Hello folks,
I've been using Pixinsight for a while, and have a workflow that has been working well for me. Until the latest image that is. I am processing about 18 hours of the M77 region, imaged with a Takahashi FSQ 106ED. As usual, I used the batch preprocessing script with a super bias, fresh flats and dark frames. After the script calibrated, debayered, and registered the frames, I manually used ImageIntegration to integrate the 219x5m subs. The result is not good, as you can see from the attached screen shot. While it is nice and clean, and has great potential, the vignetting is terrible. The light strip at the bottom of the frame is a problem that I have always had using the Tak with the Canon 6D. I have not found a way to remove that strip with calibration, and have in the past reluctantly accepted that I have to crop it from the final image. But that I can live with, and it is nothing new. The really exaggerated vignetting is new though. It is almost as if the flats made the vignetting worse instead of removing it as usual. I use this scope and camera combination all the time and have never seen this before. The flats usually remove any minor vignetting completely. I am at a site in Arizona with a SQM of 21.5, and there should not be any serious gradients at this dark site.
There is a warning visible in the process console: Inconsistent observer values - metadata not generated. I have never seen this warning before. Can anyone tell me what this means?
A last mystery is the red (hydrogen?) arc in the lower left of the frame. I have not seen this in other images of this area.
Any advice much appreciated.
Dean
edit: I checked a sub before and after calibration, and sure enough, the flats are doing the job and removing the vignetting, and even the strip at the bottom of the frame that has long been a problem. See attached screenshot. So what is happening that the vignetting/gradients are being reintroduced to the image during integration?
