Author Topic: Merging and copying between projects  (Read 1647 times)
Offline ChrisFC
« on: 2018 November 17 03:16:22 »
I have several projects that do different parts of pre processing and processing. I change them occassionally. Is there a way to copy processes between different projects?
Thanks Chris
Offline oldwexi
    • Astronomy Pages G.W.
Re: Merging and copying between projects
« Reply #1 on: 2018 November 17 11:59:50 »
Hi Chris!
I open e second instance of PI.
!!PixInsight -n
(in the commandline of PI (1))
In the first instance of PI i select all the processes i want to copy,
and save them  in a fast accessible directory under name "z".
Than i open file Explorer and drag and drop (!!!)  z.xpsm
into the second instance of PI.
And all processes of instance 1 of PI are now available also in instance 2 of PI.
Maybe there is a faster approach - but for me, an old old guy, its fast enough..
Gerald
Offline STEVE333
    • sk-images
« Reply #2 on: 2018 November 17 12:21:19 »
Hi Chris -
Another possibility is to highlight the process icons you wish to transfer and then right-click on the workspace, select
     Process Icons/Save Process Icons.... Save the icons with the name z.xpsm.
Open the second project, right-click on the workspace, select Process Icons/Load Process Icons.... Double click on the z.xpsm file and, voila, there are the process icons with all the same settings.
Hope this helps.
Camera:  Canon T3 (modified)
Mount:  CEM40 EC
Offline ChrisFC
« Reply #3 on: 2018 November 21 04:05:09 »
Thanks all. Worked a treat
