Author Topic: PixInsight 1.5.5 Released | PixInsight 1.5.5 Publicado  (Read 15353 times)
Offline William McLaughlin
    • Images from the Night Sky
Re: PixInsight 1.5.5 Released | PixInsight 1.5.5 Publicado
« Reply #15 on: 2009 July 16 10:13:19 »
I downloaded and installed the x64 windows version without trouble just now. Thanks for the quick update!
Hmm, I am still getting bad installer on the 64 bit as of now.
Website: http://nightskypictures.com/
Observatory: http://nightskypictures.com/raptor-ridge.html
For every complex problem there is an answer
that is clear, simple, and wrong.
H. L. Mencken
Offline Harry page
« Reply #16 on: 2009 July 16 12:24:03 »
Hi Juan
Still can not install the 64 bit win
Harry
Harry Page
Offline Stephane Murphy
« Reply #17 on: 2009 July 16 16:12:47 »
Harry, for now you can install the full package (PCL + Core) PCL-win-x86_64-01.00.70.0269-nsi-20090715-c.exe it is working for me.
Stephane
Stephane Murphy
CDK 12.5 Planewave Instrument
Paramount ME
SBIG STL11000M
SBIG ST-402 Guider
Astrodon MOAG
Astrodon Filters
« Reply #18 on: 2009 July 16 16:55:29 »
Hi again,
All packages are now uploaded and correct, except the PCL installation archive for Mac OS X, which I am uploaded now for the third time... The core OS X application package is valid though, so this isn't a big problem for now. Besides that, all Windows and Linux packages have been verified and can be downloaded and installed without any problem.
Sorry again for the inconveniences. I hope this will never happen again in future releases.
« Reply #19 on: 2009 July 16 17:22:35 »
Hi Philippe,
Thank you! ;)
When do you believe you will release a 64bits version for OSX ?   Maybe you prefer wait for Snow Leopard ?
To be honest, I have no idea. The *only* problem is Qt 4.5.2 (http://qtsoftware.com/). As you probably know, PixInsight's GUI is based on the Qt library. Qt 4.5 is the first version supporting 64-bit Cocoa-based development on Mac OS X. Now the problem is that Qt 4.5 (even the latest 4.5.2 version) is so plagued by bugs that PixInsight is just unusable when compiled against it.
The same *exact* code works like a charm when compiled with Qt 4.4.3, which is the current version I'm using on the Mac. Unfortunately, Qt 4.4.3 is only available as a 32-bit Carbon-based framework on Mac OS X. Interestingly, the same *exact* code works wonderfully compiled against Qt 4.5.2 on Windows and Linux, both as 32-bit and 64-bit builds.
So I am completely stuck with Qt for Mac OS X. Of course I've contacted Qt Software (= Nokia) support. The problem is that they need to see a piece of working code that reproduces the problem, but PixInsight is so complex that writing such a test program is something I just can't afford right now. All Qt 4.5.2 example programs work fine as 64-bit builds on the Mac, but PixInsight is a complete disaster.
I can basically do one of the following:
a) Wait until the Qt guys eventually fix the problem(s) that are currently preventing PI from working on the Mac with Qt 4.5.
b) Stop my development and video production work completely and try to generate a "simple" test program that reproduces exactly what is happening with the PixInsight core application and Qt 4.5.2.
For now, I'm trying to convince myself that option a) is the way to go :) Of course, that isn't true, I know that, everybody knows that. Welcome to the wonderful world of multiplatform development  ;D
So I ask for patience while I try to find a reasonable solution. I really hate this situation, especially because everything is ready to go 64-bit on the Mac except Qt.
What I want to state clear is that Qt is a wonderful multiplatform development framework (the best one without doubt, IMO). This is just a stone in the road but PI and Qt definitely walk together.
Offline mmirot
« Reply #20 on: 2009 July 18 20:27:26 »
You might check again. I can get either 64 bit version to install on my system.  I get a "error opening file for writing" for all modules
32 bit installs ok
Max
« Reply #21 on: 2009 July 19 00:27:07 »
Hi Max,
I've just downloaded and installed the 64-bit commercial version for Windows, and it works without problems.
Are you sure you have enough permissions to install 64-bit programs for your Windows user account? To install PixInsight, you need administrative privileges. Once you've installed, of course you don't need them to run the core application.
