Author Topic: Image container cannot abort  (Read 3791 times)
« on: 2009 July 27 12:29:17 »
I created an Image Container with 180 images, and let it run a process that eventuelly got an "Out of Memory" error. The Image Container was set to "On errors: continue execution". Two problems:
- A dialog box pops up saying "Out of memory", requesting to hit the "OK" button, which should not happend with "continue execution" policy. After hitting "OK", processing continues (which is ok).
- I cannot abort the process after hitting "OK", even using the "Abort/Pause" button in the console window. My request to abort caused a dialog that was always ignored (which is annoying when there are another 100 images that cause "Out of memory".)  :'(
Using "ask what to do" behaves as it should.
