Author Topic: PixInsight 1.5.5 Released | PixInsight 1.5.5 Publicado  (Read 15793 times)
[Versión en Español disponible en breve]
Hi all,
PixInsight 1.5.5 is now available for Linux, Mac OS X and Windows.
This is a bug fix / optimization release, but it also contains some new tools and important improvements.
Download Addresses
PixInsight 1.5.5 is now available for download from our file servers:
* For commercial users (user name and password required):
      http://dist.pixinsight.com/
* For users of 30-day trial licenses:
      http://pixinsight.com/download/STD/
Preserving User Preferences and Settings
Before uninstalling your current version of PixInsight, you should be aware that due to some important changes, PixInsight 1.5.5 requires a full reset of all platform settings and user preferences. This will happen automatically the first time you launch the new core application. If you have customized your preferences in a significant way, you may want to save a Preferences process icon that you can run on the new version to recover most of your current settings. Otherwise you'll need to reconfigure PixInsight manually. We apologize for the inconveniences.
However, if you save your preferences as a .psm file to restore them later, we suggest that you try out the new default settings in PixInsight 1.5.5 first.
Installation
We encourage you to update your current installation as soon as possible. Before installing PixInsight 1.5.5, it is advisable to uninstall a previous version. This is the recommended procedure:
Linux
   1. Exit all running instances of the PixInsight core application, if any.
   2. Delete the whole directory where a previous version of PixInsight was installed. If you have created files of your own within PixInsight's installation directory, please don't forget to backup them first.
   3. Unpack the .tar.gz file on a suitable directory, preferably one under the user's personal directory (for example, $HOME/PixInsight).
   4. To launch PixInsight, run the PixInsight.sh shell script on the bin installation directory.
Mac OS X
   2. Delete the previous version of the PixInsight.app application bundle. If you installed it on the standard location, it should be on the /Applications folder.
   3. Double click the .zip installation archive for version 1.5.5. This will create a new PixInsight.app application bundle. PixInsight can be executed from any location, but we recommend copying PixInsight.app to the standard /Applications folder. You may want to add it to the Dock as well.
   4. If you are a commercial Windows or Linux user, your existing license file works fine on the Mac; you do not need to reactivate your license. Do the following:
      4.1 Locate your PixInsight license file. It is the .pixinsight-license file on your personal folder of your Linux or Windows machine.
      4.2 Make a duplicate of .pixinsight-license, and rename it to pixinsight-license (that is, the same name but without a starting dot character).
      4.3 Copy the pixinsight-license file to your home folder on the Mac. Now you can run PixInsight for Mac OS X with your commercial license.
Windows
   2. Uninstall PixInsight. There is a Start > PixInsight Platform > Uninstall menu item that should be used. Never try to uninstall PixInsight by manually removing files. If you have created files of your own within PixInsight's installation directory, please don't forget to backup them first.
   3. Run the PixInsight installation module for version 1.5.5.
   4. To launch PixInsight, go to Start > PixInsight Platform > PixInsight Core.
Bug Fixes
Version 1.5.5 fixes all confirmed bugs and regressions as of the date of release. Please refer to the Bug Reports board of this forum.
New Tools and Features
Please refer to the Release Information board on this forum, where we'll be providing detailed descriptions and practical usage examples of all new features and improvements during the next days. Also stay tuned with our video tutorials collection because we'll be authoring new videos during this Summer.
As a brief summary, PixInsight 1.5.5 comes with the following main changes and improvements:
- Completely redesigned and rewritten screen rendering engine. New fast rendering mode.
- New mask rendering modes, including eight color overlay modes and a mask replacement mode, along with the traditional mask multiplication mode that has always been used to render masks in PixInsight since the first LE version.
- Important changes to the ImageIntegration process. Implementation of a new noise evaluation algorithm based on the multiresolution support (Starck et al., 1998, 2002). New image normalization modes for pixel rejection. Improved file cache management and Winsorized sigma clipping rejection.
- Important changes to the StarAlignment process. Improved star detection engine. Improved RANSAC implementation for rejection of false putative star pair matches. New preview operation mode for mosaic construction.
- New scripts available: Batch CMYG deBayer utility by Niall Saunders, Deconvolution Preview by Juan Manuel Gómez, and MathTran Client by Juan Conejero.
- New command-line commands available in the core PixInsight application: echo, set, dedicated.
- New script preprocessor directives: #ifoneof, #ifnoneof
- Important boost to the PixInsight JavaScript Runtime (PJSR) development framework. New native JavaScript objects: Cursor, Matrix, Vector, FileTransfer, FileDownload and FileUpload. New objects implemented as pure JavaScript code: ColorComboBox and SimpleColorDialog. New automatic garbage collector. Important new methods of the Math object for basic linear algebra operations (SVD, Gauss-Jordan solvers) and generation of Gaussian and linear filter distributions. Lots of new features added to the Global, Image, Settings, Graphics and Font native objects.
- Important changes to the PixInsight Class Library (PCL) C++ development framework. New MIME type support for image file formats (changes to all file format related classes). New member functions of the ImageWindow and Bitmap classes to implement access to the new mask rendering modes and fast bitmap/screen rendering engine.
- New thread priority scheduling policy that avoids exhausting system resources on Windows.
Note for Developers
PixInsight 1.5.5 introduces important changes to the low-level C API for modules (new API interface version 0x118). All modules built with previous versions of the PCL require full recompilation and linkage against PCL 1.0.70.
I hope you'll like it. Have fun!
Re: PixInsight 1.5.5 Released | PixInsight 1.5.5 Publicado
« Reply #1 on: 2009 July 16 04:27:51 »
Hi Juan,
Once again, thanks for your tireless efforts !!
Now, whilst you are 'resting' between PI releases, is there anything you can do about the weather? !!
« Reply #2 on: 2009 July 16 04:33:27 »
Hi Niall,
Thanks!
Oh yes, I can sing a little. Do you want some additional rain?  ;D
Offline h0ughy
« Reply #3 on: 2009 July 16 04:55:13 »
look forward to using it, thanks for the updates
Doghouse Observatory
Offline Stephane Murphy
« Reply #4 on: 2009 July 16 05:01:55 »
Hi Juan, throught the windows control panel, I uninstalled my previous version. I downloaded the latest bits (PI-win-x86_64-01.05.05.0521-nsi-20090715-c.exe) but I cannot run the executable.
I am getting an error:
Installer Integrity check has failed. Common causes include incomplete download or damaged media. Contact the installer author to obtain a new copy.
Any idea?
Stephane Murphy
CDK 12.5 Planewave Instrument
Paramount ME
SBIG STL11000M
SBIG ST-402 Guider
Astrodon MOAG
Astrodon Filters
Offline eddiet
    • http://astroshed.com
« Reply #5 on: 2009 July 16 05:04:37 »
Hi to all,
May I echo the sentiments on your tireless efforts Juan! Well done!
May I also echo the error mentioned by Stephane regarding the 64-bit class library executable...
The same error also occurs with the 64-bit Pixinsight core archive...
Thanks again!
Eddie T.
« Reply #6 on: 2009 July 16 05:20:25 »
Juan I am also getting the same error for PCL-win-x86_64-01.00.70.0269-nsi-20090715-c.exe
Stephane
Stephane Murphy
Paramount ME
SBIG STL11000M
SBIG ST-402 Guider
Astrodon MOAG
Astrodon Filters
Offline Philippe B.
    • CIEL AUSTRAL
« Reply #7 on: 2009 July 16 05:41:43 »
Hi Juan,
same for me  PCL win 32
Could you check ?
Thanks !!!
Philippe
« Reply #8 on: 2009 July 16 05:43:00 »
Stephane
Same.
« Reply #9 on: 2009 July 16 07:23:01 »
Hi all,
Thanks to everyone for your nice words.
For some weird reason, six installation archives have been damaged during the ftp upload process. This is the first time I have this problem. I must verify also the trial versions since there can be also damaged files, but at least the Windows trial installation archives are OK.
Right now the following (correct) file is available:
I'll upload the rest of damaged files later this afternoon. Thank you for your patience!
Offline Philippe B.
    • CIEL AUSTRAL
« Reply #10 on: 2009 July 16 07:53:18 »
Don't worry Juan, you are still the best  :laugh:
Thanks for your quick reply  ;)
cheers,
philippe
« Last Edit: 2009 July 16 08:30:25 by CCD1024 »
« Reply #11 on: 2009 July 16 07:58:34 »
Ahh, so there IS an advantage to being stuck in the office all day - I can get YOU guys to iron the bugs out for me !!
Looking forward to gettingback home though . . .
« Reply #12 on: 2009 July 16 08:32:31 »
I downloaded and installed the x64 windows version without trouble just now. Thanks for the quick update!
« Reply #13 on: 2009 July 16 09:43:03 »
Nice work Juan, I like the new mask mode.
Stephane
Stephane Murphy
Paramount ME
SBIG STL11000M
SBIG ST-402 Guider
Astrodon MOAG
Astrodon Filters
Offline Philippe B.
    • CIEL AUSTRAL
« Reply #14 on: 2009 July 16 10:11:21 »
Juan,
Also the OSX version are damaged.
Another question :
When do you believe you will release a 64bits version for OSX ?   Maybe you prefer wait for Snow Leopard ?
Cheers
Philippe
