Author Topic: combining different images of same subject  (Read 522 times)
Offline jamesRC
« on: 2019 May 09 08:54:55 »
Hello there -
I have two groups of the same image, Messier 101. They were taken at 2 different exposure times. I have darks, flats and bias for each of them. What's the better way of combining them so I can get all the information possible?
Thank you very much!
James
Offline Geoff
Re: combining different images of same subject
« Reply #1 on: 2019 May 09 09:38:29 »
I would calibrate each set separately, then register all the resulting frames, followed by image integration of all the frames.
Don't panic! (Douglas Adams)
Offline jamesRC
« Reply #2 on: 2019 May 09 11:38:36 »
Thank you very much, Geoff. man, lot of work. I'm happy we got scripts, even if it's looked down on :-)
James
Offline wvanreeven
« Reply #3 on: 2019 May 09 12:33:52 »
Are the exposure times very different? If yes you might consider to calibrate each set separately, register together (so they are aligned with each other) and then integrate separately. Next use HDRComposition to combine them. This might bring out more details in bright parts of the galaxy.
HTH, Wouter
