Author Topic: Red Spots  (Read 1758 times)
Offline Farzad_k
Red Spots
« on: 2018 November 11 14:18:56 »
Hello.
The attached is a simple snapshot of an RGB combined. The red halos are actually star objects. I have processed this in BPP. Why should these particular stars look this way? The subs ar 120 seconds each, and 15 subs each channel.
Thanks for any ideas.
Farzad
Re: Red Spots
« Reply #1 on: 2018 November 11 16:35:12 »
did you use MaskedStretch or ArcsinhStretch?
Offline Farzad_k
Re: Red Spots
« Reply #2 on: 2018 November 11 16:37:31 »
No I didn't. But just a minute ago I found a discussion on PI about the same issue and apparently the culprit is if the Chrominance noise reduction is enabled at LRGB combination. I deselected that and it worked.
Thanks for replying.
Farzad
Re: Red Spots
« Reply #3 on: 2018 November 11 19:11:55 »
Farzad
Are you using LRGBCOmbination on stretched or linear images. The tool is not designed to work with linear images if you are. Here is a posting about that.
https://pixinsight.com/forum/index.php?topic=2485.0
Offline Farzad_k
Re: Red Spots
« Reply #4 on: 2018 November 11 19:15:50 »
Mike,
LRGB combination happens on nonlinear images. I have already figured out that I need to deselect chrominance noise reduction when I do L+RGB combination and it has now been working for me. Thanks.
