Author Topic: Zoom level for all open images at the same time  (Read 1060 times)
Offline Herbert_W
« on: 2019 March 26 23:14:46 »
is there a possibility to change all open images to the same zoom level at the same time - (process console)?
Thank you and best regards!
Herbert, Austria
Re: Zoom level for all open images at the same time
« Reply #1 on: 2019 March 27 01:39:06 »
Hi Herbert,
Yes, of course you can do this. Some examples:
zoom -z=4 *
This will apply a 4:1 zoom factor to all open images.
zoom -f *_B*
Apply the 'zoom to fit' action to all images including '_B' in their identifiers.
If you enter 'help zoom' you'll get detailed information on the zoom command. Here is the result for your convenience:
help zoom
The zoom command sets the current zoom ratio for a set of views.
Usage: zoom [<arg_list>] [<image_id_list>]
-z=<n> | --zoom-factor=<n>
      <n> is the new zoom factor in the range [-32,+100]. Positive values are
      zoom-in (magnifying) factors. Negative values indicate zoom-out
      (demagnifying) factors. The zero and -1 values are reserved and must
      not be used. +1 corresponds to the 1:1 (actual size) zoom ratio.
-i | --zoom-in
      Selects the zoom-in mode. Current zoom factors are incremented.
-o | --zoom-out
      Selects the zoom-out mode. Current zoom factors are decremented.
-f | --fit
      Selects the zoom-to-fit mode. Zoom factors are automatically calculated
      such that target views fit in the workspace completely.
--fit-no-zoom
      Same as --fit, but no magnification is allowed.
--fit-view
      This option does not change current zoom rations. It resizes target
      windows so that they fit their current views completely, if this is
      possible without exceeding workspace limits; otherwise windows are
      resized to occupy the whole workspace, in one or both axes.
--help
      Displays this help and exits.
The information given is slightly outdated. The minimum zoom factor is now -100, that is, the allowed range of zoom factors is [–100,+100]. This command should provide arguments to apply an optimal fit action, as well as more control on the target images. I'll implement them in the next version.
Offline Herbert_W
« Reply #2 on: 2019 March 27 01:57:30 »
Hi Juan,
Thanks for the quick answer - that's exactly what I was looking for.
PixInsight can do everything  :)
Best regards!
Herbert, Austria
PS: I had 'help zoom' open - but didn't get the placeholder option.
Sometimes concrete examples, like in your answer, would be very helpful in help files, too.
At least for me, who's not familiar with computer nomenclature.
