Author Topic: Error in SubframeSelector ?  (Read 923 times)
Offline Denjnie
« on: 2018 November 26 09:48:35 »
I wanted to recalculate the weights from subframeselector for a selection of subframes taken over several nights.
Therefore I ran the script on an existing directory with weighted subframes with postfix's _a.
The "measure" routine went fine.
For the "output subframe" routine, I blanked the postfix option, checked the "overwrite existing files" and ran the script on the same input- and output directory.
The result was a bunch of errors witch corrupted all my subframes - now not recognizable as valid FITS files:
*** Error: PCL Legacy FITS Format Support: Unable to open FITS file: /Users/Jens/Pictures/Astrofoto_Imac/ASI1600MM/NGC281/Approved/NGC281_Blue_30sec_2018-11-25_0001_a.fit
CFITSIO error message stack:
01 : Extension doesn't start with SIMPLE or XTENSION keyword. (ffrhdu)
02 : END
03 : ffopen could not interpret primary array header of file:
04 : /Users/Jens/Pictures/Astrofoto_Imac/ASI1600MM/NGC281/Approved/NGC281_Blue_30sec_
05 : 2018-11-25_0001_a.fit
06 : This does not look like a FITS file.
*** Unable to open file: /Users/Jens/Pictures/Astrofoto_Imac/ASI1600MM/NGC281/Approved/NGC281_Blue_30sec_2018-11-25_0001_a.fit
<* failed *>
The FITS tester gives the following error:
File name:  NGC281_Green_30sec_2018-11-25_0012_a.fit
                                           Run Number 23796
              fitsverify 4.18 (CFITSIO V3.440)
*** Error:   (from CFITSIO error stack:)
             Couldn't find the string 'SIMPLE' in the stdin stream.
             failed to copy stdin into memory (stdin_open)
             failed to find or open the following file: (ffopen)
**** Abort Verification: Fatal Error. ****
Pls help me correct my files  :-\ - I'm running Pixinsight under MacOS
I've uploaded an example here:
https://www.dropbox.com/s/e5cyqrc7tffty62/NGC281_Ha_500sec_2018-10-25_0001_a.fit?dl=0
Offline cameronleger
    • Blog
Re: Error in SubframeSelector ?
« Reply #1 on: 2018 December 19 11:05:56 »
It's very unfortunate that your data is corrupted, but that is always the risk with overwriting files. The Subframe Selector does not support overwriting the input files; I think on Windows it would complain about writing to a locked file and not do anything, but it looks like on OS X it will try it anyway and trash the files.
I'll look into preventing this from happening.
Offline pellereau.jc
« Reply #2 on: 2018 December 26 03:04:15 »
bonjour
la nouvelle version de subframe selector me donne weight ?
que faire
« Reply #3 on: 2018 December 26 03:05:45 »
non pas weight ? mais weight 0
