I have been noticing recently that all the time I put in initially with PCC or traditional color calibration is sometimes lost after I use the LRGBCombination process. Not completely sure what is going on here besides the Lum highlighting different areas of the image that are a bit more bias in one color?
What is the best way to fix the problem? You can manually use HistrogramTransformation to fix the problem or in some cases export to photoshop and then use autotone or autocolor. However, it seems like there should be a better solution.
