Author Topic: Blue/white artifacting stars  (Read 762 times)
Offline DJago
« on: 2019 June 14 05:26:21 »
Hello, I'm processing NGC 6188 and I'm having trouble with some misshapen/artifacted/discoloured stars.    The effect is visible after stretch/channel combination (SHO pixelmath).  I was wondering if anyone knew why this happens and how i can prevent it from happening?
https://imgur.com/cDLcOzQ
https://i.imgur.com/Sh70j2V.jpg
https://i.imgur.com/BH9dMDK.jpg
I'm using a william optics gt81 and an ASI 1600mm-c.
Thanks.
Offline wvanreeven
Re: Blue/white artifacting stars
« Reply #1 on: 2019 June 14 06:42:44 »
Did you refocus when switching to the blue filter? I suppose you did.
It may be a blue halo caused by imperfect optics. I had the same problem with my WilliamOptics ZS71 ED.
Offline DJago
« Reply #2 on: 2019 June 14 06:46:16 »
It may have something to do with using different brand filters.  I'm using a ZWO HA filter and Astronomik Oiii and Sii filters.  Imaging for each channel was done on different nights so focusing isn't the issue.
Offline wvanreeven
« Reply #3 on: 2019 June 14 07:03:16 »
Ah wait I hadn't seen that you were using small band filters. Then please ignore what I wrote about imperfect optics because that only comes in play with broad band imaging.
