Author Topic: metadata not generated  (Read 2507 times)
Offline fayegaubert
« on: 2018 October 28 02:38:37 »
Hello,
What does "Warning: Inconsistent filter name value (s) - metadata not generated." and how to fix it
Thanks for your help
Re: metadata not generated
« Reply #1 on: 2018 October 28 03:02:02 »
Fitst, are you actually using filters on a monochrome imager? If you are, then you next need to consider whether your image acquisition software is either naming the filtered images appropriately, or if it is storing different data sets in different folders, and also whether the filter being used is being correctly described and stored in the FITS header file.
Only if the images have a decipherable description can PixInsight then understand, auto-magically, which images were collected by which filter. If PI cannot do that, then it has no choice but to give up.
However, please bear in mind that I use an OSC imager, and that I have not worked with anything else for several years now - so others may have a better understanding of what, exactly, is causing your messages.
In the meantime, I hope this helps.
Offline fayegaubert
« Reply #2 on: 2018 October 28 04:52:23 »
thank you for your reply.
I use a monochrome sensor and the filters are correctly named in the header fits. Does this affect the image obtained?
thank you
christian
