Author Topic: Nikon D7500 sensor parameters  (Read 669 times)
Offline ppeake
« on: 2019 February 12 13:55:11 »
Using the new selector, it wants some info on the sensor (Camera Gain).
Not being able to find anything for the D7500 via Google, I used the BasicCCDParameters script to determine the characteristics.
The numbers work, but then again, virtually any random number seems to work ok for the subframe selector, and the pop-ups are not terribly informative.
Anyway ... back on track. Just wondering if the numbers that I obtained look believable:
Gain: 0.091 e/ADU
Readout Noise: 1.181 e
Dark Current: 0.005 e/sec
Full Well Capacity: 1484.083 e
Not sure that I really understand these well enough to be certain myself.
Offline sharkmelley
Re: Nikon D7500 sensor parameters
« Reply #1 on: 2019 February 12 14:45:55 »
You didn't mention what ISO you used.
So it's difficult to know if the numbers make sense or not (since they vary according to ISO).
Mark
Takahashi Epsilon 180ED
H-alpha modified Sony A7S
Offline ppeake
« Reply #2 on: 2019 February 12 14:52:37 »
Yes, should have mentioned: ISO 3200
Offline sharpie78
« Reply #3 on: 2019 February 13 03:13:14 »
I used to use a canon DSLR and at ISO800 ;
gain : 0.27 e/ADU
Readout Noise : 2.8 e
Dark Current : 0.002 e/sec (diy cooler)
I cant remember the full well capacity
I'd say your figures look reasonable for the high ISO that you're using.
.....sidenote.....if you are guiding and can do 5 minute or more subs....reduce your ISO and expose longer. Aim for the main peak of the histogram of your exposures to be in the 20-40% area (1/3 of the way from the left)
Offline ppeake
« Reply #4 on: 2019 February 13 09:34:31 »
I am guiding, but with a 300mm lens, so exposure time is still rather short.
The D7500 actually behaves rather well at relatively high ISO.
Offline sharpie78
« Reply #5 on: 2019 February 13 12:12:34 »
If it's behaving well, stick with it then mate.  :)
I'm only going by the results I got with my EOS450D and our cameras obviously have different chips plus we're using different optics. If you read Jerry Lodrigus' book  - DSLR Astrophotography, there is an explanation on why lower ISO settings sometimes yield better results but I certainly couldn't repeat it to you verbatim.
I spent hours upon hours measuring sensor characteristics when I built a cooler for my DSLR, wanted to see if it was having any effect on noise etc. Very tedious but I learnt a lot in the process.
