Author Topic: Preprocessing integration error  (Read 3267 times)
Offline basskep
« on: 2018 October 21 04:14:49 »
I am currently facing an issue with preprocessing registration and integration. Either manually or with BatchPreprocessing script.
You will find the logs and screenshots in attachment.
Offline basskep
Re: Preprocessing integration error
« Reply #1 on: 2018 October 21 04:21:21 »
You will find logs here :
Process:               PixInsight [2429]
Path:                  /Applications/PixInsight/PixInsight.app/Contents/MacOS/PixInsight
Identifier:            software.pleiades.PixInsight
Version:               1.8.5.1352 (1.8.5.1352)
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           PixInsight [2429]
User ID:               501
Date/Time:             2018-10-18 00:54:38.685 +0200
OS Version:            Mac OS X 10.12.6 (16G1212)
Report Version:        12
Anonymous UUID:        67E15640-C021-D9E4-4D1D-63CF40E80E89
Time Awake Since Boot: 15000 seconds
System Integrity Protection: enabled
Crashed Thread:        25  pi::APIThread
Exception Type:        EXC_BAD_ACCESS (SIGABRT)
Exception Codes:       KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
VM Regions Near 0:
    __TEXT                 0000000108380000-00000001097f3000 [ 20.4M] r-x/rwx SM=COW  /Applications/PixInsight/PixInsight.app/Contents/MacOS/PixInsight
Application Specific Information:
abort() called
terminating with uncaught exception of type pcl::EUnixSegmentationViolation
Thread 0:: CrBrowserMain  Dispatch queue: com.apple.main-thread
0   libsystem_kernel.dylib           0x00007fffd3afabf2 __psynch_cvwait + 10
1   libsystem_pthread.dylib          0x00007fffd3be67fa _pthread_cond_wait + 712
2   org.qt-project.QtCore            0x00000001109bcf00 0x110991000 + 179968
3   org.qt-project.QtCore            0x00000001109bcc4b 0x110991000 + 179275
4   org.qt-project.QtCore            0x00000001109bcc02 QWaitCondition::wait(QMutex*, unsigned long) + 162
5   org.qt-project.QtCore            0x00000001109bc3be QThread::wait(unsigned long) + 110
6   software.pleiades.PixInsight     0x000000010848c187 0x108380000 + 1098119
7   ImageIntegration-pxm.dylib       0x000000013246307c pcl::Thread::Wait(unsigned int) + 28
8   ImageIntegration-pxm.dylib       0x00000001322092bb void pcl::AbstractImage::RunThreads<pcl::RejectionMapGenerationEngine::GenerationThread>(pcl::ReferenceArray<pcl::RejectionMapGenerationEngine::GenerationThread, pcl::StandardAllocator>&, pcl::AbstractImage::ThreadData&, bool) + 443
9   ImageIntegration-pxm.dylib       0x00000001321e863b pcl::ImageIntegrationInstance::ExecuteGlobal() + 13291
10  ImageIntegration-pxm.dylib       0x000000013233ab67 pcl::ProcessContextDispatcher::ExecuteProcessGlobal(void*) + 71
11  software.pleiades.PixInsight     0x000000010902618a 0x108380000 + 13263242
12  software.pleiades.PixInsight     0x0000000109047955 0x108380000 + 13400405
13  software.pleiades.PixInsight     0x0000000108406288 0x108380000 + 549512
14  ImageIntegration-pxm.dylib       0x000000013240581d pcl::InterfaceDispatcher::ApplyInstanceGlobal(void*) + 29
15  software.pleiades.PixInsight     0x000000010907baf8 0x108380000 + 13613816
16  org.qt-project.QtCore            0x0000000110bc0ab9 QMetaObject::activate(QObject*, int, int, void**) + 3113
17  org.qt-project.QtWidgets         0x000000010fe8e3c0 0x10fca3000 + 2012096
18  org.qt-project.QtWidgets         0x000000010fe8e250 0x10fca3000 + 2011728
19  org.qt-project.QtWidgets         0x000000010fe8f2c0 QAbstractButton::mouseReleaseEvent(QMouseEvent*) + 272
20  org.qt-project.QtWidgets         0x000000010fe6ab6f QToolButton::mouseReleaseEvent(QMouseEvent*) + 15
21  org.qt-project.QtWidgets         0x000000010fcf003b QWidget::event(QEvent*) + 603
22  org.qt-project.QtWidgets         0x000000010fe8f020 QAbstractButton::event(QEvent*) + 160
23  org.qt-project.QtWidgets         0x000000010fe6b135 QToolButton::event(QEvent*) + 325
24  org.qt-project.QtWidgets         0x000000010fcb5abd QApplicationPrivate::notify_helper(QObject*, QEvent*) + 301
25  org.qt-project.QtWidgets         0x000000010fcb8a9f QApplication::notify(QObject*, QEvent*) + 7663
26  software.pleiades.PixInsight     0x00000001084ca166 0x108380000 + 1352038
27  org.qt-project.QtCore            0x0000000110b8f424 QCoreApplication::notifyInternal2(QObject*, QEvent*) + 164
28  org.qt-project.QtWidgets         0x000000010fcb63ea QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) + 874
29  org.qt-project.QtWidgets         0x000000010fd11206 0x10fca3000 + 451078
30  org.qt-project.QtWidgets         0x000000010fd10089 0x10fca3000 + 446601
31  org.qt-project.QtWidgets         0x000000010fcb5abd QApplicationPrivate::notify_helper(QObject*, QEvent*) + 301
32  org.qt-project.QtWidgets         0x000000010fcb6e37 QApplication::notify(QObject*, QEvent*) + 391
33  software.pleiades.PixInsight     0x00000001084ca166 0x108380000 + 1352038
34  org.qt-project.QtCore            0x0000000110b8f424 QCoreApplication::notifyInternal2(QObject*, QEvent*) + 164
35  org.qt-project.QtGui             0x00000001102c5eac QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) + 3068
36  org.qt-project.QtGui             0x00000001102ace5b QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 155
37  libqcocoa.dylib                  0x000000011433f0f1 0x114317000 + 164081
38  com.apple.CoreFoundation         0x00007fffbe265321 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17
39  com.apple.CoreFoundation         0x00007fffbe24621d __CFRunLoopDoSources0 + 557
40  com.apple.CoreFoundation         0x00007fffbe245716 __CFRunLoopRun + 934
41  com.apple.CoreFoundation         0x00007fffbe245114 CFRunLoopRunSpecific + 420
42  com.apple.HIToolbox              0x00007fffbd7a5ebc RunCurrentEventLoopInMode + 240
43  com.apple.HIToolbox              0x00007fffbd7a5bf9 ReceiveNextEventCommon + 184
44  com.apple.HIToolbox              0x00007fffbd7a5b26 _BlockUntilNextEventMatchingListInModeWithFilter + 71
45  com.apple.AppKit                 0x00007fffbbd3ca54 _DPSNextEvent + 1120
46  com.apple.AppKit                 0x00007fffbc4b87ee -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 2796
47  com.apple.AppKit                 0x00007fffbbd313db -[NSApplication run] + 926
48  libqcocoa.dylib                  0x000000011433de33 0x114317000 + 159283
49  org.qt-project.QtCore            0x0000000110b8b0d1 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 417
50  org.qt-project.QtCore            0x0000000110b8fa97 QCoreApplication::exec() + 343
51  software.pleiades.PixInsight     0x00000001084db826 0x108380000 + 1423398
52  libdyld.dylib                    0x00007fffd39cc235 start + 1
Thread 1:: pi::PixInsightWatchDog
0   libsystem_kernel.dylib           0x00007fffd3afaf46 __semwait_signal + 10
1   libsystem_c.dylib                0x00007fffd3a81b72 nanosleep + 199
2   org.qt-project.QtCore            0x0000000110be29ab 0x110991000 + 2431403
3   software.pleiades.PixInsight     0x00000001084d3cfb 0x108380000 + 1391867
4   org.qt-project.QtCore            0x00000001109bb6af 0x110991000 + 173743
5   libsystem_pthread.dylib          0x00007fffd3be593b _pthread_body + 180
6   libsystem_pthread.dylib          0x00007fffd3be5887 _pthread_start + 286
7   libsystem_pthread.dylib          0x00007fffd3be508d thread_start + 13
Thread 2:: NetworkConfigWatcher
0   libsystem_kernel.dylib           0x00007fffd3afc19e poll + 10
1   org.qt-project.QtCore            0x0000000110be2fc0 qt_safe_poll(pollfd*, unsigned int, timespec const*) + 544
2   org.qt-project.QtCore            0x0000000110be4657 QEventDispatcherUNIX::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 871
3   org.qt-project.QtCore            0x0000000110b8b0d1 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 417
4   org.qt-project.Qt.QtWebEngineCore   0x000000010a46e1da 0x10a44c000 + 139738
5   org.qt-project.Qt.QtWebEngineCore   0x000000010b0ac94e 0x10a44c000 + 12978510
6   org.qt-project.Qt.QtWebEngineCore   0x000000010b0d1161 0x10a44c000 + 13128033
7   org.qt-project.Qt.QtWebEngineCore   0x000000010b1062e0 0x10a44c000 + 13345504
8   org.qt-project.Qt.QtWebEngineCore   0x000000010b0ff2e7 0x10a44c000 + 13316839
9   libsystem_pthread.dylib          0x00007fffd3be593b _pthread_body + 180
10  libsystem_pthread.dylib          0x00007fffd3be5887 _pthread_start + 286
11  libsystem_pthread.dylib          0x00007fffd3be508d thread_start + 13
Thread 3:: DnsConfigService
0   libsystem_kernel.dylib           0x00007fffd3afbd96 kevent + 10
1   org.qt-project.Qt.QtWebEngineCore   0x000000010b5183e7 0x10a44c000 + 17613799
2   org.qt-project.Qt.QtWebEngineCore   0x000000010b5156ad 0x10a44c000 + 17602221
3   org.qt-project.Qt.QtWebEngineCore   0x000000010b0af1a1 0x10a44c000 + 12988833
4   org.qt-project.Qt.QtWebEngineCore   0x000000010b0ac94e 0x10a44c000 + 12978510
5   org.qt-project.Qt.QtWebEngineCore   0x000000010b0d1161 0x10a44c000 + 13128033
6   org.qt-project.Qt.QtWebEngineCore   0x000000010b1062e0 0x10a44c000 + 13345504
7   org.qt-project.Qt.QtWebEngineCore   0x000000010b0ff2e7 0x10a44c000 + 13316839
8   libsystem_pthread.dylib          0x00007fffd3be593b _pthread_body + 180
9   libsystem_pthread.dylib          0x00007fffd3be5887 _pthread_start + 286
10  libsystem_pthread.dylib          0x00007fffd3be508d thread_start + 13
Thread 4:: Chrome_DBThread
0   libsystem_kernel.dylib           0x00007fffd3af334a mach_msg_trap + 10
1   libsystem_kernel.dylib           0x00007fffd3af2797 mach_msg + 55
2   com.apple.CoreFoundation         0x00007fffbe246434 __CFRunLoopServiceMachPort + 212
3   com.apple.CoreFoundation         0x00007fffbe2458c1 __CFRunLoopRun + 1361
4   com.apple.CoreFoundation         0x00007fffbe245114 CFRunLoopRunSpecific + 420
5   org.qt-project.Qt.QtWebEngineCore   0x000000010b0b011f 0x10a44c000 + 12992799
6   org.qt-project.Qt.QtWebEngineCore   0x000000010b0afab4 0x10a44c000 + 12991156
7   org.qt-project.Qt.QtWebEngineCore   0x000000010b0ac94e 0x10a44c000 + 12978510
8   org.qt-project.Qt.QtWebEngineCore   0x000000010b0d1161 0x10a44c000 + 13128033
9   org.qt-project.Qt.QtWebEngineCore   0x000000010a742eb8 0x10a44c000 + 3108536
10  org.qt-project.Qt.QtWebEngineCore   0x000000010a74327c 0x10a44c000 + 3109500
11  org.qt-project.Qt.QtWebEngineCore   0x000000010b1062e0 0x10a44c000 + 13345504
12  org.qt-project.Qt.QtWebEngineCore   0x000000010b0ff2e7 0x10a44c000 + 13316839
13  libsystem_pthread.dylib          0x00007fffd3be593b _pthread_body + 180
14  libsystem_pthread.dylib          0x00007fffd3be5887 _pthread_start + 286
15  libsystem_pthread.dylib          0x00007fffd3be508d thread_start + 13
Thread 5:: Chrome_FileThread
6   org.qt-project.Qt.QtWebEngineCore   0x000000010a742f38 0x10a44c000 + 3108664
7   org.qt-project.Qt.QtWebEngineCore   0x000000010a74328c 0x10a44c000 + 3109516
8   org.qt-project.Qt.QtWebEngineCore   0x000000010b1062e0 0x10a44c000 + 13345504
9   org.qt-project.Qt.QtWebEngineCore   0x000000010b0ff2e7 0x10a44c000 + 13316839
10  libsystem_pthread.dylib          0x00007fffd3be593b _pthread_body + 180
11  libsystem_pthread.dylib          0x00007fffd3be5887 _pthread_start + 286
12  libsystem_pthread.dylib          0x00007fffd3be508d thread_start + 13
Thread 6:: Chrome_FileUserBlockingThread
9   org.qt-project.Qt.QtWebEngineCore   0x000000010a742fb8 0x10a44c000 + 3108792
10  org.qt-project.Qt.QtWebEngineCore   0x000000010a74329c 0x10a44c000 + 3109532
Thread 7:: Chrome_ProcessLauncherThread
9   org.qt-project.Qt.QtWebEngineCore   0x000000010a743038 0x10a44c000 + 3108920
10  org.qt-project.Qt.QtWebEngineCore   0x000000010a7432a9 0x10a44c000 + 3109545
Thread 8:: Chrome_CacheThread
9   org.qt-project.Qt.QtWebEngineCore   0x000000010a7430b8 0x10a44c000 + 3109048
10  org.qt-project.Qt.QtWebEngineCore   0x000000010a7432b6 0x10a44c000 + 3109558
Thread 9:: Chrome_IOThread
6   org.qt-project.Qt.QtWebEngineCore   0x000000010a743138 0x10a44c000 + 3109176
7   org.qt-project.Qt.QtWebEngineCore   0x000000010a7432c3 0x10a44c000 + 3109571
Thread 10:: BrowserBlockingWorker1/48387
2   org.qt-project.Qt.QtWebEngineCore   0x000000010b100881 0x10a44c000 + 13322369
3   org.qt-project.Qt.QtWebEngineCore   0x000000010b0fff66 0x10a44c000 + 13320038
4   org.qt-project.Qt.QtWebEngineCore   0x000000010b1040ad 0x10a44c000 + 13336749
5   org.qt-project.Qt.QtWebEngineCore   0x000000010b0ff2e7 0x10a44c000 + 13316839
6   libsystem_pthread.dylib          0x00007fffd3be593b _pthread_body + 180
7   libsystem_pthread.dylib          0x00007fffd3be5887 _pthread_start + 286
8   libsystem_pthread.dylib          0x00007fffd3be508d thread_start + 13
Thread 11:: IndexedDB
9   org.qt-project.Qt.QtWebEngineCore   0x000000010b1062e0 0x10a44c000 + 13345504
10  org.qt-project.Qt.QtWebEngineCore   0x000000010b0ff2e7 0x10a44c000 + 13316839
11  libsystem_pthread.dylib          0x00007fffd3be593b _pthread_body + 180
12  libsystem_pthread.dylib          0x00007fffd3be5887 _pthread_start + 286
13  libsystem_pthread.dylib          0x00007fffd3be508d thread_start + 13
Thread 12:: CompositorTileWorker1/50435
2   org.qt-project.Qt.QtWebEngineCore   0x000000010bccac28 0x10a44c000 + 25685032
3   org.qt-project.Qt.QtWebEngineCore   0x000000010b1040ad 0x10a44c000 + 13336749
4   org.qt-project.Qt.QtWebEngineCore   0x000000010b0ff2e7 0x10a44c000 + 13316839
Thread 13:: AudioThread
Thread 14:: Chrome_InProcGpuThread
Thread 15:: Chrome_ChildIOThread
Thread 16:: com.apple.NSEventThread
5   com.apple.AppKit                 0x00007fffbbe89f02 _NSEventThread + 205
Thread 17:: NetworkConfigWatcher
Thread 18:: BrowserBlockingWorker2/79619
Thread 19:: QFileInfoGatherer
2   org.qt-project.QtCore            0x00000001109bcc6b 0x110991000 + 179307
3   org.qt-project.QtCore            0x00000001109bcc02 QWaitCondition::wait(QMutex*, unsigned long) + 162
4   org.qt-project.QtWidgets         0x000000010fef6e72 QFileInfoGatherer::run() + 114
5   org.qt-project.QtCore            0x00000001109bb6af 0x110991000 + 173743
Thread 20:
0   libsystem_pthread.dylib          0x00007fffd3be5070 start_wqthread + 0
1   ???                              0x0000700009d2bbe0 0 + 123145467116512
Thread 21:: pi::APIThread
2   ImageIntegration-pxm.dylib       0x00000001324558dd pcl::MonitorDispatcherThread::Run() + 77
3   ImageIntegration-pxm.dylib       0x0000000132462f96 pcl::ThreadDispatcher::RunThread(void*) + 70
4   software.pleiades.PixInsight     0x000000010848b6cf 0x108380000 + 1095375
Thread 22:: pi::APIThread
0   libsystem_kernel.dylib           0x00007fffd3afad42 __pthread_kill + 10
1   libsystem_pthread.dylib          0x00007fffd3be8457 pthread_kill + 90
2   libsystem_c.dylib                0x00007fffd3a60420 abort + 129
3   libc++abi.dylib                  0x00007fffd25b494a abort_message + 266
4   libc++abi.dylib                  0x00007fffd25d9c2f default_terminate_handler() + 267
5   libobjc.A.dylib                  0x00007fffd30e8713 _objc_terminate() + 124
6   libc++abi.dylib                  0x00007fffd25d6d49 std::__terminate(void (*)()) + 8
7   libc++abi.dylib                  0x00007fffd25d7715 __cxxabiv1::call_terminate(bool, _Unwind_Exception*) + 35
8   libc++abi.dylib                  0x00007fffd25d7320 __cxxabiv1::scan_eh_tab(__cxxabiv1::(anonymous namespace)::scan_results&, _Unwind_Action, bool, _Unwind_Exception*, _Unwind_Context*) + 553
9   libc++abi.dylib                  0x00007fffd25d706e __gxx_personality_v0 + 174
10  libunwind.dylib                  0x00007fffd3c0f862 _Unwind_RaiseException + 162
11  libc++abi.dylib                  0x00007fffd25d67ad __cxa_throw + 104
12  software.pleiades.PixInsight     0x00000001093de40a 0x108380000 + 17163274
13  libsystem_platform.dylib         0x00007fffd3bdbb3a _sigtramp + 26
14  ???                              000000000000000000 0 + 0
15  ImageIntegration-pxm.dylib       0x0000000132462f96 pcl::ThreadDispatcher::RunThread(void*) + 70
16  software.pleiades.PixInsight     0x000000010848b6cf 0x108380000 + 1095375
17  org.qt-project.QtCore            0x00000001109bb6af 0x110991000 + 173743
18  libsystem_pthread.dylib          0x00007fffd3be593b _pthread_body + 180
19  libsystem_pthread.dylib          0x00007fffd3be5887 _pthread_start + 286
20  libsystem_pthread.dylib          0x00007fffd3be508d thread_start + 13
Thread 23:: pi::APIThread
0   libsystem_kernel.dylib           0x00007fffd3afaf5e __semwait_signal_nocancel + 10
1   libsystem_c.dylib                0x00007fffd3a08904 nanosleep$NOCANCEL + 188
2   libsystem_c.dylib                0x00007fffd3a31e9e usleep$NOCANCEL + 54
3   libsystem_c.dylib                0x00007fffd3a6042a abort + 139
4   libc++abi.dylib                  0x00007fffd25b494a abort_message + 266
5   libc++abi.dylib                  0x00007fffd25d9c2f default_terminate_handler() + 267
6   libobjc.A.dylib                  0x00007fffd30e8713 _objc_terminate() + 124
7   libc++abi.dylib                  0x00007fffd25d6d49 std::__terminate(void (*)()) + 8
8   libc++abi.dylib                  0x00007fffd25d7715 __cxxabiv1::call_terminate(bool, _Unwind_Exception*) + 35
9   libc++abi.dylib                  0x00007fffd25d7320 __cxxabiv1::scan_eh_tab(__cxxabiv1::(anonymous namespace)::scan_results&, _Unwind_Action, bool, _Unwind_Exception*, _Unwind_Context*) + 553
10  libc++abi.dylib                  0x00007fffd25d706e __gxx_personality_v0 + 174
11  libunwind.dylib                  0x00007fffd3c0f862 _Unwind_RaiseException + 162
12  libc++abi.dylib                  0x00007fffd25d67ad __cxa_throw + 104
13  software.pleiades.PixInsight     0x00000001093de40a 0x108380000 + 17163274
14  libsystem_platform.dylib         0x00007fffd3bdbb3a _sigtramp + 26
15  ???                              000000000000000000 0 + 0
16  ImageIntegration-pxm.dylib       0x0000000132462f96 pcl::ThreadDispatcher::RunThread(void*) + 70
17  software.pleiades.PixInsight     0x000000010848b6cf 0x108380000 + 1095375
18  org.qt-project.QtCore            0x00000001109bb6af 0x110991000 + 173743
19  libsystem_pthread.dylib          0x00007fffd3be593b _pthread_body + 180
20  libsystem_pthread.dylib          0x00007fffd3be5887 _pthread_start + 286
21  libsystem_pthread.dylib          0x00007fffd3be508d thread_start + 13
Thread 24:: pi::APIThread
Thread 25 Crashed:: pi::APIThread
Thread 25 crashed with X86 Thread State (64-bit):
  rax: 0x0000000000000000  rbx: 0x0000000000000006  rcx: 0x0000700009f36528  rdx: 0x0000000000000000
  rdi: 0x00000000000188bb  rsi: 0x0000000000000006  rbp: 0x0000700009f36550  rsp: 0x0000700009f36528
   r8: 0x00007fffd3a89650   r9: 0x00007fffd3a4ba50  r10: 0x0000000008000000  r11: 0x0000000000000206
  r12: 0x0000700009f366b0  r13: 0x0000000000000030  r14: 0x0000700009f38000  r15: 0x0000000000000008
  rip: 0x00007fffd3afad42  rfl: 0x0000000000000206  cr2: 0x0000700009eb1e28
Logical CPU:     0
Error Code:      0x02000148
Trap Number:     133
Binary Images:
       0x108380000 -        0x1097f2ffb +software.pleiades.PixInsight (1.8.5.1352 - 1.8.5.1352) <FAA17977-C91D-3ACD-98B3-E77544A5FF86> /Applications/PixInsight/PixInsight.app/Contents/MacOS/PixInsight
       0x109973000 -        0x10998cfff +org.qt-project.QtSensors (5.9 - 5.9.0) <A3AD52C7-F100-325E-B09F-969E3B3B6BDA> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtSensors.framework/Versions/5/QtSensors
       0x1099b0000 -        0x1099eefff +org.qt-project.QtPositioning (5.9 - 5.9.0) <63A43C3F-8B6E-3AE2-9BA7-748301B0A73D> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtPositioning.framework/Versions/5/QtPositioning
       0x109a08000 -        0x109a19ff7 +org.qt-project.QtMultimediaWidgets (5.9 - 5.9.0) <1BCC91AF-C900-36FF-BC38-1C24B2D6EB2E> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtMultimediaWidgets.framework/Versions/5/QtMultimediaWidgets
       0x109a31000 -        0x109aa6ff3 +org.qt-project.QtMultimedia (5.9 - 5.9.0) <EA574B63-671A-3715-B4BE-2A61AA5A1DAB> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtMultimedia.framework/Versions/5/QtMultimedia
       0x109afd000 -        0x109b31fff +org.qt-project.QtOpenGL (5.9 - 5.9.0) <81357AD1-4FC3-35B8-A9FD-7975DBD78B13> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtOpenGL.framework/Versions/5/QtOpenGL
       0x109b59000 -        0x109b7cff7 +org.qt-project.QtSql (5.9 - 5.9.0) <33FBDDD7-999B-3D74-B236-D5E11B6F03D5> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtSql.framework/Versions/5/QtSql
       0x109b94000 -        0x109e63ff7 +org.qt-project.QtQml (5.9 - 5.9.0) <CC975CAE-4BAE-3FEA-9A78-7F56A91D931D> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtQml.framework/Versions/5/QtQml
       0x109f24000 -        0x10a1cdff7 +org.qt-project.QtQuick (5.9 - 5.9.0) <620EF5C4-98CA-399B-B508-D2957B600576> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtQuick.framework/Versions/5/QtQuick
       0x10a2f7000 -        0x10a30bfff +org.qt-project.QtWebChannel (5.9 - 5.9.0) <60828451-86E0-3251-96D3-5D584ADF954A> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtWebChannel.framework/Versions/5/QtWebChannel
       0x10a31a000 -        0x10a349ffb +org.qt-project.QtWebEngine (5.9 - 5.9.0) <E3CC0DD0-96CD-3D37-925E-9119BA575CE9> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtWebEngine.framework/Versions/5/QtWebEngine
       0x10a37d000 -        0x10a385ff7 +org.qt-project.QtMacExtras (5.9 - 5.9.0) <579BE559-3E85-3C38-A8A9-A491E3967675> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtMacExtras.framework/Versions/5/QtMacExtras
       0x10a38e000 -        0x10a3a7fff  libexpat.1.dylib (15.1) <588CA992-60BB-363B-BEE7-3CC0A26C1AFA> /usr/lib/libexpat.1.dylib
       0x10a3c1000 -        0x10a3fedc7  dyld (433.5) <93EA668C-4BB2-3646-96E9-B406B81308D6> /usr/lib/dyld
       0x10a44c000 -        0x10f5a4fbf +org.qt-project.Qt.QtWebEngineCore (5.9 - 5.9.0) <ED62C3D4-D6D2-33A8-80EB-26459AD1946E> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtWebEngineCore.framework/Versions/5/QtWebEngineCore
       0x10fc0d000 -        0x10fc2dff7 +org.qt-project.QtWebEngineWidgets (5.9 - 5.9.0) <E6EBEF99-21AE-3CE3-86C1-2BF92D2956D2> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtWebEngineWidgets.framework/Versions/5/QtWebEngineWidgets
       0x10fc52000 -        0x10fc7effb +org.qt-project.QtPrintSupport (5.9 - 5.9.0) <E90FBBB6-4130-39FB-A8E9-CFA98E1B91A8> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtPrintSupport.framework/Versions/5/QtPrintSupport
       0x10fca3000 -        0x110109ff3 +org.qt-project.QtWidgets (5.9 - 5.9.0) <F241C7E7-2896-362B-AB71-C36D5A6CBA79> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtWidgets.framework/Versions/5/QtWidgets
       0x110297000 -        0x110692feb +org.qt-project.QtGui (5.9 - 5.9.0) <96EE0E47-5EB1-3F32-9979-F71D1C066D6C> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtGui.framework/Versions/5/QtGui
       0x110799000 -        0x1107cfffb +org.qt-project.QtSvg (5.9 - 5.9.0) <F371FB86-0A1B-3446-9409-5AB0AA7E3AED> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtSvg.framework/Versions/5/QtSvg
       0x1107ef000 -        0x11081aff3 +org.qt-project.QtXml (5.9 - 5.9.0) <3EEF66A3-8DAC-3F96-B1AB-D46868BF3412> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtXml.framework/Versions/5/QtXml
       0x11082e000 -        0x110936ff7 +org.qt-project.QtNetwork (5.9 - 5.9.0) <0E09215D-7048-3897-BAEE-AB1CF6F3688F> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtNetwork.framework/Versions/5/QtNetwork
       0x110991000 -        0x110e7eff3 +org.qt-project.QtCore (5.9 - 5.9.0) <F57E72F1-E61A-3E32-AEC7-C6E74A8AFF0A> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtCore.framework/Versions/5/QtCore
       0x110f48000 -        0x111354fff +libmozjs-24.dylib (1) <E33E54D2-0AB5-3A18-BA0F-B816C8FEEBFF> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/libmozjs-24.dylib
       0x1113e2000 -        0x111420ff7  com.apple.audio.midi.CoreMIDI (1.10 - 88) <5E2D1F53-B466-312E-AEA7-117B68C9A7F0> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
       0x111448000 -        0x111453ffb +org.qt-project.QtQuickWidgets (5.9 - 5.9.0) <2A33F9F6-55B3-3E6C-A46B-C8C725C28426> /Applications/PixInsight/PixInsight.app/Contents/Frameworks/QtQuickWidgets.framework/Versions/5/QtQuickWidgets
       0x114317000 -        0x114468ff3 +libqcocoa.dylib (0) <ADDB718A-0B9B-3469-BCB3-A8B91A468100> /Applications/PixInsight/PixInsight.app/Contents/PlugIns/platforms/libqcocoa.dylib
       0x116cb6000 -        0x116cbafff  libFontRegistryUI.dylib (196.4) <4EEE5715-A024-3A4B-BF0E-D55325B8E129> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resources/libFontRegistryUI.dylib
       0x116ede000 -        0x117084fff  GLEngine (14.0.16) <E8C60E20-6414-32B2-8964-41882943D9C1> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
       0x1170c3000 -        0x11761eff7  com.apple.driver.AppleIntelHD5000GraphicsGLDriver (10.25.19 - 10.2.5) <0A79FC72-47E5-3546-813C-05610FCABD9F> /System/Library/Extensions/AppleIntelHD5000GraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHD5000GraphicsGLDriver
       0x117831000 -        0x11785bfff  GLRendererFloat (14.0.16) <32A016EE-63CF-3D07-9BAB-C4EB3E8E479D> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
       0x117865000 -        0x1178ddff7  com.apple.driver.AppleIntelHD5000GraphicsMTLDriver (10.25.19 - 10.2.5) <4779D135-8ECC-3B1D-88EB-E2334696DA43> /System/Library/Extensions/AppleIntelHD5000GraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelHD5000GraphicsMTLDriver
       0x119e8b000 -        0x119e91fff +libqgif.dylib (0) <BD9ED32B-7B3F-31AC-9DAE-AAB8CBB91DF0> /Applications/PixInsight/PixInsight.app/Contents/PlugIns/imageformats/libqgif.dylib
       0x119e97000 -        0x119e9effb +libqicns.dylib (0) <724E2C29-1BC3-3063-A5BC-5FFB537BD045> /Applications/PixInsight/PixInsight.app/Contents/PlugIns/imageformats/libqicns.dylib
       0x119ea5000 -        0x119eaaff3 +libqico.dylib (0) <8D22E3A7-FEB7-36FE-B246-A94CABE24C85> /Applications/PixInsight/PixInsight.app/Contents/PlugIns/imageformats/libqico.dylib
       0x119eb1000 -        0x119eebff7 +libqjpeg.dylib (0) <0E541047-2971-36BD-8AE6-CAFED9BFCB42> /Applications/PixInsight/PixInsight.app/Contents/PlugIns/imageformats/libqjpeg.dylib
       0x119ef4000 -        0x119ef8fff +libqmacjp2.dylib (0) <E32F6219-AE20-37D9-B742-28AA71E8A431> /Applications/PixInsight/PixInsight.app/Contents/PlugIns/imageformats/libqmacjp2.dylib
       0x119eff000 -        0x119f03fff +libqsvg.dylib (0) <D1226155-EE8A-3E37-91CB-F8FBA1A79D35> /Applications/PixInsight/PixInsight.app/Contents/PlugIns/imageformats/libqsvg.dylib
       0x119f0a000 -        0x119f0eff7 +libqtga.dylib (0) <FBFFA5E4-6113-329D-B912-815B5CF5A071> /Applications/PixInsight/PixInsight.app/Contents/PlugIns/imageformats/libqtga.dylib
       0x119f14000 -        0x119f66fff +libqtiff.dylib (0) <1ECFF29F-1198-345E-A85F-2E5076B227E7> /Applications/PixInsight/PixInsight.app/Contents/PlugIns/imageformats/libqtiff.dylib
       0x119f72000 -        0x119f76ff3 +libqwbmp.dylib (0) <593D56B0-6F9A-3463-B759-2D8401440ADA> /Applications/PixInsight/PixInsight.app/Contents/PlugIns/imageformats/libqwbmp.dylib
       0x119f7d000 -        0x11a019ff7 +libqwebp.dylib (0) <A4750C17-8CC4-3BB7-83F7-E648D617FA79> /Applications/PixInsight/PixInsight.app/Contents/PlugIns/imageformats/libqwebp.dylib
       0x11a554000 -        0x11a556fff  AppleIntelHSWVA (10.25.19) <E46D735F-5193-391B-84F9-3774AF38019E> /System/Library/Extensions/AppleIntelHSWVA.bundle/Contents/MacOS/AppleIntelHSWVA
       0x11c1f6000 -        0x11c3c7ff7  com.apple.AppleIntelHD5000GraphicsVADriver (10.25.19 - 10.2.5) <3584E7F4-A179-3051-821E-2D0EC8D8CF85> /System/Library/Extensions/AppleIntelHD5000GraphicsVADriver.bundle/Contents/MacOS/AppleIntelHD5000GraphicsVADriver
       0x11d674000 -        0x11d675ff1 +cl_kernels (???) <FFB9D2D9-02A4-45E4-8D23-9B496E48939A> cl_kernels
       0x11d67a000 -        0x11d67aff3 +cl_kernels (???) <A9AA1218-9C47-48C1-B680-C651CEF4DB27> cl_kernels
       0x11d8ff000 -        0x11d97afff +Sandbox-pxm.dylib (0) <99ADADB8-C4C9-308D-8B20-BA8630737568> /Applications/PixInsight/*/Sandbox-pxm.dylib
       0x12525f000 -        0x125260ff3 +cl_kernels (???) <00244723-9CB3-41FA-A0B1-CE98AC411A6A> cl_kernels
       0x12e500000 -        0x12e5a3ff7 +Annotation-pxm.dylib (0) <15153C94-E53A-30AF-95F3-D821A8E896D6> /Applications/PixInsight/*/Annotation-pxm.dylib
       0x12e700000 -        0x12e794ff3 +AssistedColorCalibration-pxm.dylib (0) <582B53B0-C72C-39FA-9268-E157407E8A31> /Applications/PixInsight/*/AssistedColorCalibration-pxm.dylib
       0x12e7c1000 -        0x12e94afff +BackgroundModelization-pxm.dylib (0) <D2AC0D61-F207-32F4-9B6B-E1D108CB795B> /Applications/PixInsight/*/BackgroundModelization-pxm.dylib
       0x12e9b3000 -        0x12eb43ffb +Blink-pxm.dylib (0) <B08954A7-F692-3CF8-9B79-9BB09B2DECE3> /Applications/PixInsight/*/Blink-pxm.dylib
       0x12eb94000 -        0x12eca6ffb +BMP-pxm.dylib (0) <6FB2ED72-4739-34A4-B446-7AC9C2EA5262> /Applications/PixInsight/*/BMP-pxm.dylib
       0x12ecee000 -        0x12eec4ffb +CloneStamp-pxm.dylib (0) <C13EA109-4071-3A0B-9ECC-9628722D39E0> /Applications/PixInsight/*/CloneStamp-pxm.dylib
       0x12ef1a000 -        0x12f258ffb +ColorCalibration-pxm.dylib (0) <ADBED9B7-E207-3568-9C64-AD5037658297> /Applications/PixInsight/*/ColorCalibration-pxm.dylib
       0x12f2ea000 -        0x12f3d2ffb +ColorManagement-pxm.dylib (0) <02CC93CB-E3EC-31D0-8A24-ABBAFDDCE689> /Applications/PixInsight/*/ColorManagement-pxm.dylib
       0x12f410000 -        0x12f916fff +ColorSpaces-pxm.dylib (0) <D3C7A365-A195-314E-8D19-4D04B9B682C9> /Applications/PixInsight/*/ColorSpaces-pxm.dylib
       0x12f9c7000 -        0x12fc96ff7 +CometAlignment-pxm.dylib (0) <BA47351D-5DD6-35CE-8DE2-EF46FD3A1ACA> /Applications/PixInsight/*/CometAlignment-pxm.dylib
       0x12fd0a000 -        0x13001bff3 +Compatibility-pxm.dylib (0) <1F875F75-2266-3EF0-97BB-E1257A280375> /Applications/PixInsight/*/Compatibility-pxm.dylib
       0x13009b000 -        0x1303a5ff3 +Convolution-pxm.dylib (0) <108E8ADD-1BE0-38DF-B4B9-6289087AD1A7> /Applications/PixInsight/*/Convolution-pxm.dylib
       0x130429000 -        0x130689fff +CosmeticCorrection-pxm.dylib (0) <CE38FD0D-65A2-35FA-ADD5-B87E523DBDDE> /Applications/PixInsight/*/CosmeticCorrection-pxm.dylib
       0x1306e7000 -        0x1308a1ffb +Debayer-pxm.dylib (0) <AE6EB3F2-1CAD-3568-900A-FC6ECA6A7B22> /Applications/PixInsight/*/Debayer-pxm.dylib
       0x130903000 -        0x130b45ff3 +Deconvolution-pxm.dylib (0) <C089C941-5592-318C-BE24-A89920168B70> /Applications/PixInsight/*/Deconvolution-pxm.dylib
       0x130ba9000 -        0x130ce3fff +DSLR_RAW-pxm.dylib (0) <69973785-C105-373E-8AF3-F4D93A3FA19F> /Applications/PixInsight/*/DSLR_RAW-pxm.dylib
       0x130dbf000 -        0x131011ff7 +FITS-pxm.dylib (0) <E2DF26F5-B884-3C92-9523-BA66939CE4FD> /Applications/PixInsight/*/FITS-pxm.dylib
       0x131190000 -        0x1312adffb +Flux-pxm.dylib (0) <08D51A84-8F2C-349D-A529-B937FFA61E69> /Applications/PixInsight/*/Flux-pxm.dylib
       0x1312f8000 -        0x1313b5ff3 +Fourier-pxm.dylib (0) <70ECEEA1-1FAA-311C-A5B1-E74F9B422D56> /Applications/PixInsight/*/Fourier-pxm.dylib
       0x1313e8000 -        0x131532fff +Geometry-pxm.dylib (0) <67FBCEEE-6D3E-35A2-A1E0-43096B0140FF> /Applications/PixInsight/*/Geometry-pxm.dylib
       0x131594000 -        0x131717ff7 +Global-pxm.dylib (0) <ECFE07C0-3FF1-36F4-B735-4C6F825D7736> /Applications/PixInsight/*/Global-pxm.dylib
       0x13178c000 -        0x131909ff7 +GradientDomain-pxm.dylib (0) <A44D10A9-44B8-32FE-AF6F-7A483368C812> /Applications/PixInsight/*/GradientDomain-pxm.dylib
       0x131960000 -        0x131a1fff3 +GREYCstoration-pxm.dylib (0) <5BA69845-BB63-3E37-8A3E-15ECC21777C8> /Applications/PixInsight/*/GREYCstoration-pxm.dylib
       0x131a4e000 -        0x131cc1fff +Image-pxm.dylib (0) <A9FC09E2-F05D-3DE6-A37C-69A28652CD3B> /Applications/PixInsight/*/Image-pxm.dylib
       0x131d33000 -        0x1320baff7 +ImageCalibration-pxm.dylib (0) <3C7F4760-55D8-3C70-BDD3-FBDB71E29DFC> /Applications/PixInsight/*/ImageCalibration-pxm.dylib
       0x13214f000 -        0x132543ff7 +ImageIntegration-pxm.dylib (0) <D130E3EF-3296-31F2-9FD1-042F2BB1CCDC> /Applications/PixInsight/*/ImageIntegration-pxm.dylib
       0x1325fa000 -        0x132b3dfff +ImageRegistration-pxm.dylib (0) <9219BD73-4C4C-3E05-82DC-F1934D9743AB> /Applications/PixInsight/*/ImageRegistration-pxm.dylib
       0x132c22000 -        0x132e22ffb +INDIClient-pxm.dylib (0) <DF48708B-E6F2-39D9-8A2C-FC9A4BE71C40> /Applications/PixInsight/*/INDIClient-pxm.dylib
       0x132e9e000 -        0x133246ffb +IntensityTransformations-pxm.dylib (0) <56E6879C-084E-3242-BAF2-EE53EF8C9A2B> /Applications/PixInsight/*/IntensityTransformations-pxm.dylib
       0x133304000 -        0x133425ff3 +JPEG-pxm.dylib (0) <D0DD42CF-4186-3FAC-BCD2-530EC03D3DC8> /Applications/PixInsight/*/JPEG-pxm.dylib
       0x133466000 -        0x13358fff3 +JPEG2000-pxm.dylib (0) <DD3C068D-DEFC-3017-9C6A-ADC8832D411B> /Applications/PixInsight/*/JPEG2000-pxm.dylib
       0x1335db000 -        0x133687ffb +LocalHistogramEqualization-pxm.dylib (0) <915E2E46-1285-3E6A-AE92-F57D1FD83F6E> /Applications/PixInsight/*/LocalHistogramEqualization-pxm.dylib
       0x1336b6000 -        0x133896ff7 +MaskGeneration-pxm.dylib (0) <1CC93314-4934-385E-B134-DC747C831721> /Applications/PixInsight/*/MaskGeneration-pxm.dylib
       0x1338ee000 -        0x133a64fff +Morphology-pxm.dylib (0) <3CB5E734-DA36-3752-B379-84333E20E08C> /Applications/PixInsight/*/Morphology-pxm.dylib
       0x133aa3000 -        0x133ed4ff3 +MultiscaleProcessing-pxm.dylib (0) <453BD081-3A51-3841-968D-C685785A2379> /Applications/PixInsight/*/MultiscaleProcessing-pxm.dylib
       0x133f6e000 -        0x133ff1ff7 +NoiseGeneration-pxm.dylib (0) <36FC2A49-4021-347A-8544-16A04FF8EF59> /Applications/PixInsight/*/NoiseGeneration-pxm.dylib
       0x13401b000 -        0x1341a1fff +NoiseReduction-pxm.dylib (0) <BA3A4761-1B0D-3154-B34B-F92361CD05B2> /Applications/PixInsight/*/NoiseReduction-pxm.dylib
       0x1341f3000 -        0x134231fff +NoOperation-pxm.dylib (0) <DABA497F-5AA6-3F95-9729-BD297B145F20> /Applications/PixInsight/*/NoOperation-pxm.dylib
       0x134248000 -        0x1343c1ffb +Obsolete-pxm.dylib (0) <6D5D01A7-96A7-3A2C-ACEF-7AEC13BFE6D3> /Applications/PixInsight/*/Obsolete-pxm.dylib
       0x13444b000 -        0x1345d8ff7 +PixelMath-pxm.dylib (0) <56C5868A-3BE8-357D-ABE2-5EAAD9EA8959> /Applications/PixInsight/*/PixelMath-pxm.dylib
       0x134641000 -        0x134872ffb +RestorationFilters-pxm.dylib (0) <7C060DE7-63C7-3D31-99B3-373F57089799> /Applications/PixInsight/*/RestorationFilters-pxm.dylib
       0x1348d7000 -        0x1349d0ff7 +SplitCFA-pxm.dylib (0) <D791C9F7-B1F9-3AA2-8FCF-99A5243F1B69> /Applications/PixInsight/*/SplitCFA-pxm.dylib
       0x134a14000 -        0x134af0ffb +StarGenerator-pxm.dylib (0) <7483D7DF-5084-35A1-8FB7-DB146A5A6233> /Applications/PixInsight/*/StarGenerator-pxm.dylib
       0x134b28000 -        0x134c9bff7 +TGV-pxm.dylib (0) <9408DCB1-9B42-3A14-AD5B-1D824E905071> /Applications/PixInsight/*/TGV-pxm.dylib
       0x134ce5000 -        0x134e8dff3 +TIFF-pxm.dylib (0) <4100F523-801F-3EB0-A1A7-B8358F5E7144> /Applications/PixInsight/*/TIFF-pxm.dylib
       0x134ede000 -        0x13509cffb +XISF-pxm.dylib (0) <C7EA4C90-4DC5-3E46-820A-F32858325F6E> /Applications/PixInsight/*/XISF-pxm.dylib
       0x1350f9000 -        0x1354adfff +SubframeSelector-pxm.dylib (0) <628186A5-4699-3CEB-B10C-040AAE1D7555> /Applications/PixInsight/*/SubframeSelector-pxm.dylib
       0x135520000 -        0x135606fff  unorm8_bgra.dylib (2.8.5) <74CB9618-8EDC-336E-A994-C5A1612BD32E> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
       0x13564a000 -        0x13572afe7  unorm8_rgba.dylib (2.8.5) <E3B3D1D1-73DA-3A20-884F-42FFFA59AFB9> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_rgba.dylib
       0x138d96000 -        0x138d9affb  com.apple.qldisplay.Generic (5.0 - 720.7) <108C34E4-AD64-3CAA-9B3A-E93A6165E603> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/PlugIns/Generic.qldisplay/Contents/MacOS/Generic
    0x7fffb8e6d000 -     0x7fffb91b2ff7  com.apple.RawCamera.bundle (7.04 - 914) <86A67D11-9791-3CE6-9FF5-3387C0AB925B> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
    0x7fffba9e4000 -     0x7fffba9e8ffb  com.apple.agl (3.3.1 - AGL-3.3.1) <00D11B5C-E29F-3938-A8DD-D40A26201821> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
    0x7fffba9e9000 -     0x7fffbabaafff  com.apple.avfoundation (2.0 - 1187.36) <2F390EAD-07BB-3788-9E73-13104C2E04CD> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
    0x7fffbabab000 -     0x7fffbac4dff7  com.apple.audio.AVFAudio (1.0 - ???) <7997D588-B542-3EBB-B822-D719C1114BB4> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
    0x7fffbac4e000 -     0x7fffbad17ff3  com.apple.AVKit (1.1 - 356.12) <1A0929CC-BD23-377D-8A22-6C092409AA9D> /System/Library/Frameworks/AVKit.framework/Versions/A/AVKit
    0x7fffbad18000 -     0x7fffbad18fff  com.apple.Accelerate (1.11 - Accelerate 1.11) <916E360F-323C-3AE1-AB3D-D1F3B284AEE9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x7fffbad19000 -     0x7fffbad30ffb  libCGInterfaces.dylib (331.5) <17109679-A284-3C72-AA60-DBA815D3062B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
    0x7fffbad31000 -     0x7fffbb24afeb  com.apple.vImage (8.1 - ???) <B58A7937-BEE2-38FE-87F4-5D5F40D31DC9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x7fffbb24b000 -     0x7fffbb3bcff3  libBLAS.dylib (1185.50.4) <4087FFE0-627E-3623-96B4-F0A9A1991E09> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x7fffbb3bd000 -     0x7fffbb3d1ffb  libBNNS.dylib (15) <254698C7-7D36-3FFF-864E-ADEEEE543076> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
    0x7fffbb3d2000 -     0x7fffbb7c8fef  libLAPACK.dylib (1185.50.4) <C35FFB2F-A0E6-3903-8A3C-113A74BCBCA2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x7fffbb7c9000 -     0x7fffbb7dffff  libLinearAlgebra.dylib (1185.50.4) <345CAACF-7263-36EF-B69B-793EA8B390AF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
    0x7fffbb7e0000 -     0x7fffbb7e6fff  libQuadrature.dylib (3) <EF56C8E6-DE22-3C69-B543-A8648F335FDD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
    0x7fffbb7e7000 -     0x7fffbb7fbff7  libSparseBLAS.dylib (1185.50.4) <67BA432E-FB59-3C78-A8BE-ED4274CBC359> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
    0x7fffbb7fc000 -     0x7fffbb983fe7  libvDSP.dylib (600.60.1) <4155F45B-41CD-3782-AE8F-7AE740FD83C3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x7fffbb984000 -     0x7fffbba36fff  libvMisc.dylib (600.60.1) <E18365D7-DCC4-3304-A8D1-395E656D7B99> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x7fffbba37000 -     0x7fffbba37fff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <7C5733E7-0568-3E7D-AF61-160F19FED544> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x7fffbba38000 -     0x7fffbba75ffb  com.apple.Accounts (113 - 113) <8550BD08-7D05-3AC4-A0CC-B67ECB2DE950> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
    0x7fffbba76000 -     0x7fffbbcf5ff7  com.apple.AddressBook.framework (10.0 - 1756.20) <E512B69B-8DBE-3085-95BE-750B8EFC97FD> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
    0x7fffbbcf6000 -     0x7fffbcacfff3  com.apple.AppKit (6.9 - 1504.83.101) <9BE62551-6557-3E49-9894-6917D403E8F8> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7fffbcae1000 -     0x7fffbcae1fff  com.apple.ApplicationServices (48 - 48) <DA687F9A-7B2D-342B-8796-16E45344F853> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x7fffbcae2000 -     0x7fffbcb50ff7  com.apple.ApplicationServices.ATS (377 - 422.3) <73C230CF-3213-3DCA-B528-664FEC76A90C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x7fffbcbea000 -     0x7fffbcd19fff  libFontParser.dylib (194.13) <BE507D17-17D0-37E8-A317-6921118BD283> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x7fffbcd1a000 -     0x7fffbcd64fff  libFontRegistry.dylib (196.4) <EA96AE47-3369-3DEA-BB82-98348ADBD85B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x7fffbcdc1000 -     0x7fffbcdf4fff  libTrueTypeScaler.dylib (194.13) <F982F582-E2C8-3902-9C79-BB3F4B8199D2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
    0x7fffbce61000 -     0x7fffbcf0bff7  com.apple.ColorSync (4.12.0 - 502.2) <ACA4001E-A0E3-33F6-9CD6-EEC2AA15E322> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x7fffbcf0c000 -     0x7fffbcf5dfff  com.apple.HIServices (1.22 - 593) <045870A9-1D92-3FEF-8722-671E99A35E71> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x7fffbcf5e000 -     0x7fffbcf6dff3  com.apple.LangAnalysis (1.7.0 - 1.7.0) <2CBE7F61-2056-3F96-99A1-0D527796AFA6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x7fffbcf6e000 -     0x7fffbcfbbfff  com.apple.print.framework.PrintCore (12 - 491) <5027FD58-F0EE-33E4-8577-934CA06CD2AF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x7fffbcfbc000 -     0x7fffbcff7fff  com.apple.QD (3.12 - 313) <B339C41D-8CDF-3342-8414-F9717DCCADD4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x7fffbcff8000 -     0x7fffbd003fff  com.apple.speech.synthesis.framework (6.6.2 - 6.6.2) <7853EFF4-62B9-394E-B7B8-41A645656820> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x7fffbd004000 -     0x7fffbd210ff7  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <1F4026C6-23C1-39E8-823D-72298FECF75C> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x7fffbd211000 -     0x7fffbd211fff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <2CEE36AF-79E6-3B3E-B369-285E6C1886F7> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x7fffbd37a000 -     0x7fffbd756fff  com.apple.CFNetwork (811.8 - 811.8) <3FB812CB-F4BF-3C47-B772-042FC4D59A33> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x7fffbd770000 -     0x7fffbd770fff  com.apple.Carbon (154 - 157) <69F403C7-F0CB-34E6-89B0-235CF4978C17> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x7fffbd771000 -     0x7fffbd774fff  com.apple.CommonPanels (1.2.6 - 98) <BF04BB22-D54C-309E-9F5C-897D969CAF70> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x7fffbd775000 -     0x7fffbda7efff  com.apple.HIToolbox (2.1.1 - 857.8) <5367366E-747E-32CF-8E76-93CD8E7424C7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x7fffbda7f000 -     0x7fffbda82ff7  com.apple.help (1.3.5 - 49) <B1A930E3-5907-3677-BACD-858EF68B172D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x7fffbda83000 -     0x7fffbda88fff  com.apple.ImageCapture (9.0 - 9.0) <341252B4-E082-361A-B756-6A330259C741> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x7fffbda89000 -     0x7fffbdb20ff3  com.apple.ink.framework (10.9 - 219) <1BD40B45-FD33-3177-A935-565EE5FC79D7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x7fffbdb21000 -     0x7fffbdb3bfff  com.apple.openscripting (1.7 - 172.1) <78F3256B-AF4C-324A-A591-ECA4443A469F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x7fffbdb3c000 -     0x7fffbdb3dff3  com.apple.print.framework.Print (12 - 267) <E2F82F1F-DC27-3EF0-9F75-B354F701450A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x7fffbdb3e000 -     0x7fffbdb40ff7  com.apple.securityhi (9.0 - 55006) <3AA3E67A-83BF-3EA8-A751-570D9856735B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x7fffbdb41000 -     0x7fffbdb47ff7  com.apple.speech.recognition.framework (6.0.1 - 6.0.1) <082895DC-3AC7-3DEF-ADCA-5B018C19C9D3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x7fffbdb48000 -     0x7fffbdc27ffb  com.apple.cloudkit.CloudKit (651.14 - 651.14) <9F901E45-23E3-3F45-B66F-1BAB3AFC4462> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
    0x7fffbdc28000 -     0x7fffbdc28fff  com.apple.Cocoa (6.11 - 22) <85EDFBE1-75F0-369E-8CA8-C6A639B98FA6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x7fffbdd72000 -     0x7fffbddfffff  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <78767F88-91D4-31CE-AAC6-1F9407F479BB> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x7fffbde00000 -     0x7fffbde13fff  com.apple.CoreBluetooth (1.0 - 1) <BCB78777-76F0-3CC1-8443-9E61AEF7EF63> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
    0x7fffbde14000 -     0x7fffbe10ffff  com.apple.CoreData (120 - 754.2) <4C9CAB2C-60D4-3694-A0A0-5B04B14BD14E> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x7fffbe110000 -     0x7fffbe1bdff7  com.apple.CoreDisplay (1.0 - 1) <53D1EAFE-23A4-398D-BF52-E4299E670DB6> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
    0x7fffbe1be000 -     0x7fffbe657ff7  com.apple.CoreFoundation (6.9 - 1349.90) <F07A2387-602E-3D9E-8708-3B3430BD7D82> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7fffbe658000 -     0x7fffbecdafff  com.apple.CoreGraphics (2.0 - 1070.22) <FAB476BB-B5CD-3936-8AFC-41229DBDF0E8> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x7fffbecdb000 -     0x7fffbef1effb  com.apple.CoreImage (12.4.0 - 451.4.9) <BE4303C9-C9D9-361D-AC94-DBE40EB6700E> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
    0x7fffbef1f000 -     0x7fffbef84ff7  com.apple.corelocation (2101.0.63) <C4C6BE27-85E2-34D5-AEDC-EBB5A7CB78D1> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
    0x7fffbef85000 -     0x7fffbf036fff  com.apple.CoreMedia (1.0 - 1907.59.1.6) <570690D8-A956-3629-9E46-4F8BDDB8A82C> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
    0x7fffbf037000 -     0x7fffbf082ff7  com.apple.CoreMediaIO (805.0 - 4932) <15668A10-FD6B-34BB-A14D-F4CE4DAF2887> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
    0x7fffbf083000 -     0x7fffbf083fff  com.apple.CoreServices (775.19 - 775.19) <5046FF69-034E-3570-AC30-D14AA469F669> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x7fffbf084000 -     0x7fffbf0d5fff  com.apple.AE (712.5 - 712.5) <61F2AE2C-E04E-3FDF-9E88-201325136C83> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x7fffbf0d6000 -     0x7fffbf3b1ff7  com.apple.CoreServices.CarbonCore (1159.6 - 1159.6) <08AC074C-965B-3EDF-8E45-0707C8DE9EAD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x7fffbf3b2000 -     0x7fffbf3e5fff  com.apple.DictionaryServices (1.2 - 274) <D23866E2-F7C8-3984-A9D4-96552CCDE573> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x7fffbf3e6000 -     0x7fffbf3eeff3  com.apple.CoreServices.FSEvents (1230.50.1 - 1230.50.1) <2AD1B0E5-7214-37C4-8D11-A27C9CAC0F74> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
    0x7fffbf3ef000 -     0x7fffbf55bff7  com.apple.LaunchServices (775.19 - 775.19) <F3E91733-245F-3F7B-97A7-CB54DFB80CEF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x7fffbf55c000 -     0x7fffbf60cffb  com.apple.Metadata (10.7.0 - 1075.40) <B734F567-EC70-39AF-BB86-46C97065580F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x7fffbf60d000 -     0x7fffbf66cfff  com.apple.CoreServices.OSServices (775.19 - 775.19) <FF1BED62-A2AD-3FA0-BBFA-E619D21E574F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x7fffbf66d000 -     0x7fffbf6ddfff  com.apple.SearchKit (1.4.0 - 1.4.0) <7A6DDA2B-03F1-3137-BA9E-1CC211973E26> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x7fffbf6de000 -     0x7fffbf723ff7  com.apple.coreservices.SharedFileList (38 - 38) <DA096678-93AB-3291-BDE2-482F1D544589> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
    0x7fffbf7ac000 -     0x7fffbf8f9ffb  com.apple.CoreText (352.0 - 544.16) <543AFBA5-4E6B-3F81-BC45-81ED9707BD9C> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
    0x7fffbf8fa000 -     0x7fffbf92fff3  com.apple.CoreVideo (1.8 - 235.3) <AC11D5FB-C77B-34F5-B942-F698E84C229F> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x7fffbf930000 -     0x7fffbf9a1ffb  com.apple.framework.CoreWLAN (11.0 - 1200.31) <4D57D932-6D66-3800-8D33-13951D2E0D84> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
    0x7fffbf9d4000 -     0x7fffbf9dfff3  com.apple.DirectoryService.Framework (10.12 - 194) <45BEA292-4550-3082-8CE7-5D6CE7E0052A> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
    0x7fffbf9e0000 -     0x7fffbfa9eff7  com.apple.DiscRecording (9.0.3 - 9030.4.5) <9397E609-CB54-37B2-B28E-D4BC6C34BFAB> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
    0x7fffbfa9f000 -     0x7fffbfaa4fff  com.apple.DiskArbitration (2.7 - 2.7) <70F56042-EF04-3BAF-9E04-90F423FB2BCC> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x7fffbfc36000 -     0x7fffbffdcfff  com.apple.Foundation (6.9 - 1349.91) <F24B1521-454A-3AE7-B41F-F8FA95BA0490> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x7fffc0008000 -     0x7fffc0039ff7  com.apple.GSS (4.0 - 2.0) <30A77A95-CBD4-3BD7-9BFF-8426071F5D9D> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
    0x7fffc003a000 -     0x7fffc0052ff7  com.apple.GameController (1.0 - 1) <DAC8C83B-7EC8-3A88-A725-E13DD905BF4F> /System/Library/Frameworks/GameController.framework/Versions/A/GameController
    0x7fffc00f9000 -     0x7fffc019cfff  com.apple.Bluetooth (5.0.5 - 5.0.5f1) <7BC341AE-0207-3670-AD01-27687D9D6F5E> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
    0x7fffc019d000 -     0x7fffc0233ff7  com.apple.framework.IOKit (2.0.2 - 1324.60.4) <454036AD-86AA-3ABB-8C53-B5F654A6824D> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x7fffc0234000 -     0x7fffc023affb  com.apple.IOSurface (159.12 - 159.12) <E3D6FCED-F938-30A3-AD08-0998B674A492> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x7fffc023b000 -     0x7fffc028cff7  com.apple.ImageCaptureCore (7.0 - 7.0) <A640CA2F-8093-34AB-947C-26679ECB8A6D> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
    0x7fffc028d000 -     0x7fffc03edfef  com.apple.ImageIO.framework (3.3.0 - 1599.13) <443879A7-48C6-37ED-AC0B-166EEEABA662> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x7fffc03ee000 -     0x7fffc03f2fff  libGIF.dylib (1599.13) <11C5D9D7-B8A1-3D53-BA50-B25976FE6379> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x7fffc03f3000 -     0x7fffc04e3ff7  libJP2.dylib (1599.13) <C495FB08-0CD2-36FC-8196-FAD3D598A010> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x7fffc04e4000 -     0x7fffc0507ffb  libJPEG.dylib (1599.13) <D22E2431-76A5-39B4-AF0B-174CF282A1CE> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x7fffc0508000 -     0x7fffc052fff7  libPng.dylib (1599.13) <561865FA-A51B-3EFF-ABFF-B4566B90B1A2> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x7fffc0530000 -     0x7fffc0532ff3  libRadiance.dylib (1599.13) <6559253B-8FE2-3884-BC93-95BB7705A6D1> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x7fffc0533000 -     0x7fffc0581ffb  libTIFF.dylib (1599.13) <8FC594B3-6BBF-3A70-9994-203E9B330B5F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x7fffc06df000 -     0x7fffc12e9fff  com.apple.JavaScriptCore (12603 - 12603.3.8) <9557271A-1838-38DD-93E3-D8A9ECDE3B6B> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
    0x7fffc12ea000 -     0x7fffc1303ff7  com.apple.Kerberos (3.0 - 1) <B9D242EB-E325-3A21-9812-C77CBBFB0D51> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x7fffc1304000 -     0x7fffc133afff  com.apple.LDAPFramework (2.4.28 - 194.5) <492ACA22-373E-3DD9-BAEB-9EF6AA962FD5> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
    0x7fffc158d000 -     0x7fffc1593fff  com.apple.MediaAccessibility (1.0 - 97.1.1) <0BD82735-6644-37CE-B13D-8E7CC59A1752> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
    0x7fffc15a9000 -     0x7fffc1ae2ff7  com.apple.MediaToolbox (1.0 - 1907.59.1.6) <FA068C6F-0506-35C3-A637-C4AFF82411DB> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
    0x7fffc1ae3000 -     0x7fffc1b3efff  com.apple.Metal (87.18 - 87.18) <E3618B54-C728-34CA-9E8A-9BD33A295D31> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
    0x7fffc2427000 -     0x7fffc242ffff  com.apple.NetFS (6.0 - 4.0) <14A24D00-5673-330A-959D-87F72040DEFF> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x7fffc2606000 -     0x7fffc260eff7  libcldcpuengine.dylib (2.8.5) <8086D6FA-2006-3582-B20E-4209D81ACC58> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
    0x7fffc260f000 -     0x7fffc265dff3  com.apple.opencl (2.8.6 - 2.8.6) <A6140AC4-7579-3AC2-B7EE-08A8899BC811> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x7fffc265e000 -     0x7fffc2677ffb  com.apple.CFOpenDirectory (10.12 - 194) <A64E9A01-3F6E-36EA-9C10-88C564A68C9D> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x7fffc2678000 -     0x7fffc2683ff7  com.apple.OpenDirectory (10.12 - 194) <4298FFD0-B1A7-3064-AF5B-708B3FA38671> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x7fffc2684000 -     0x7fffc2686fff  libCVMSPluginSupport.dylib (14.0.16) <AA2468D1-9169-3424-8EE4-0470E9050E21> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
    0x7fffc2687000 -     0x7fffc268aff7  libCoreFSCache.dylib (156.3) <687C4CC3-6537-344B-8BE1-5234C8CB2864> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
    0x7fffc268b000 -     0x7fffc268ffff  libCoreVMClient.dylib (156.3) <E7AEFCBE-B6BF-3C7C-9A4E-E78CB04DB794> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0x7fffc2690000 -     0x7fffc2699ff7  libGFXShared.dylib (14.0.16) <170D07F3-2D30-3D4B-80A0-971E0A765709> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
    0x7fffc269a000 -     0x7fffc26a5fff  libGL.dylib (14.0.16) <0801F3B9-A525-32BB-9BC0-478947CE21D9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x7fffc26a6000 -     0x7fffc26e2ff7  libGLImage.dylib (14.0.16) <FE39C57B-056C-3CBF-B653-A8F2005631C1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x7fffc26e3000 -     0x7fffc2859ff3  libGLProgrammability.dylib (14.0.16) <A81F1B95-445C-3191-ADB1-07BAEA5A204D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
    0x7fffc285a000 -     0x7fffc289bff7  libGLU.dylib (14.0.16) <B285EAD6-B3AA-3753-BB85-75864BD6E76C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x7fffc3203000 -     0x7fffc3211fff  com.apple.opengl (14.0.16 - 14.0.16) <B428BB89-8FE1-3527-BF3E-F8F0A1060884> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x7fffc32ae000 -     0x7fffc33f5fff  com.apple.QTKit (7.7.3 - 2978.8) <80B27C5D-087F-3B83-AF99-AD6BA2E1105D> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
    0x7fffc33f6000 -     0x7fffc3660ff7  com.apple.imageKit (3.0 - 1023) <9C547565-CBAA-3ACB-A3F6-1366A0DCDCB4> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
    0x7fffc3661000 -     0x7fffc3728fff  com.apple.PDFKit (1.0 - 1) <BE82F14C-B20C-3771-B16C-F0723F6552AD> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
    0x7fffc3729000 -     0x7fffc3c4fff7  com.apple.QuartzComposer (5.1 - 356) <C66293F6-EF05-3B36-8524-081CEB9FADD7> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
    0x7fffc3c50000 -     0x7fffc3c73ffb  com.apple.quartzfilters (1.10.0 - 1.10.0) <365342ED-7A1A-3C75-AE60-90764E96034C> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
    0x7fffc3c74000 -     0x7fffc3d61fff  com.apple.QuickLookUIFramework (5.0 - 720.7) <3136C23E-399E-3296-928A-B18EC9FC423C> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
    0x7fffc3d62000 -     0x7fffc3d62fff  com.apple.quartzframework (1.5 - 21) <09455972-8A33-3D61-B193-BA7E7CF984CA> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
    0x7fffc3d63000 -     0x7fffc3f63fff  com.apple.QuartzCore (1.11 - 453.39.5) <34F65F8C-01D2-3120-BD04-2620BB652D50> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x7fffc3f64000 -     0x7fffc3fb9fff  com.apple.QuickLookFramework (5.0 - 720.7) <3BD7BA2F-924C-3EFF-B26E-3F930E62E6B4> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
    0x7fffc3fba000 -     0x7fffc3fd0fff  com.apple.SafariServices.framework (12604 - 12604.5.6.1.1) <8B44CF12-8B46-3E05-A6E6-8B726BEDF7D5> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
    0x7fffc44cb000 -     0x7fffc47cdff7  com.apple.security (7.0 - 57740.60.22) <F5AE6D2C-DA85-356B-9696-229545452B6A> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x7fffc47ce000 -     0x7fffc4843fff  com.apple.securityfoundation (6.0 - 55132.50.7) <A4D43619-8083-333C-AFD1-2BA9E8AFB7EB> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x7fffc4844000 -     0x7fffc486dfff  com.apple.securityinterface (10.0 - 55079.50.4) <23B4B419-5768-3EC6-8DD9-7470D2599AD1> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
    0x7fffc486e000 -     0x7fffc4871ff3  com.apple.xpc.ServiceManagement (1.0 - 1) <BE0F9708-0B55-3E78-A15E-C287B8ED13BA> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
    0x7fffc4bf8000 -     0x7fffc4c67ff7  com.apple.SystemConfiguration (1.14 - 1.14) <B471E0FA-3AC6-3A34-82C8-4FCF4B389368> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x7fffc4c68000 -     0x7fffc5016fff  com.apple.VideoToolbox (1.0 - 1907.59.1.6) <EB2577A4-DCDF-3FD1-B5FA-42A55653A74D> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
    0x7fffc6d43000 -     0x7fffc6d4affb  com.apple.APFS (1.0 - 1) <6E79797E-26BD-3E49-891C-03B223F7BD59> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
    0x7fffc74be000 -     0x7fffc74d9ff3  com.apple.AppContainer (4.0 - 307.50.21) <C2E6BA3D-81FF-39C3-B4BF-DBB9A17DE078> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
    0x7fffc74da000 -     0x7fffc74e7ff3  com.apple.AppSandbox (4.0 - 307.50.21) <BF9FA426-8C11-358B-9E1F-A3901E3F2B14> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
    0x7fffc74e8000 -     0x7fffc750affb  com.apple.framework.Apple80211 (12.0 - 1200.47) <869BFE4C-3F15-349E-9715-0A48ED725EAE> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
    0x7fffc750b000 -     0x7fffc751afeb  com.apple.AppleFSCompression (88.50.3 - 1.0) <478E8BFF-8BA2-375E-BE02-BA27F115C15A> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
    0x7fffc751b000 -     0x7fffc75e3fff  com.apple.AppleGVAFramework (10.1.17 - 10.1.17) <7BA0A1D5-537E-3262-80A9-99E5312D2995> /System/Library/PrivateFrameworks/AppleGVA.framework/Versions/A/AppleGVA
    0x7fffc7605000 -     0x7fffc769097f  com.apple.AppleJPEG (1.0 - 1) <B9E9570D-04A4-34E4-B756-D200043B25B8> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
    0x7fffc76a4000 -     0x7fffc76bffff  com.apple.aps.framework (4.0 - 4.0) <6CA07CDF-1E35-34E9-95BF-BD565FF42BAD> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
    0x7fffc76c0000 -     0x7fffc76c8ffb  com.apple.AppleSRP (5.0 - 1) <6AAE93B6-9816-35B2-9C59-D5C3218065AF> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
    0x7fffc76c9000 -     0x7fffc76ccff3  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <42A1731A-A576-307A-B07C-9F8F64696CB7> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
    0x7fffc76cd000 -     0x7fffc771ffff  com.apple.AppleVAFramework (5.0.36 - 5.0.36) <B272678B-2EA8-3F04-BB0F-3CE62D1E4F58> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
    0x7fffc7729000 -     0x7fffc7730ff7  com.apple.AssetCacheServices (48.3 - 48.3) <C59F7295-36D8-3109-A910-C83D884CC92C> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServices
    0x7fffc7ac3000 -     0x7fffc7b41ff7  com.apple.backup.framework (1.8.5 - 1.8.5) <CC679891-E8F5-3166-8EB6-AEA06954A52D> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
    0x7fffc7b6a000 -     0x7fffc7ba7ffb  com.apple.bom (14.0 - 194.1) <0CBECAF1-B5E0-302F-99EC-D7ED14E12B84> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
    0x7fffc7de8000 -     0x7fffc7e11ffb  com.apple.CacheDelete (1.0 - 1) <D9678282-6F34-3EE4-94E2-42B2F6A055A5> /System/Library/PrivateFrameworks/CacheDelete.framework/Versions/A/CacheDelete
    0x7fffc81dd000 -     0x7fffc8204fff  com.apple.CalendarAgentLink (8.0 - 250) <E50E29F6-2BAB-3B8B-BBEA-7DC0B8B077AD> /System/Library/PrivateFrameworks/CalendarAgentLink.framework/Versions/A/CalendarAgentLink
    0x7fffc87cc000 -     0x7fffc87f3ff3  com.apple.ChunkingLibrary (173 - 173) <FC2165F9-FC93-39C0-8323-C2F43A5E00A3> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
    0x7fffc87f4000 -     0x7fffc8880ff7  com.apple.CloudDocs (1.0 - 486.29) <392B87EC-0317-313F-8FE2-F571831C7F35> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
    0x7fffc9118000 -     0x7fffc9121ffb  com.apple.CommonAuth (4.0 - 2.0) <44E4467E-90BB-3CC4-9E57-9B09D7E90081> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
    0x7fffc91e8000 -     0x7fffc9239ff7  com.apple.AddressBook.ContactsFoundation (8.0 - 2250.11) <1324A70E-A093-3DB9-A802-07B8F4A499B5> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation
    0x7fffc923a000 -     0x7fffc925cfff  com.apple.contacts.ContactsPersistence (1.0 - 2250.11) <7CDEB852-B3B7-328F-9537-DFB3A58B882C> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersistence
    0x7fffc92a6000 -     0x7fffc9685ff7  com.apple.CoreAUC (226.0.0 - 226.0.0) <FBF6C5BC-5937-3957-B6BA-E101DF9B0DF6> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
    0x7fffc9686000 -     0x7fffc96b6fff  com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <3F6857D1-AE7C-3593-B064-930F5BB7269E> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
    0x7fffc9751000 -     0x7fffc9759ffb  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <2AB86FAF-37B3-3323-9EF0-CA591B6E357C> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
    0x7fffc986a000 -     0x7fffc987afff  com.apple.CoreEmoji (1.0 - 40.3.3) <E9A28301-2D79-3A97-A046-028258A6ABE5> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
    0x7fffc993f000 -     0x7fffc9955ff3  com.apple.CoreMediaAuthoring (2.2 - 956) <AEBFF55F-BF1E-3CA5-AA9C-1CE22218A665> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
    0x7fffc995c000 -     0x7fffc99ecffb  com.apple.CorePDF (4.0 - 4) <7F50E4A6-940C-33F5-BE4E-7E01AFE98A8F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
    0x7fffc9bb5000 -     0x7fffc9be5ff3  com.apple.CoreServicesInternal (276.2 - 276.2) <05EB7D45-DD4C-3A0F-AC63-A0C2A68E6481> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
    0x7fffc9e76000 -     0x7fffc9f05ff7  com.apple.CoreSymbolication (62046) <9685A34A-C6FD-3681-8F7E-211D48298DD2> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
    0x7fffc9f06000 -     0x7fffca045fe7  com.apple.coreui (2.1 - 431.3) <8D0FA478-9B6C-3D6D-8ADF-8677BA0BF134> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x7fffca046000 -     0x7fffca116ff3  com.apple.CoreUtils (5.1 - 510.31) <4AC4A8E9-C1E8-3FBA-AF0E-96F9404D826D> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
    0x7fffca166000 -     0x7fffca1cbff3  com.apple.framework.CoreWiFi (12.0 - 1200.31) <DE9DB291-452C-33FB-833B-C62D09CF424F> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
    0x7fffca1cc000 -     0x7fffca1daff7  com.apple.CrashReporterSupport (10.12 - 827) <802A9B81-E349-348B-90AB-10E40B654250> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
    0x7fffca24c000 -     0x7fffca256ffb  com.apple.framework.DFRFoundation (1.0 - 104.25) <7CFF896C-EF22-3941-BB3D-F3615CE4C908> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
    0x7fffca257000 -     0x7fffca25bff3  com.apple.DSExternalDisplay (3.1 - 380) <4B5E3FF0-E8C3-38CC-BF72-418C928956AB> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
    0x7fffca291000 -     0x7fffca306ffb  com.apple.datadetectorscore (7.0 - 539.1) <84F04DEF-DF0A-3F93-AEE9-B6FAC781164B> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
    0x7fffca342000 -     0x7fffca381fff  com.apple.DebugSymbols (137 - 137) <58A70B66-2628-3CFE-B103-2200D95FC5F7> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
    0x7fffca382000 -     0x7fffca493fff  com.apple.desktopservices (1.11.5 - 1.11.5) <46A9D4F3-1EF8-373C-98A4-AD48D285E484> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x7fffca498000 -     0x7fffca56dfff  com.apple.DiskImagesFramework (444.50.16 - 444.50.16) <EF7030F9-7C0F-37C3-A6AB-3DEF6FC89337> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
    0x7fffca5d6000 -     0x7fffca5e1fff  com.apple.DisplayServicesFW (3.1 - 380) <0BDF6C17-5E5F-33F8-8E99-C7350C6F9667> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
    0x7fffca626000 -     0x7fffca628ffb  com.apple.EFILogin (2.0 - 2) <A74B0065-643F-3BC1-8FE9-E7CEAA29AD9A> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
    0x7fffca77b000 -     0x7fffcabacff7  com.apple.vision.FaceCore (3.3.2 - 3.3.2) <9391D5A3-738C-3136-9D07-518CB43DBADA> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
    0x7fffcabea000 -     0x7fffcaf7cff7  com.apple.FinderKit (1.5.5 - 1.5.5) <85D64484-35E0-3500-A651-FD1DD9A1D6C5> /System/Library/PrivateFrameworks/FinderKit.framework/Versions/A/FinderKit
    0x7fffcbf03000 -     0x7fffcbf03fff  libmetal_timestamp.dylib (600.0.49.9) <E5EED927-1671-3390-BCBB-D76201D63C73> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
    0x7fffcbf10000 -     0x7fffcbf1bff3  libGPUSupportMercury.dylib (14.0.16) <1216909A-E38E-335F-9F46-9362753AE0D1> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
    0x7fffcc1d4000 -     0x7fffcc1f0fff  com.apple.GenerationalStorage (2.0 - 267.1) <3DE1C580-D089-362D-8582-8DE68A3C5F13> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
    0x7fffcc209000 -     0x7fffcc8bbfff  com.apple.GeoServices (1.0 - 1228.24.9.30.34) <96BF97F6-8FF2-3FC4-A8C1-498CB7B0D9A0> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
    0x7fffcc901000 -     0x7fffcc977ff3  com.apple.Heimdal (4.0 - 2.0) <9541C717-96FF-32D3-8F0B-5048525DAA70> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
    0x7fffcc978000 -     0x7fffcc989fff  com.apple.HelpData (2.1.12 - 100.1) <EEB8CC44-9AFF-3005-A25D-18FE46574FD5> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
    0x7fffccf92000 -     0x7fffccf99ffb  com.apple.IOAccelerator (311.16.2 - 311.16.2) <96FA28B6-B03D-3A5E-AF07-0AE4486D2968> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
    0x7fffccf9b000 -     0x7fffccfafff7  com.apple.IOPresentment (1.0 - 29.10) <30DF04EE-10E2-353F-845F-A97B87DF3207> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
    0x7fffccfb0000 -     0x7fffccfd2fff  com.apple.IconServices (74.4 - 74.4) <218DDD05-35F4-3833-B98D-471ED0EBC031> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
    0x7fffcd06e000 -     0x7fffcd07eff3  com.apple.IntlPreferences (2.0 - 216) <15B0DF1F-24C3-3A51-9032-1DD150B7D321> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
    0x7fffcd0b9000 -     0x7fffcd270fff  com.apple.LanguageModeling (1.0 - 123.2.5) <A8CA965F-0399-310D-91C3-B93DDDE9A442> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
    0x7fffcd2bc000 -     0x7fffcd2c0ff7  com.apple.LoginUICore (4.0 - 4.0) <12F7223B-BFCD-3FAF-A016-D5583594BF84> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
    0x7fffcd36c000 -     0x7fffcd42eff3  com.apple.MMCS (1.3 - 385.4) <D3D76CE0-DE05-373E-B757-9E4B4920565D> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
    0x7fffcd8e0000 -     0x7fffcd8e3fff  com.apple.Mangrove (1.0 - 1) <98814966-FD65-302B-B47E-00928DC34E5C> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
    0x7fffcd9bc000 -     0x7fffcd9f0ff3  com.apple.MediaKit (16 - 845) <883DC63F-F90F-3FB9-8C23-9CECD72EBCDE> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
    0x7fffcd9f1000 -     0x7fffcdb51ffb  com.apple.MediaRemote (1.0 - 1) <E1DB72EE-2BA2-34B4-A406-B94955B15B69> /System/Library/PrivateFrameworks/MediaRemote.framework/Versions/A/MediaRemote
    0x7fffcdb52000 -     0x7fffcdb6dffb  com.apple.MediaServices (1.0 - 1) <C7097932-E6BF-396A-B838-785000FBF58D> /System/Library/PrivateFrameworks/MediaServices.framework/Versions/A/MediaServices
    0x7fffcdb91000 -     0x7fffcdc0aff7  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <C323FC94-FFA5-3EE6-B2AC-7E61EA92F304> /System/Library/PrivateFrameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
    0x7fffcdd70000 -     0x7fffcdd7efff  com.apple.MobileKeyBag (2.0 - 1.0) <D0983DB7-EF9D-3E19-A084-21319ECE5846> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
    0x7fffcdd8f000 -     0x7fffcddb7ff7  com.apple.MultitouchSupport.framework (368.16 - 368.16) <E2FE1821-C7CC-3C35-BEB3-6DC693F5128D> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    0x7fffcde69000 -     0x7fffcde74fff  com.apple.NetAuth (6.2 - 6.2) <97F487D6-8089-31A8-B68C-6C1EAC6ED1B5> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
    0x7fffce2c1000 -     0x7fffce2c3fff  com.apple.OAuth (25 - 25) <D6E5F36D-71B8-3E12-9601-CE2A1D6ED60B> /System/Library/PrivateFrameworks/OAuth.framework/Versions/A/OAuth
    0x7fffce74c000 -     0x7fffce78dff3  com.apple.PerformanceAnalysis (1.148.3 - 148.3) <ED3CFDFC-878E-30C2-929B-C2CD43D702DE> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
    0x7fffce7d0000 -     0x7fffce7d7ff3  com.apple.phonenumbers (1.1.1 - 105) <B8EFDDD3-BA26-39B8-9EA0-3649184BF527> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
    0x7fffcedc5000 -     0x7fffcede7fff  com.apple.pluginkit.framework (1.0 - 1) <775E1168-9A28-34EC-AACD-B73803B9DDD4> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
    0x7fffcee3a000 -     0x7fffcee74ffb  com.apple.ProtectedCloudStorage (1.0 - 1) <8B32A7EC-D371-38E3-A286-F1BE1307F1E1> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
    0x7fffcee75000 -     0x7fffcee8ffff  com.apple.ProtocolBuffer (1 - 249.1) <A1F1B0F3-078F-378F-A9A9-0DEEA70E816A> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
    0x7fffcee90000 -     0x7fffcee9fff7  com.apple.QuickLookThumbnailing (1.0 - 1) <173EE873-1700-3FCA-9782-C060FBB5BCAD> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
    0x7fffceea8000 -     0x7fffceecbff3  com.apple.RemoteViewServices (2.0 - 124) <6B967FDA-6591-302C-BA0A-76C4856E584E> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
    0x7fffcfb95000 -     0x7fffcfb98fff  com.apple.SecCodeWrapper (4.0 - 307.50.21) <F8E957B2-D3F0-3B73-B38C-AE8868F00939> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
    0x7fffcfc27000 -     0x7fffcfcb4fff  com.apple.Sharing (696.2.67 - 696.2.67) <F681EE28-153F-3216-97A6-6F5E4148AB2E> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
    0x7fffcfcb5000 -     0x7fffcfcd4ff7  com.apple.shortcut (2.16 - 98) <6C0435B1-83DD-3254-B0D3-3B86C6CE606A> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
    0x7fffcfcd5000 -     0x7fffcff3bfeb  com.apple.SkyLight (1.600.0 - 170.3) <38AC05EF-3A9E-3E3E-9849-04E0223DF7B9> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
    0x7fffd011a000 -     0x7fffd0126ff7  com.apple.SpeechRecognitionCore (3.3.2 - 3.3.2) <684BD1EA-8268-331C-A5A9-080EB375C658> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
    0x7fffd04b0000 -     0x7fffd0511fff  com.apple.Suggestions (6.0 - 197) <9DD142A2-82A5-3202-B36C-20E19B4C5D56> /System/Library/PrivateFrameworks/Suggestions.framework/Versions/A/Suggestions
    0x7fffd0812000 -     0x7fffd0886fdf  com.apple.Symbolication (62048.1) <1A30ED19-7532-3F46-9DD3-9879A973D0CF> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
    0x7fffd0aa6000 -     0x7fffd0ad2ff3  com.apple.framework.SystemAdministration (1.0 - 1.0) <CD5B74B1-01ED-369E-AB11-1DA59F2C2A24> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
    0x7fffd0cc5000 -     0x7fffd0ccbff7  com.apple.TCC (1.0 - 1) <911B534B-4AC7-34E4-935E-E42ECD008CBC> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
    0x7fffd0d57000 -     0x7fffd0e1dff7  com.apple.TextureIO (2.8 - 2.8) <3D61E533-4156-3B21-B7ED-CB823E680DFC> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
    0x7fffd0e66000 -     0x7fffd0e7bff3  com.apple.ToneKit (1.0 - 1) <B709293D-0A79-398A-8AA9-50F6340C227C> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit
    0x7fffd0e7c000 -     0x7fffd0e8affb  com.apple.ToneLibrary (1.0 - 1) <F2ED5DFC-5F11-3012-BCD7-17753413141F> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
    0x7fffd0e91000 -     0x7fffd0e92fff  com.apple.TrustEvaluationAgent (2.0 - 28.50.1) <EBE65DD5-1732-3747-8C6C-7BECEBF089A4> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
    0x7fffd0e93000 -     0x7fffd1023ff3  com.apple.UIFoundation (1.0 - 490.7) <2A3063FE-1790-3510-8A0E-AEC581D42B7E> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
    0x7fffd1af2000 -     0x7fffd1bb2fff  com.apple.ViewBridge (283 - 283) <25A635B3-C87C-3D3A-ADF3-539713FA1048> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
    0x7fffd1ffd000 -     0x7fffd2003fff  com.apple.XPCService (2.0 - 1) <4B28B225-2105-33F4-9ED0-F04288FF4FB1> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
    0x7fffd2050000 -     0x7fffd20ceff7  com.apple.iLifeMediaBrowser (2.11.2 - 733) <13B4CC92-9DFE-3C01-A519-6E32CC504662> /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Versions/A/iLifeMediaBrowser
    0x7fffd20d4000 -     0x7fffd20d6ffb  com.apple.loginsupport (1.0 - 1) <F3140B97-12C3-35A7-9D3D-43DA2D13C113> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
    0x7fffd2102000 -     0x7fffd2129ff7  com.apple.contacts.vCard (1.0 - 2250.11) <DD615DAF-AF34-3AB4-9CB4-DA0A882D59A5> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
    0x7fffd212b000 -     0x7fffd2146ff7  libCRFSuite.dylib (34) <F78B7F5F-0B4F-35C6-AA2F-84EE9CB22137> /usr/lib/libCRFSuite.dylib
    0x7fffd2147000 -     0x7fffd2152fff  libChineseTokenizer.dylib (21) <0886E908-A825-36AF-B94B-2361FD8BC2A1> /usr/lib/libChineseTokenizer.dylib
    0x7fffd2153000 -     0x7fffd21e3ff7  libCoreStorage.dylib (540.30.1) <85C0A366-F901-36E3-854A-FE8A14A04A72> /usr/lib/libCoreStorage.dylib
    0x7fffd21e4000 -     0x7fffd21e5ff3  libDiagnosticMessagesClient.dylib (102) <84A04D24-0E60-3810-A8C0-90A65E2DF61A> /usr/lib/libDiagnosticMessagesClient.dylib
    0x7fffd21e6000 -     0x7fffd23f9fff  libFosl_dynamic.dylib (16.39) <E22A4243-D148-3C74-BA15-2D906A3D1F9E> /usr/lib/libFosl_dynamic.dylib
    0x7fffd2415000 -     0x7fffd241cfff  libMatch.1.dylib (27) <70D4BD2A-9383-37F2-B0D6-9B592D236601> /usr/lib/libMatch.1.dylib
    0x7fffd241d000 -     0x7fffd241dfff  libOpenScriptingUtil.dylib (172.1) <0F1BA407-97D1-36F6-882D-A355EAAD5E00> /usr/lib/libOpenScriptingUtil.dylib
    0x7fffd241e000 -     0x7fffd2422ffb  libScreenReader.dylib (477.40.6) <CBE6420C-EF60-3ACD-A0B6-7CBE936BA3B8> /usr/lib/libScreenReader.dylib
    0x7fffd2423000 -     0x7fffd2424ffb  libSystem.B.dylib (1238.60.2) <ACC3231B-370F-3235-8E5F-159E094FC3F9> /usr/lib/libSystem.B.dylib
    0x7fffd2490000 -     0x7fffd24bbff3  libarchive.2.dylib (41.70.2) <907D1FB1-9A65-33F5-AFC8-0B6E5AE9D83A> /usr/lib/libarchive.2.dylib
    0x7fffd24bc000 -     0x7fffd2538fc7  libate.dylib (1.12.13) <D0767875-D02E-3377-84D8-5F174C27BEA9> /usr/lib/libate.dylib
    0x7fffd253c000 -     0x7fffd253cff3  libauto.dylib (187) <34388D0B-C539-3C1B-9408-2BC152162E43> /usr/lib/libauto.dylib
    0x7fffd253d000 -     0x7fffd254dff3  libbsm.0.dylib (34) <20084796-B04D-3B35-A003-EA11459557A9> /usr/lib/libbsm.0.dylib
    0x7fffd254e000 -     0x7fffd255cff7  libbz2.1.0.dylib (38) <ADFA329A-DCE7-356D-8F09-A3168DFC6610> /usr/lib/libbz2.1.0.dylib
    0x7fffd255d000 -     0x7fffd25b3ff7  libc++.1.dylib (307.5) <0B43BB5D-E6EB-3464-8DE9-B41AC8ED9D1C> /usr/lib/libc++.1.dylib
    0x7fffd25b4000 -     0x7fffd25ddff7  libc++abi.dylib (307.4) <BC271AD3-831B-362A-9DA7-E8C51F285FE4> /usr/lib/libc++abi.dylib
    0x7fffd25de000 -     0x7fffd25eeffb  libcmph.dylib (6) <2B5D405E-2D0B-3320-ABD6-622934C86ABE> /usr/lib/libcmph.dylib
    0x7fffd25ef000 -     0x7fffd2605fcf  libcompression.dylib (39) <F2726F95-F54E-3B21-BCB5-F7151DEFDC2F> /usr/lib/libcompression.dylib
    0x7fffd2606000 -     0x7fffd2606ff7  libcoretls.dylib (121.50.4) <64B1001E-10F6-3542-A3B2-C4B49F51817F> /usr/lib/libcoretls.dylib
    0x7fffd2607000 -     0x7fffd2608ff3  libcoretls_cfhelpers.dylib (121.50.4) <1A10303E-5EB0-3C7C-9165-021FCDFD934D> /usr/lib/libcoretls_cfhelpers.dylib
    0x7fffd26c2000 -     0x7fffd27a6ff7  libcrypto.0.9.8.dylib (64.50.7) <B34BC0FA-18ED-37C5-9D46-393803CADEBB> /usr/lib/libcrypto.0.9.8.dylib
    0x7fffd2938000 -     0x7fffd2943fff  libcsfde.dylib (540.30.1) <0C2B183B-16D9-3D5F-962D-0A09C7063211> /usr/lib/libcsfde.dylib
    0x7fffd2944000 -     0x7fffd2997ff7  libcups.2.dylib (450) <9950BFCB-7882-33C9-9ECF-CE66773C5657> /usr/lib/libcups.2.dylib
    0x7fffd2998000 -     0x7fffd29eafff  libcurl.4.dylib (95.70.4) <D81AEB1D-8501-3EEC-9651-D6D476C2A387> /usr/lib/libcurl.4.dylib
    0x7fffd29eb000 -     0x7fffd29f2ff3  libdscsym.dylib (148.3) <2A78774F-6679-3B72-9903-B295B9825872> /usr/lib/libdscsym.dylib
    0x7fffd2a14000 -     0x7fffd2a14fff  libenergytrace.dylib (15) <A1B040A2-7977-3097-9ADF-34FF181EB970> /usr/lib/libenergytrace.dylib
    0x7fffd2a24000 -     0x7fffd2a29ff7  libheimdal-asn1.dylib (498.50.9) <92C953A2-5E1D-39E9-875E-92F29A12D6FB> /usr/lib/libheimdal-asn1.dylib
    0x7fffd2a2a000 -     0x7fffd2b1cff7  libiconv.2.dylib (50) <42125B35-81D7-3FC4-9475-A26DBE10884D> /usr/lib/libiconv.2.dylib
    0x7fffd2b1d000 -     0x7fffd2d42ffb  libicucore.A.dylib (57167.0.1) <E720801C-2D92-3108-B853-469551EDF21F> /usr/lib/libicucore.A.dylib
    0x7fffd2d48000 -     0x7fffd2d49fff  liblangid.dylib (126) <2085E7A7-9A34-3735-87F4-F174EF8EABF0> /usr/lib/liblangid.dylib
    0x7fffd2d4a000 -     0x7fffd2d63ffb  liblzma.5.dylib (10) <44BD0279-99DD-36B5-8A6E-C11432E2098D> /usr/lib/liblzma.5.dylib
    0x7fffd2d64000 -     0x7fffd2d7aff7  libmarisa.dylib (5) <9030D214-5D0F-30CB-AC03-902C63909362> /usr/lib/libmarisa.dylib
    0x7fffd2d7b000 -     0x7fffd3023ff7  libmecabra.dylib (744.8) <D429FCC9-42A4-38B3-8784-44024BC859EF> /usr/lib/libmecabra.dylib
    0x7fffd3056000 -     0x7fffd30d0ff3  libnetwork.dylib (856.60.1) <191E99F5-4723-3180-8013-02AF2F9AE4B8> /usr/lib/libnetwork.dylib
    0x7fffd30d1000 -     0x7fffd34a3047  libobjc.A.dylib (709.1) <70614861-0340-32E2-85ED-FE65759CDFFA> /usr/lib/libobjc.A.dylib
    0x7fffd34a4000 -     0x7fffd34a5fff  libodfde.dylib (23.50.1) <744F1E66-11EB-3A4D-8944-722F39C55278> /usr/lib/libodfde.dylib
    0x7fffd34a6000 -     0x7fffd34aafff  libpam.2.dylib (21.30.1) <71EB0D88-DE84-3C8D-A2C5-58AA282BC5BC> /usr/lib/libpam.2.dylib
    0x7fffd34ab000 -     0x7fffd34dcfff  libpcap.A.dylib (67.60.2) <B2D36AD8-D5C8-3875-AC81-4787A15E44C2> /usr/lib/libpcap.A.dylib
    0x7fffd34f9000 -     0x7fffd3515ffb  libresolv.9.dylib (64) <A244AE4C-00B0-396C-98FF-97FE4DB3DA30> /usr/lib/libresolv.9.dylib
    0x7fffd3516000 -     0x7fffd354ffff  libsandbox.1.dylib (592.70.2) <FC102F86-0F04-30D4-B680-4B9C5ACDDE36> /usr/lib/libsandbox.1.dylib
    0x7fffd3550000 -     0x7fffd3562ffb  libsasl2.2.dylib (209) <32107C59-22C6-3049-B86E-9C2F85FF549B> /usr/lib/libsasl2.2.dylib
    0x7fffd3563000 -     0x7fffd3564ff3  libspindump.dylib (231.3) <9E50A114-FC58-3E22-9027-5002B60005BE> /usr/lib/libspindump.dylib
    0x7fffd3565000 -     0x7fffd36b3ff7  libsqlite3.dylib (254.8) <1ECF7DF7-7A07-3B4B-A63B-F4EFF6BC7ACF> /usr/lib/libsqlite3.dylib
    0x7fffd370f000 -     0x7fffd375ffff  libstdc++.6.dylib (104.1) <A980E08C-A511-3D19-9881-1D79B7CFF2BA> /usr/lib/libstdc++.6.dylib
    0x7fffd37a4000 -     0x7fffd37a7ff7  libutil.dylib (47.30.1) <88CC63B3-0EDF-306E-9AB5-D87EBE0F3F16> /usr/lib/libutil.dylib
    0x7fffd37a8000 -     0x7fffd37b5fff  libxar.1.dylib (357) <69547C64-E811-326F-BBED-490C6361BDCB> /usr/lib/libxar.1.dylib
    0x7fffd37b6000 -     0x7fffd38a5ff3  libxml2.2.dylib (30.18) <75135C3D-47B1-3217-AC2B-B566E2E1A4A3> /usr/lib/libxml2.2.dylib
    0x7fffd38a6000 -     0x7fffd38cffff  libxslt.1.dylib (15.9.1) <A1EFC225-2115-3710-A2FD-B11FDE15B01F> /usr/lib/libxslt.1.dylib
    0x7fffd38d0000 -     0x7fffd38e1ff3  libz.1.dylib (67) <46E3FFA2-4328-327A-8D34-A03E20BFFB8E> /usr/lib/libz.1.dylib
    0x7fffd38f0000 -     0x7fffd38f4ff7  libcache.dylib (79) <093A4DAB-8385-3D47-A350-E20CB7CCF7BF> /usr/lib/system/libcache.dylib
    0x7fffd38f5000 -     0x7fffd38fffff  libcommonCrypto.dylib (60092.50.5) <8A64D1B0-C70E-385C-92F0-E669079FDA90> /usr/lib/system/libcommonCrypto.dylib
    0x7fffd3900000 -     0x7fffd3907fff  libcompiler_rt.dylib (62) <55D47421-772A-32AB-B529-1A46C2F43B4D> /usr/lib/system/libcompiler_rt.dylib
    0x7fffd3908000 -     0x7fffd3910fff  libcopyfile.dylib (138) <819BEA3C-DF11-3E3D-A1A1-5A51C5BF1961> /usr/lib/system/libcopyfile.dylib
    0x7fffd3911000 -     0x7fffd3994fdf  libcorecrypto.dylib (442.50.19) <65D7165E-2E71-335D-A2D6-33F78E2DF0C1> /usr/lib/system/libcorecrypto.dylib
    0x7fffd3995000 -     0x7fffd39c6fff  libdispatch.dylib (703.50.37) <6582BAD6-ED27-3B30-B620-90B1C5A4AE3C> /usr/lib/system/libdispatch.dylib
    0x7fffd39c7000 -     0x7fffd39ccffb  libdyld.dylib (433.5) <128FF2BB-D0C8-36D9-A456-C1077E7BB182> /usr/lib/system/libdyld.dylib
    0x7fffd39cd000 -     0x7fffd39cdffb  libkeymgr.dylib (28) <7AA011A9-DC21-3488-BF73-3B5B14D1FDD6> /usr/lib/system/libkeymgr.dylib
    0x7fffd39ce000 -     0x7fffd39dafff  libkxld.dylib (3789.73.8) <CE95DAA4-068A-369A-95CF-3AE472FC4F34> /usr/lib/system/libkxld.dylib
    0x7fffd39db000 -     0x7fffd39dbfff  liblaunch.dylib (972.70.1) <B856ABD2-896E-3DE0-B2C8-146A6AF8E2A7> /usr/lib/system/liblaunch.dylib
    0x7fffd39dc000 -     0x7fffd39e1ff3  libmacho.dylib (898) <17D5D855-F6C3-3B04-B680-E9BF02EF8AED> /usr/lib/system/libmacho.dylib
    0x7fffd39e2000 -     0x7fffd39e4ff3  libquarantine.dylib (85.50.1) <12448CC2-378E-35F3-BE33-9DC395A5B970> /usr/lib/system/libquarantine.dylib
    0x7fffd39e5000 -     0x7fffd39e6ffb  libremovefile.dylib (45) <38D4CB9C-10CD-30D3-8B7B-A515EC75FE85> /usr/lib/system/libremovefile.dylib
    0x7fffd39e7000 -     0x7fffd39ffff7  libsystem_asl.dylib (349.50.5) <096E4228-3B7C-30A6-8B13-EC909A64499A> /usr/lib/system/libsystem_asl.dylib
    0x7fffd3a00000 -     0x7fffd3a00ff7  libsystem_blocks.dylib (67) <10DC5404-73AB-35B3-A277-A8AFECB476EB> /usr/lib/system/libsystem_blocks.dylib
    0x7fffd3a01000 -     0x7fffd3a8efef  libsystem_c.dylib (1158.50.2) <E5AE5244-7D0C-36AC-8BB6-C7AE7EA52A4B> /usr/lib/system/libsystem_c.dylib
    0x7fffd3a8f000 -     0x7fffd3a92ffb  libsystem_configuration.dylib (888.60.2) <BECC01A2-CA8D-31E6-BCDF-D452965FA976> /usr/lib/system/libsystem_configuration.dylib
    0x7fffd3a93000 -     0x7fffd3a96fff  libsystem_coreservices.dylib (41.4) <7D26DE79-B424-3450-85E1-F7FAB32714AB> /usr/lib/system/libsystem_coreservices.dylib
    0x7fffd3a97000 -     0x7fffd3aaffff  libsystem_coretls.dylib (121.50.4) <EC6FCF07-DCFB-3A03-9CC9-6DD3709974C6> /usr/lib/system/libsystem_coretls.dylib
    0x7fffd3ab0000 -     0x7fffd3ab6fff  libsystem_dnssd.dylib (765.50.9) <CC960215-0B1B-3822-A13A-3DDE96FA796F> /usr/lib/system/libsystem_dnssd.dylib
    0x7fffd3ab7000 -     0x7fffd3ae0ff7  libsystem_info.dylib (503.50.4) <611DB84C-BF70-3F92-8702-B9F28A900920> /usr/lib/system/libsystem_info.dylib
    0x7fffd3ae1000 -     0x7fffd3b03ff7  libsystem_kernel.dylib (3789.73.8) <7F77BDE8-93F4-3A2D-B864-95AE10DCEA60> /usr/lib/system/libsystem_kernel.dylib
    0x7fffd3b04000 -     0x7fffd3b4bfe7  libsystem_m.dylib (3121.6) <86D499B5-BBDC-3D3B-8A4E-97AE8E6672A4> /usr/lib/system/libsystem_m.dylib
    0x7fffd3b4c000 -     0x7fffd3b6aff7  libsystem_malloc.dylib (116.50.8) <A3D15F17-99A6-3367-8C7E-4280E8619C95> /usr/lib/system/libsystem_malloc.dylib
    0x7fffd3b6b000 -     0x7fffd3bc4ffb  libsystem_network.dylib (856.60.1) <369D0221-56CA-3C3E-9EDE-94B41CAE77B7> /usr/lib/system/libsystem_network.dylib
    0x7fffd3bc5000 -     0x7fffd3bceff3  libsystem_networkextension.dylib (563.60.2) <B021F2B3-8A75-3633-ABB0-FC012B8E9B0C> /usr/lib/system/libsystem_networkextension.dylib
    0x7fffd3bcf000 -     0x7fffd3bd8ff3  libsystem_notify.dylib (165.20.1) <B8160190-A069-3B3A-BDF6-2AA408221FAE> /usr/lib/system/libsystem_notify.dylib
    0x7fffd3bd9000 -     0x7fffd3be1fe7  libsystem_platform.dylib (126.50.8) <897462FD-B318-321B-A554-E61982630F7
Offline basskep
Re: Preprocessing integration error
« Reply #2 on: 2018 October 21 04:31:04 »
I was also facing MRS noise evaluation errors as you can see in attachment
Offline basskep
« Reply #3 on: 2018 October 21 04:41:25 »
I could try to install PI on Windows and see if I am facing the same issue but normally PI is compatible with MacOSX 10.12.6 right ?
For information my light frames comes from Sharpcap 3.1 and they were registered in raw16 format. I really don't know why PI tells me that my light frames are "empty file". There are datas inside. Maybe the file format don't suit ?
I could upload a light frame header if necessary.
Thanks for your help.
Offline basskep
« Reply #4 on: 2018 October 24 05:48:09 »
Is there anybody from PI Team who can help please ?
« Reply #5 on: 2018 October 24 09:35:34 »
'empty file' likely means the calibration is bad for some reason. perhaps mismatched dark frame or double subtraction of bias.
i have never seen crashes like this on OSX but i suppose it could be related to the corrupt frames.
Offline basskep
« Reply #6 on: 2018 October 24 10:32:10 »
Hi Rob thx for your reply.
I did another test with another Mac with MacOSX 10.13.6 and the same frames and I don't have any errors ! How is it possible ?
Is there some bugs with PI on 10.12.6 ? Or maybe some issues with installation. I will try to reinstall PI on this platform and let you know.
« Reply #7 on: 2018 October 24 10:44:13 »
i don't have a machine with 10.12.6 installed. i think i may have gone from 10.11 to 10.12 so i may have never used 10.12. i don't know what OS juan is using to develop PI. im sure lots of people are using or have used 10.12 with PI and it was probably fine though or the forum would be full of complaints...
Offline basskep
« Reply #8 on: 2018 October 24 10:55:58 »
Is that a question that you can ask to Juan please ? Because I searched on the forum for the same issue I was facing and just find 1 thread about it.
« Reply #9 on: 2018 October 24 14:00:31 »
unfortunately i'm just a PI user just like you; i don't have any way to ask juan your question other than posting here.
PTeam is kind of a loose concept  :)
Offline basskep
« Reply #10 on: 2018 October 24 15:30:22 »
Wow sorry I thought that you were part of the PTeam as a master Jedi :-)
So there is only one person who develop PI (Juan) ?
« Reply #11 on: 2018 October 24 16:54:00 »
indeed, there are a few other people who have contributed code but almost all of them are users as well.
Offline basskep
« Reply #12 on: 2018 October 25 05:25:46 »
Hi Rob thank you for the information. I just have a last question : sometimes i have a failure at the end of the integration with MRS Noise evaluation fail. And if i uncheck the Evaluation Noise for integration everything is ok until the end but i have a completely grey image. Do you know what does it mean ?
Offline basskep
« Reply #13 on: 2018 October 25 07:12:33 »
Rob you will find below the error
« Reply #14 on: 2018 October 25 08:52:45 »
i believe your calibration is bad, you should post your calibration masters and an uncalibrated light.
