Author Topic: Calibration Tools  (Read 7550 times)
Offline Harry page
Calibration Tools
« on: 2009 July 18 11:13:19 »
Hi Juan
I know this is in your mind, but I thought I would tell you what I would like :D
Me and others are using OSC camera and with this in mind I would like it to do
1) Debayer ( If needed)
2) Apply Flat ( Tool needed to create flat for OSC ie box car filter)
3) Application of darks and bias ( Again if needed )
4) Defect map application ( again tool to create one )
And ideally integration with the alignment and integration tool to create full automation ;D
Just something for you to chew on as I know you don't have anything to do :laugh:
Regards Harry
« Last Edit: 2009 July 19 08:03:38 by Harry page »
Harry Page
Offline Cheyenne
    • Link to Picasa gallery of my astronomy photos
Re: Calibration Tools
« Reply #1 on: 2009 July 18 12:07:37 »
I would like to chime in on adding DSLR support as well ...
Cheyenne Wills
Takahashi 130 TOA
Losmandy G11
SBIG STF8300M
Canon 20Da
SBIG ST-i + openPHD for autoguiding
« Reply #2 on: 2009 July 19 07:27:27 »
Hi Juan
Regards Harry
I hope you're not proposing those steps in order :) They should be applied from step 4 to 1 in reverse order. In the case of step 2 there is no need to do a 1:2 reduction. Instead flats should be applied on each color channel separately the way HAIP describes and DSS does. Note that this is done before debayering so a flattened image still contains a bayer matrix.
Offline Harry page
« Reply #3 on: 2009 July 19 08:02:54 »
Hi Sander
I should have listed them in order not as they came into my head ???
As you know the art of a OSC flat is a dark one
The only way I could decent results using AA4 was to remove all colour ( extract a LUM ) and I believe that the box car filter removes the bayer matrix ( Correct me if I am wrong)
But I am more than willing to listen to any ideas on this ;)
Regards harry
Harry Page
« Reply #4 on: 2009 July 20 04:36:45 »
Hi all,
The art of using OSC Flats is neither 'dark' nor 'mysterious' - assuming that you are working with RAW data (i.e. data that still contains the "CFA", in other words data that still appears 'greyscale')
ALL of your calibration steps should be using this RAW data. Lights, Darks, Flats and FlatDarks (and BiasOffsets, if you 'have' to use them) should all be 'greyscale', and should all look 'blocky' when you zoom in.
It is only AFTER you have 'calibrated' your Lights that you should be considering deBayering your (still RAW) Lights into colour frames, ready for aligning and stacking.
So, just take your Darks, Flats and FlatDarks in exactly the same way as you acquire your Lights,just bearing in mind that :
Darks should be at the same CCD Temperature as your Lights, and should have the same Exposure Time - and you should have enough of them to be 'statistically viable' (5 minimium ??)
Flats should be taken with an Exposure Time that gives you a 'Median' ADU value of around 1/2 of the maximum ADU value supported by your imager (1/2 * 65535 for a 16-bit imager, for example). This is a 'guidance level' only - you should research your imager and find out what others are recommending.
Then you would take time and temperature matched FlatDarks - and would take enough of both to be statistically useable. Your Flats/FlatDarks do NOT have to match the ExpTime or Temp of your Lights/Darks in ANY way, shape, or form.
HTH
Offline Cheyenne
« Reply #5 on: 2009 July 20 05:36:30 »
Here is a good "paper" detailing the whole calibration process (math included).  It's targeted towards a spectrograph, but goes into great detail the process of calibrating images.
Andreas Observatory Spectrograph Manual
Cheyenne Wills
Takahashi 130 TOA
Losmandy G11
SBIG STF8300M
Canon 20Da
Offline mmirot
« Reply #6 on: 2009 July 20 11:17:02 »
Yes
Time for a full blown calibration module that does these functions.
It would be nice it you could just add a set of files to the image container then have it align & intergrate after calibration.  I am sure Juan has this on his list.
Max
