Author Topic: How to interpret strange gain values in BasicCCDParameters?  (Read 771 times)
Offline magnusl
Hi!
I am playing with the BasicCCDParameters script, following instructions found here: https://www.lightvortexastronomy.com/measuring-your-camera-sensor-parameters-automatically-with-pixinsight.html
Screenshot of the report is attached.
The data here is from a Canon 1000D. I use 2 identical flats, 2 bias frames, and 2 darks with exposures differing with a factor of 10. ANd I get what I think is strange gain values, and generally, strange differences between the colums. What am I missing here?
- I would not expect the gain value to be more than 2. In fact, it is roughly the same despite ISO value on the images. I normally use ISO 400, here I tried 100 to see if gain would be lower. But not.
- I would expect the values to be quite similar in the different columns - that is what I have seen when others try. Why not here?
The files I used are available here:
https://www.dropbox.com/sh/g955gg2qht6e02h/AACE6cp3sx33i7ZceOIav5xZa?dl=0
Any ideas? I'm quite confused.
Magnus
Offline sharkmelley
Re: How to interpret strange gain values in BasicCCDParameters?
« Reply #1 on: 2019 January 23 15:13:32 »
A couple of things I notice:
   1) You have a mixture of ISO 100 and 400.  That won't help.
   2) Your flats show significant vignetting.  You need to select a region of interest that is as flat as possible.
Mark
Takahashi Epsilon 180ED
H-alpha modified Sony A7S
Offline magnusl
« Reply #2 on: 2019 January 23 22:49:00 »
Hi!
Thanks for your reply!
So, I do the same with all frames at ISO400, and I define a small preview in the center, which is the flattest part of the image. And again I get what I consider to be strange values, see attached screenshot. Subs are in the same folder as before.
Magnus
Offline sharkmelley
« Reply #3 on: 2019 January 24 00:07:24 »
Your flat frames are saturated in the green channel.  That's your main problem.  The green channel is clipping at a value of 3651 which you can clearly see if you look at the histogram in the HistogramTransformation tool.
I didn't notice it earlier because I missed the fact that the camera is only 12bit.
Mark
« Last Edit: 2019 January 24 00:33:45 by sharkmelley »
Offline magnusl
« Reply #4 on: 2019 January 24 11:47:23 »
Hi!
Ok, thanks! Using another pair of flats with lower exposure makes a difference - now the values are rather consistent across the channels!!
But still - my gain vaiule is 2.7-2.8. I'm surprised by that  - is that really to be expected from a Canon 1000D?
Magnus
Offline sharkmelley
« Reply #5 on: 2019 January 24 13:42:33 »
Why the surprise?  The gain seems to be a perfectly reasonable figure to me.
It's also broadly in line with the results at PhotonsToPhotos:
http://www.photonstophotos.net/Charts/Gain.htm#Canon%20EOS%201000D_12
Mark
« Last Edit: 2019 January 24 14:45:08 by sharkmelley »
