Author Topic: BPP not using saved CosmeticCorrection process  (Read 1083 times)
Offline jpaana
« on: 2019 May 01 04:43:39 »
Hello,
it seems starting saved instance of BPP with CosmeticCorrection enabled doesn't use the correct process but always seems to use the first one it finds. I have two cameras, mono and color, and use two different CC processes (named CosCorr and CosCorr_CFA) and my saved BPP instances always want to use the mono one which happens to be first on the list. Looking at the saved parameters there seems to be cosmeticCorrectionTemplateId which is correctly set to CosCorr_CFA for my color camera BPP instance, but still when I start it, the template icon is set to CosCorr which is my mono instance.
« Last Edit: 2019 May 01 09:06:53 by jpaana »
