Author Topic: No correction made Amp Glow zwo 1600MM cool in batch processing  (Read 520 times)
Offline ericm
Newbie alert. I took dark frames at the same length and temperature as my light frames. After stretching them on my screen the amp glow was visible. After processing all my files the quick way via batch processing in the final result its like nothing has happened, the amp glow was still visible in the result. Exact the same as on the master dark frames like there was no correction at all. I thought that in Batch Processing normally the correction was made automatically. Or am I doing something wrong?
Re: No correction made Amp Glow zwo 1600MM cool in batch processing
« Reply #1 on: 2019 January 22 10:50:03 »
make sure "optimize darks" is unchecked... if the darks get scaled the amp glow won't be fully subtracted from the lights.
Offline ericm
« Reply #2 on: 2019 January 22 11:11:17 »
Thanks Rob, I think that box was checked. Tomorrow I will start again with the workflow. It's a steep learning curve. :smiley:
