Author Topic: PixInsight 1.5.6 Released | PixInsight 1.5.6 Publicado  (Read 7689 times)
[Versión en Español al final]
Hi all,
We are pleased to announce the release of PixInsight 1.5.6 for Linux, Mac OS X and Windows.
This is a bugfix and optimization release. Some of the fixed bugs are critical, so we encourage all our users to update their current installations as soon as possible.
Download Addresses
PixInsight 1.5.6 is now available for download from our file servers:
* For commercial users (user name and password required):
      http://dist.pixinsight.com/
* For users of 30-day trial licenses:
      http://pixinsight.com/download/STD/
Installation
Before installing PixInsight 1.5.6, it is advisable to uninstall a previous version. This is the recommended procedure:
Linux
   1. Exit all running instances of the PixInsight core application, if any.
   2. Delete the whole directory where a previous version of PixInsight was installed. If you have created files of your own within PixInsight's installation directory, please don't forget to backup them first.
   3. Unpack the .tar.gz file on a suitable directory, preferably one under the user's personal directory (for example, $HOME/PixInsight).
   4. To launch PixInsight, run the PixInsight.sh shell script on the bin installation directory.
Mac OS X
   2. Delete the previous version of the PixInsight.app application bundle. If you installed it on the standard location, it should be on the /Applications folder.
   3. Double click the .zip installation archive for version 1.5.6. This will create a new PixInsight.app application bundle. PixInsight can be executed from any location, but we recommend copying PixInsight.app to the standard /Applications folder. You may want to add it to the Dock as well.
   4. If you are a commercial Windows or Linux user, your existing license file works fine on the Mac; you do not need to reactivate your license. Do the following:
      4.1 Locate your PixInsight license file. It is the .pixinsight-license file on your personal folder of your Linux or Windows machine.
      4.2 Make a duplicate of .pixinsight-license, and rename it to pixinsight-license (that is, the same name but without a starting dot character).
      4.3 Copy the pixinsight-license file to your home folder on the Mac. Now you can run PixInsight for Mac OS X with your commercial license.
Windows
   2. Uninstall PixInsight. There is a Start > PixInsight Platform > Uninstall menu item that should be used. Never try to uninstall PixInsight by manually removing files. If you have created files of your own within PixInsight's installation directory, please don't forget to backup them first.
   3. Run the PixInsight installation module for version 1.5.6.
   4. To launch PixInsight, go to Start > PixInsight Platform > PixInsight Core.
Bug Fixes
Version 1.5.6 fixes all confirmed bugs and regressions as of the date of release. Please refer to the Bug Reports board of this forum.
New Tools and Features
Please refer to the Release Information board on this forum, where we'll be providing detailed descriptions and practical usage examples of all new features and improvements during the next days. Also stay tuned with our video tutorials collection because we'll be authoring new videos during this Summer.
As a brief summary, These are the main changes and improvements introduced since PixInsight 1.5.5:
- Completely redesigned and rewritten screen rendering engine. New fast rendering mode.
- New mask rendering modes, including eight color overlay modes and a mask replacement mode, along with the traditional mask multiplication mode that has always been used to render masks in PixInsight since the first LE version.
- Important changes to the ImageIntegration process. Implementation of a new noise evaluation algorithm based on the multiresolution support (Starck et al., 1998, 2002). New image normalization modes for pixel rejection. Improved file cache management and Winsorized sigma clipping rejection.
- Important changes to the StarAlignment process. Improved star detection engine. Improved RANSAC implementation for rejection of false putative star pair matches. New preview operation mode for mosaic construction.
- New scripts available: Batch CMYG deBayer utility by Niall Saunders, Deconvolution Preview by Juan Manuel Gómez, and MathTran Client by Juan Conejero.
- New command-line commands available in the core PixInsight application: echo, set, dedicated.
- New script preprocessor directives: #ifoneof, #ifnoneof
- Important boost to the PixInsight JavaScript Runtime (PJSR) development framework. New native JavaScript objects: Cursor, Matrix, Vector, FileTransfer, FileDownload and FileUpload. New objects implemented as pure JavaScript code: ColorComboBox and SimpleColorDialog. New automatic garbage collector. Important new methods of the Math object for basic linear algebra operations (SVD, Gauss-Jordan solvers) and generation of Gaussian and linear filter distributions. Lots of new features added to the Global, Image, Settings, Graphics and Font native objects.
- Important changes to the PixInsight Class Library (PCL) C++ development framework. New MIME type support for image file formats (changes to all file format related classes). New member functions of the ImageWindow and Bitmap classes to implement access to the new mask rendering modes and fast bitmap/screen rendering engine.
- New thread priority scheduling policy that avoids exhausting system resources on Windows.
Note for Developers
PixInsight 1.5.6 introduces some changes to the low-level C API for modules (new API interface version 0x119). All modules built with previous versions of the PCL (including PCL 1.0.70) require full recompilation and linkage against the new PCL 1.0.71.
I hope you'll like it. Have fun!
Hola a todos
Nos complace anunciar que PixInsight 1.5.6 ya está disponible para Linux, Mac OS X y Windows.
Se trata de una versión para optimización y corrección de errores. Algunos de los errores corregidos son críticos, por lo cual recomendamos a todos nuestros usuarios que actualicen sus instalaciones lo antes posible.
Direcciones de Descarga
PixInsight 1.5.6 está disponible para su descarga desde nuestros servidores de archivos:
* Para usuarios comerciales (se requiere nombre de usuario y contraseña):
* Para usuarios con licencia de pruebas de 30 días (30-day trial license):
Instalación
Le recomendamos encarecidamente que actualice su instalación tan pronto como le sea posible. Antes de instalar PixInsight 1.5, es recomendable desinstalar la versión anterior. Éste es el procedimiento recomendado:
Linux
   1. Termine todas las instancias en ejecución de la aplicación principal de PixInsight.
   2. Borre el directorio completo donde instaló la anterior versión de PixInsight. Si ha creado algún archivo propio dentro del árbol de de directorios de instalación de PixInsight, por favor no olvide hacer una copia de seguridad previa.
   3. Descomprima el archivo .tar.gz en un directorio cualquiera, preferiblemente en uno bajo su directorio personal de usuario (por ejemplo, $HOME/PixInsight).
   4. Para lanzar PixInsight, ejecute el script PixInsight.sh desde el directorio bin de instalación.
Mac OS X
   2. Borre la versión anterior del archivo de aplicación PixInsight.app. Si lo instaló en su ubicación estándar, debería estar en la carpeta Aplicaciones (/Applications).
   3. Haga doble clic en el archivo .zip de instalación para la versión 1.5. Esto generará un archivo de aplicación con el nombre PixInsight.app. PixInsight puede ser ejecutado desde cualquier ubicación, pero le recomendamos que copie PixInsight.app a la carpeta estándar Aplicaciones (/Applications). Probablemente también querrá añadir PixInsight al Dock de Mac OS X.
   4. Si es usted un usuario comercial en Windows o Linux, su archivo de licencia funcionará perfectamente también en Mac OS X; no tiene que reactivar su licencia ni nada parecido. Haga lo siguiente:
      4.1 Localice su archivo de licencia de PixInsight. Es el archivo .pixinsight-license en su carpeta personal.
      4.2 Haga un duplicado de .pixinsight-license y cambie su nombre a pixinsight-license (o sea, el mismo nombre pero sin el punto inicial).
      4.3 Copie el archivo pixinsight-license a su carpeta personal en el Mac. Ahora puede ejecutar PixInsight para Mac OS X con su licencia comercial.
Windows
   2. Desinstale PixInsight. Hay una opción del menú Inicio > PixInsight Platform > Uninstall que debería utilizar. Nunca intente desinstalar PixInsight eliminando archivos manualmente. Si ha creado algún archivo propio dentro del conjunto de carpetas de instalación de PixInsight, por favor no olvide hacer una copia de seguridad previa.
   3. Ejecute el módulo de instalación para la versión 1.5.
   4. Para lanzar PixInsight, vaya a Inicio > PixInsight Platform > PixInsight Core.
Correcciones de Errores
La versión 1.5.6 soluciona todos los errores y regresiones confirmados hasta la fecha de publicación. Para obtener información acerca de los errores y problemas resueltos, consulte la sección Bug Reports (Informes de Errores) de este foro.
Nuevas Herramientas y Características
Consulte la sección Release Information (Información sobre Versiones) en este foro, donde en días sucesivos iremos proporcionando información detallada y ejemplos prácticos de uso para las nuevas herramientas y características. Esté también atento a nuestra colección de videotutoriales porque vamos a publicar nuevos vídeos durante este verano.
Aquí tiene un resumen de los principales cambios y mejoras introducidos desde PixInsight 1.5.5:
- Motor de renderización en pantalla completamente rediseñado y reimplementado. Nuevo modo de renderización rápida (fast rendering mode).
- Nuevos modos de renderización de máscara, incluyendo ocho modos de superposición de color (color overlay) y un modo de reemplazo de máscara (mask replacement), junto con el tradicional modo de multiplicación de máscara (mask multiplication) que siempre ha sido usado para representar máscaras en PixInsight, desde la primera versión LE.
- Importantes cambios en el proceso ImageIntegration. Implementación de un nuevo algoritmo de evaluación del ruido basado en el soporte multirresolución (Starck et al., 1998, 2002). Nuevos modos de normalización de imagen para rechazo de píxeles. Gestión de la caché de archivos y rechazo por sigma clipping Winsorizado mejorados.
- Importantes cambios en el proceso StarAlignment. Detector de estrellas mejorado. Implementación mejorada de RANSAC para el rechazo de falsas parejas de estrellas. Nuevo modo de generación de mosaicos basado en previsualizaciones.
- Nuevos scripts disponibles: Batch CMYG deBayer utility por Niall Saunders, Deconvolution Preview por Juan Manuel Gómez, y MathTran Client por Juan Conejero.
- Nuevos comandos en línea de comandos disponibles en la aplicación PixInsight Core: echo, set, dedicated.
- Nuevas directivas del preprocesador de scripts: #ifoneof, #ifnoneof
- Importante mejora en el entorno de desarrollo PixInsight JavaScript Runtime (PJSR). Nuevos objetos JavaScript nativos: Cursor, Matrix, Vector, FileTransfer, FileDownload y FileUpload. Nuevos objetos implementados como código JavaScript puro: ColorComboBox y SimpleColorDialog. Nuevo recolector de basura (garbage collector) automático. Nuevos métodos del objeto Math para operaciones básicas de álgebra lineal (descomposición por valores singulares (SVD), resolución de sistemas por Gauss-Jordan) y generación de filtros con distribuciones Gaussianas y lineales. Gran cantidad de nuevas características implementadas para los objetos nativos Global, Image, Settings, Graphics y Font.
- Importantes cambios en el entorno de desarrollo en C++ PixInsight Class Library (PCL). Nuevo soporte de tipos MIME para formatos de archivo de imagen (cambios en todas las clases relacionadas con formatos de archivo). Nuevas funciones miembro de las clases ImageWindow y Bitmap para implementar el acceso a los nuevos modos de renderización de máscara y el nuevo motor acelerado de renderización en pantalla y en bitmaps.
- Nueva política de prioridades de hilos de ejecución que evita consumir todos los recursos del sistema en Windows.
Nota para Desarrolladores
PixInsight 1.5.6 introduce algunos cambios en la interfaz de bajo nivel en C (low-level C API) para módulos (nueva interfaz de API versión 0x119). Todos los módulos construidos con versiones anteriores de PCL (incluyendo PCL 1.0.70) requieren su completa recompilación y enlace con la nueva PCL 1.0.71.
Espero que os guste. ¡Que lo disfrutéis!
« Last Edit: 2009 July 21 02:38:59 by Juan Conejero »
Offline Stephane Murphy
Re: PixInsight 1.5.6 Released | PixInsight 1.5.6 Publicado
« Reply #1 on: 2009 July 21 04:57:54 »
Thanks Juan, I installed teh lates bits without problem. Great job again.
Stephane
Stephane Murphy
CDK 12.5 Planewave Instrument
Paramount ME
SBIG STL11000M
SBIG ST-402 Guider
Astrodon MOAG
Astrodon Filters
« Reply #2 on: 2009 July 21 09:54:21 »
Thanks Stephane!
Offline h0ughy
« Reply #3 on: 2009 July 21 19:24:38 »
downloaded it last night for the 2nd time LOL after downloading 1.5.5 .  loaded it on the laptop seemed to go ok.  yet to play with it (need to get some data - imaging is as scarce as hens teeth at the moment)
Doghouse Observatory
