Author Topic: Panels stuck on primary monitor  (Read 926 times)
Offline mr1337
« on: 2018 December 13 14:11:33 »
Currently I can't have the Pixinsight app running from a secondary monitor hooked up to my laptop. The second monitor is positioned above my laptop screen and the primary app can be dragged to the top monitor but all dialog boxes are locked into the primary monitor.
Noticed this is similar to a previous post from 2013: https://pixinsight.com/forum/index.php?topic=5710.msg39062#msg39062
Any known fixes for that?
Offline RickS
Re: Panels stuck on primary monitor
« Reply #1 on: 2018 December 13 16:13:47 »
I have side-by-side monitors and I can drag dialogs as well as the main window back and forward.
Offline mr1337
« Reply #2 on: 2018 December 13 17:01:34 »
Correct, it works as expected for me too if the  monitors are side by side. It is if they are stacked that I have the problem.
Offline mr1337
« Reply #4 on: 2018 December 17 09:35:22 »
Thanks! I actually am running the monitors in horizontal orientation one over the other though, not vertical.
Offline Rainer
« Reply #5 on: 2018 December 17 10:31:13 »
Stacked in vertical mode does not mean the monitors are in vertical mode, it means they are stacked vertically one over the other.
Monitors which are able to work in vertical mode are not that common :-)
Have you tried in the display setting to drag the top monitor over the lower monitor ?
Well I thought it cloud help. IMHO
Offline mr1337
« Reply #6 on: 2018 December 17 11:41:00 »
Correct, it works fine when one monitor is next to the other. The problem is when I drag one over the other that the problem arises. I have it dragged to the side now, which is weird when I want a panel to go to the secondary monitor since I have to drag it sideways instead of straight up.
