Author Topic: PIX update does not work correctly  (Read 1210 times)
Offline mk95
  • -Milan-
« on: 2018 November 22 00:42:36 »
Hello, When I install a new clean PIX and then click on the PIX image file or PIX icon file, PIX will start and open the corresponding file. As soon as I update the PIX and click on the mentioned PIX files, the system requires an additional installation and looks for *.msi PIX package (DISK1), which of course does not exist. I tried to uninstall PIX completely, to clean PIX registers (PIX records), but it did not help. What with this? Thanks. Milan
Milan
Offline RickS
Re: PIX update does not work correctly
« Reply #1 on: 2018 November 22 01:57:21 »
Hi Milan,
Since you mention .msi files I assume you are running on Windows.  Can you still start PixInsight from the Start menu and then open image files, etc?  I presume you can and that the only issue is with what Windows does when you click on a file associated with the PixInsight application.  Is that correct?
Rick.
Offline mk95
  • -Milan-
« Reply #2 on: 2018 November 22 07:03:24 »
Hi Rick,
yes I work with win version (WIN10/64).
Standard way is possible and OK. I can start PIX and load icons and open any  (PIX) image. But ...
1. Clicking on the icon is more convenient, especially for a project or a process icons file
2. Something is wrong
Milan
Milan
Offline RickS
« Reply #3 on: 2018 November 22 21:18:59 »
Hi Milan,
That behaviour is controlled by Windows settings, not the PixInsight application.  I have seen it happen before but can't currently replicate the problem (I'm running a test version of PI 1.8.6.)
I agree it's an inconvenience, but a pretty minor one IMO.
Rick.
Offline mk95
  • -Milan-
« Reply #4 on: 2018 November 25 10:41:14 »
Hi Rick,
OK and thanks.
BTW is there an update on the horizon?
Milan
Milan
« Reply #5 on: 2018 November 25 13:27:08 »
Just on the horizon and rising ;)
Offline mk95
  • -Milan-
« Reply #6 on: 2018 December 17 12:55:05 »
New version works! No problems after installing updates.
Perfect work.
Milan
Milan
