Author Topic: PixelMath with ImageContainer  (Read 899 times)
« on: 2019 July 27 10:58:47 »
I have a set of 300 images in a ImageContainer and I would need to apply a PixelMath process that make image1 - image2, image 2 - image3, image n - image n+1
Any help with the formula would be appreciated!  :)
Thank you
Alejandro.
Offline oldwexi
    • Astronomy Pages G.W.
Re: PixelMath with ImageContainer
« Reply #1 on: 2019 July 27 11:37:31 »
Hi Alejandro!
Put in the Image Container
the files which you want to use and
put the expression:
image;&count;&extension;
into "Output template:"
this writes your files to the selected output directory as:
image_00001
image_00002
Yes it creates allso these files as views in your workspace but a
"Close All" removes them all.
In PixelMath put your formula and simply  click "Create new image"
and set the Image id to:             image
This is how it works for me.
Gerald
« Reply #2 on: 2019 July 27 12:15:04 »
Hi Gerald!!,
Gerald
Which would be the Pixelmath expresion?
I already have all the images in Image container named form image0001 to image0300. What I want to achieve is to subtract image0002 from image0001, then subtract image0003 from image0002, image0004 form image0003 and so on.
Alejandro.
Offline oldwexi
« Reply #3 on: 2019 July 27 13:39:57 »
Usually i use $T and do calculations with the actual image.
I have no idea how to access the last image for calculations with the actual image.
Will think about it but dont see a big chance.
Your request would need a little script which calls PixelMath with the formula and does the job
with actual image and previous image...
Sorry for havin no solution for your specific question.
Gerald
« Reply #4 on: 2019 July 27 13:49:28 »
Don't worry Gerald, thank you anyway!!  :)
Saludos, Alejandro.
« Reply #5 on: 2019 July 30 01:39:35 »
Hi Alejandro,
These tasks can be implemented very easily as scripts. What you are describing is beyond the scope of the PixelMath process.
Here is a small script (34 lines) that does exactly what you want:
#include <pjsr/ImageOp.jsh>
#include <pjsr/UndoFlag.jsh>
function SubtractSuccessiveImages( inputTemplate, outputDir )
   let inputFiles = searchDirectory( inputTemplate );
   inputFiles.sort();
   for ( let i = 0; i < inputFiles.length-1; ++i )
      let thisWindow = ImageWindow.open( inputFiles[i] )[0];
      let nextWindow = ImageWindow.open( inputFiles[i+1] )[0];
      let thisView = thisWindow.mainView;
      let nextView = nextWindow.mainView;
      thisView.beginProcess( UndoFlag_NoSwapFile );
      thisView.image.apply( nextView.image, ImageOp_Sub );
      thisView.endProcess();
      let outputFilePath = outputDir + format( "/%03d-%03d.xisf", i+1, i+2 );
      if ( !thisWindow.saveAs( outputFilePath,
                               false/*queryOptions*/,
                               false/*allowMessages*/,
                               true/*strict*/,
                               false/*verifyOverwrite*/ ) )
         console.criticalln( "*** Error: Failure to write output image: ", outputFilePath );
         break;
      thisWindow.forceClose();
SubtractSuccessiveImages( "/Users/juan/test/*.xisf", "/Users/juan/test/output" );
The script performs subtractions between successive pairs of images, which it finds on a specified input directory. The results are written to a specified output directory. The script assumes that the order of images corresponds to the list of image file names sorted alphabetically in ascending order. I think the script is quite self-describing; let me know if you need further help to understand how it works.
PixInsight is a scriptable environment precisely to solve this kind of problems.
« Reply #6 on: 2019 August 03 13:57:19 »
Excellent Juan!!, it worked perfectly well. Thank you for your help!
Saludos, Alejandro.
