Author Topic: New release of 1.8.6 on Linux does not start - old bug is back  (Read 1186 times)
Offline starhopper
    • starhopper
Hello,
the new release of Pixinsight installs successfully on my PC
PixInsight X11 UNIX/Linux installer version 01.08.06.1473 Ripley
Copyright (C) 2003-2019 Pleiades Astrophoto. All Rights Reserved
PixInsight will be installed with the following parameters:
Source installation directory ... /home/starhopper/pi-install/PixInsight
PixInsight core application ..... /opt/PixInsight
Application desktop entry ....... /usr/share/applications/PixInsight.desktop
Application icons directory ..... /usr/share/icons/hicolor
MIME type description file ...... /usr/share/mime/packages/PixInsight.xml
Create /bin launcher script ..... yes
Remove previous installation .... yes
==> Are you sure [yes|no] ? yes
Please wait while PixInsight is being installed...
but it does not start. :-(
starhopper@shark:/opt/PixInsight/bin$ ./PixInsight.sh
/opt/PixInsight/bin/./PixInsight: /opt/PixInsight/bin/./lib/libz.so.1: version `ZLIB_1.2.9' not found (required by /usr/lib/x86_64-linux-gnu/libpng16.so.16)
I remember that this happend on earlier releases.
Thomas
Thomas Jäger
https://www.starhopper.eu
12"f/3.8 & 8"f/2.9 Astrograph
SBIG STL11000M, Moravian G2 8300
Vixen Atlux Mount, Skywatcher AZ-EQ6 GT
Skywatcher Esprit 100/550
Hi Thomas,
There is no libz.so file in the 1.8.6 distribution of PixInsight for Linux. You are probably mixing files from different versions when you install PixInsight.
When you uncompress the installation archive, please make sure that you remove any existing 'PixInsight' folder on your '/home/starhopper/pi-install/' directory before running the tar command. PixInsight 1.8.6 runs out-of-the box without problems on all tested Linux distributions.
Offline starhopper
    • starhopper
I have deinstalled the old version with the -u option.
Thanks for your reply, I will try it again and clean up the folder before.
Thomas
Now I cleaned it up manually. That works.
Thomas
« Last Edit: 2019 May 18 11:53:38 by starhopper »
Thomas Jäger
