Author Topic: StarNet - new module for star removal  (Read 90730 times)
Re: StarNet - new module for star removal
« Reply #45 on: 2019 July 16 21:05:34 »
not yet... the only module that exists right now is for windows. however there is a standalone program called starnet++ that runs on macosx. you need some familiarity with the osx command line to use it though.
Offline dave_galera
    • QDigital Astro
« Reply #46 on: 2019 July 17 04:14:02 »
And I can confirm that starnet++ on MacOS works perfectly well
Dave
Dave
Offline Robert Q. Kimball
« Reply #47 on: 2019 July 22 10:48:05 »
I am trying to run StarNet++ on my MAC OS but have never used the terminal before.  I have manage to open the Terminal and change the directory and list the contents of the folder I was assumming the something like exec run_rgb_starnet.sh would run the file but it didn't work.  Could you help me?
« Reply #48 on: 2019 July 22 11:06:44 »
you don't need exec, you can either do:
chmod +x ./run_rgb_starnet.sh
that's going to run starnet with canned input and output filenames and a stride of 64. the input filename will have to be "rgb_test5.tif" (no quotes of course) and it will output the starless version in "rgb_test5_s.tif". you only have to do the chmod thing once.
if you want to just run starnet on some arbitrary file:
chmod +x ./rgb_starnet++
./rgb_starnet++ your_input_filename.tif whatever_output_filename_you_like.tif
i think nikita has recommended to just run with the default stride, so i have not put it on the command line shown above. also same as the first command, you only need to do the chmod +x thing one time.
« Reply #49 on: 2019 July 22 16:00:18 »
Thank you Rob,
This the third or fouth time you've helped me over the years and I appreciate it!
I successfully ran the Mono script and got the starless output.  I then tried to repeat the process.  It didn't run.  See below:
RobertMac:StarNet_MacOS robertkimball$ chmod +x ./rgb_starnet++
RobertMac:StarNet_MacOS robertkimball$ ./run_rgb_starnet.sh
./run_rgb_starnet.sh: line 4: ./rgb_starnet++: cannot execute binary file
« Reply #50 on: 2019 July 22 16:23:48 »
no problem on the help!
looks like you still need to do chmod +x ./run_rgb_starnet.sh
but given where you are, i think you should just skip the shell script. thinking about it more, i think the script was included in the zipfile so that one could double-click the .sh from the finder and it would just run. but that requires you to rename your input images to rgb_test5.tif every time you run it. since you're already successfully in Terminal.app and in the StarNet_MacOS directory, i think you might as well just run
./rgb_starnet++ your_input_image_name.tif whatever_you_want_to_call_the_output.tif
so maybe something like like
./rgb_starnet++ tadpoles_rgb.tif tadpoles_rgb_starless.tif
« Reply #51 on: 2019 July 22 19:00:09 »
It's interesting that the RGB_starnet++ is of type "Alias" and the mono_starnet++ is of type "Unix Executible."  Could that be the problem?  I've got the mono_starnet working perfectly.
« Reply #52 on: 2019 July 22 19:09:57 »
yeah i don’t think it should be an alias. i will check my installation when i get home.
« Reply #53 on: 2019 July 22 19:41:49 »
yeah, both of course should be executables... not sure how yours became a link?
pfile% file mono_starnet++ rgb_starnet++
mono_starnet++: Mach-O 64-bit x86_64 executable, flags:<NOUNDEFS|DYLDLINK|TWOLEVEL|WEAK_DEFINES|BINDS_TO_WEAK|PIE>
rgb_starnet++:  Mach-O 64-bit x86_64 executable, flags:<NOUNDEFS|DYLDLINK|TWOLEVEL|WEAK_DEFINES|BINDS_TO_WEAK|PIE>
if you do
ls -l rgb_starnet++
you will see what it is pointing to.
« Reply #54 on: 2019 July 22 19:45:10 »
It's the stangest thing!  I unzipped the folder again and the rgb_starnet++ was listed as Unix Executable.  It is running right now in the background.  Thanks so much for all your help.
« Reply #55 on: 2019 July 23 09:00:41 »
Having big fun now that Rob has helped me get StarNet++ running.  I have attached two examples.  They look much better when they are seen as 16 bit tifs.
Offline SeattleStarGazer
« Reply #56 on: 2019 July 24 18:36:26 »
Downloaded the module and moved all files into the Pixinsight bin directory. No new modules available, tried search, same thing. I'm running a pretty new workstation, Xeon processor and Quadro P5000 16 Gig graphics card. I'm new to module install, not sure what I'm missing
« Reply #57 on: 2019 July 24 18:39:02 »
i wonder if the Xeon processors don't have all the vector instructions that the starnet module needs. a sanity check is to download starnet++ and see if it runs.
https://sourceforge.net/projects/starnet/
« Reply #58 on: 2019 July 24 20:49:28 »
Thanks! I did just run it from the .bat file included in the download and it worked fine. It just said the version of tensorflow included isn’t compiled to use the AVX2 extensions of the processor, but then went ahead and worked. All you are supposed to do is copy all the files in the download to the PI .bin directory then open the PI Process-> Modules command, right?
Wsyne
« Reply #59 on: 2019 July 24 21:17:41 »
ok so that warning just means that if you come up with a tensorflow.dll that better supports your cpu it will run faster. i think the PI module checks if it can run and won’t install if it can’t, the most common reason being that the cpu lacks the minimum set of vector instructions. so that’s not the problem you’re having.
as for how to install the PI module, i am not sure since i usually use macosx and haven’t tried installing it on my windows machine (the module only exists for windows at this time.)
