Author Topic: quick local normalization question......  (Read 720 times)
Offline sharpie78
« on: 2019 May 22 12:04:01 »
Hi everybody. Just a quick one about when to do local normalization with data sets from different nights...........
Should I be locally normalizing each nights subs to a reference frame from that night ?
or ........
Should I be locally normalizing all subs from a data set of different nights to the best reference frame of them all ?
Thanks in advance
nb. At the moment I am saving each nights weighted, registered and locally normalized subs, then integrating them all once I've got 5-10 hrs of data.
Offline John_Gill
Re: quick local normalization question......
« Reply #1 on: 2019 May 23 05:22:06 »
With my workflow I do the following for each session:
Image Calibration
Cosmetic Correction
Debayer (if using OSC)
 *** All Images for each session are now clean ***
Star Alignment all images from each session
Local Normalization for all images
Image Integration for everything.
I hope this helps
John
APM 107/700 apo on CGX mount
ZWO Optics - Autoguiding
ZWO1600mm and filters
Offline airscottdenning
« Reply #2 on: 2019 May 23 17:20:43 »
Is this preferred to checking "normalization" in Image Integration? What's the advantage either way?
Offline sharpie78
« Reply #3 on: 2019 May 23 18:07:12 »
Whether it is preferred depends on the quality of the data you're processing I guess. Just checking "normalization" in Image Integration works well with some of my data. If my neighbours are being particulary awkward and have all their lights blaring I find using local normalization helps.
Offline sharpie78
« Reply #4 on: 2019 May 23 18:17:16 »
Thanks John. I was fully calibrating, weighting, normalizing etc each nights data set seperately then integrating everything once I had 2 or 3 nights worth. It's worked ok so far but I'll try your method too.
For clarity......are you weighting your subs with subframeselector ? If so, before you align the subs, do you analyse and weight all the "clean" subs from all sessions together ?
Offline John_Gill
« Reply #5 on: 2019 May 24 02:16:40 »
My logic is something like this: Over 5 separate imaging nights of 20 images per night, if you pre-process each nights images up to and including "ImageIntegration" you end-up with 5 images that you register against each other to create a final image.  If you collect all the images up to the "clean" section and then do a "SubframeSelector", "StarAlignment" and "LocalNormalization" you will then do an "ImageIntegration" with 100 images.
With "SubframeSelector" I look for the lowest "Eccentricity" and "FWHM" and highest "SNR" and then make a decision.  Some people use "complex formulas" to weight each image
space is not black
John
