When running the BPP script and you have the image integration box checked the final image is never left open on the desktop ,
the final result is saved in the masters file .
it is only if you run the intergration process on its own will the image be left open on the desktop
Regards
Harry
Hi Harry,
Thanks. Well I had the imporession running BPP it did leave it open but again thanks for clarifying this. In the meantime I did find it
Also after changing the Global Preferences so far I have had no problem again. Will keep testing it.
I am not sure about File Cache as far as I have been disabling it when using ImageIntegration process only.
Thanks to all who helped me getting rid of the " PCL Win32 System exception "
rainer
