Author Topic: Crash on Debayer  (Read 11032 times)
Offline jeburt3
Re: Crash on Debayer
« Reply #15 on: 2019 August 29 12:51:51 »
It seems that the problem is Random (I would prefer to have consistently successful processes)
I had taken another set of pictures Wednesday night of M33. There were 64 FIT files. I decided I would run the the same BLINK and SUBFRAME SELECTOR processes for these files. To my surprise, the DEBAYER was a success!
Process Console: Debayer: 64 succeeded, 0 failed
That made me happy so I decided to try again the bigger set of files (i thought I had 64 files I actually had 120). I did not restart PixInsight.
It worked.
Process Console: Debayer: 120 succeeded, 0 failed
Happy about this outcome, concerned about stability.
Offline dhb2206
« Reply #16 on: 2019 December 26 01:31:02 »
Juan,
Still doing this, but I have noticed a pattern. If I debayer from one external drive to another I'm almost (note the almost) guaranteed a crash. However, if I shunt the files to the second hard drive before running debayer then there is no problem. So, this probably has something to do with the USB system in Windows. Note also that the target drive also hosts my temp folder.
Cheers (and a Merry Christmas),
David
Offline otti242
« Reply #17 on: 2020 January 04 13:57:27 »
I can confirm that the crash sometimes happens on MacOS also.
« Reply #18 on: 2020 January 05 03:34:46 »
This cannot be reproduced on any platform, with any of our working and testing machines and data sets.
Can you please provide a data set where this problem can be reproduced, or a pattern to reproduce it?
Offline dhb2206
« Reply #19 on: 2020 February 10 07:32:19 »
Unfortunately I don't think there is a pattern Juan, it just happens sometimes. On a bright note it hasn't happened recently and I've been running debayer quite a lot recently.
