Author Topic: Thumbnail viewer from within pixinsight file Explorer  (Read 516 times)
Offline GregW
« on: 2019 February 01 20:30:18 »
Is there any reason why pixinsight won't show thumbnail preview pics in its file Explorer? I can understand Windows not doing it.  is there any reason to save files as Xsif as opposed to Tiff.  any plans on a thumbnail viewer within the program?
Objects in the mirror are farther than they appear
Re: Thumbnail viewer from within pixinsight file Explorer
« Reply #1 on: 2019 February 02 02:01:25 »
The File Explorer window includes a resizable thumbnail, a histogram preview, and metadata information, including basic statistics, image geometry and color space, as well as FITS keywords when applicable. This works for all supported file formats and all PixInsight project files and bundles. You can right-click the thumbnail to configure it, including its dimensions, automatic STF settings, and cached data.
File explorer allows you to open any image or set of images in PixInsight. You can double-click a file or drag a file or set of files to PixInsight's workspace. You can also drag folders and sets of files to tools that require file lists, such as ImageCalibration, ImageIntegration, StarAlignment, etc. You can also drag a file or a folder to any place on a tool where these items are required. Besides this, File Explorer allows you to navigate your local filesystem in a safe read-only mode, which you can disable temporarily to perform common actions such as copying, moving, deleting and renaming files and folders.
Normally File Explorer is docked as an auto-hide window at the left side of PixInsight's main window. Hover the File Explorer vertical tab to open it. If it isn't docked, select View > Explorer Windows > File Explorer from the main menu.
There are dozens of reasons. The fact that XISF is the native file format of PixInsight is just one of them, and not the most important one. See the XISF resources page for more information.
As for TIFF, this format is unable to provide even a minimal support for the data and metadata that we have to store and manage in PixInsight. Its support is maintained just for compatibility with legacy data and applications.
As we continue implementing more functionality and capabilities in PixInsight, XISF will become more important because it is the only format able to implement most of the new features. For example, in an incoming version of PixInsight an XISF file will be able to store the complete processing history of an image, which will be a crucial feature. This is impossible with other formats.
Offline GregW
« Reply #2 on: 2019 February 02 11:35:43 »
Thank you for the prompt reply I will look into that further. What I was actually referring to was when double-clicking in a work space it brings up a file explorer similar to the Windows File Explorer and there are no previews there.  I will look further into the file explorer feature rather than a double click on a workspace.
