Author Topic: Setting default properties for xisf file type  (Read 1415 times)
Offline dchamberlain
« on: 2019 January 02 15:25:24 »
Is there a way to have every time I save an xisf file to always have clicked "Image Properties" in XISF options?
Offline Cosmick
Re: Setting default properties for xisf file type
« Reply #1 on: 2019 January 03 00:11:50 »
Under Global Preferences > File I/O Settings
Clear Skies
Mick
« Reply #2 on: 2019 January 03 12:17:35 »
Except it doesn't enable "Image Properties" in XISF Options. I can't seem to find a way to have that set all the time.
« Reply #3 on: 2019 January 03 12:30:04 »
The first image is the Global Preferences>File I/O Settings. The second is the dialog box during the save of an XISF file. Note the "Image Properties" is unchecked even though I would think it should be checked because "Enable embedding of image properties by default" is checked in the File I/O Settings.
« Reply #4 on: 2019 January 04 12:49:42 »
Should this be reported as a bug?
« Reply #5 on: 2019 January 04 13:28:34 »
To modify default settings for the XISF format:
- Open the Format Explorer window. If it isn't already docked on the left side, select View > Explorer Windows > Format Explorer from the main menu.
- Activate (e.g., double click) the XISF item on the left panel.
- On the XISF Format Preferences window, change settings as desired; then click OK.
Note that the same can be done for any format support module that provides a preferences interface. This currently includes XISF, TIFF, RAW, JPEG, JPC, JP2, and FITS.
« Reply #6 on: 2019 January 04 20:06:51 »
Thank you Juan!
That is exactly what I was looking for!
Dale
