www.pixinsight.com
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
https://pixinsight.com/forum/
News:
Home
Help
Search
Login
Register
PixInsight Forum (historical)
PixInsight
Bug Reports
CatalogStarGenerator
« previous
next »
Print
Pages: [
1
Author
Topic: CatalogStarGenerator (Read 884 times)
ppistor
Newcomer
on:
2018 October 18 10:14:06 »
Using CatalogStarGenerator v2.1.5, I generated two star fields with the same set of parameters, except for the observation data (one: 1900.01.01, the other: 2018.08.12). The resulting fields
do not differ. Is this a bug or a feature?
Peter.
Logged
dld
PixInsight Addict
Re: CatalogStarGenerator
Reply #1 on:
2018 October 18 11:14:06 »
Hi Peter, maybe there aren't any stars with high enough proper motion within your field. How about trying the same for a starfield around Barnard's Star?
Sadly I'm away from PI to try by myself
Logged
Andres.Pozo
PTeam Member
PixInsight Padawan
Reply #2 on:
2018 October 18 12:51:03 »
Which catalog did you use? Not every catalog has proper motion data.
See this message for an example using Gaia DR2:
https://pixinsight.com/forum/index.php?topic=12447.msg76129#msg76129
Logged
Gallery @ Astrobin
dld
PixInsight Addict
Reply #3 on:
2018 October 18 13:51:28 »
Well, for the default catalog (PPMXL) and for a 2 degree FOV centered at Barnard's Star, the script (apparently) works as expected!
Logged
ppistor
Newcomer
Reply #4 on:
2018 October 30 10:03:32 »
Here are some parameters used by the CatalogStarGenerator:
RA: 2h 29 39.59
DEC: 58°56 24.6
Image size: 3927x3584
Projection: Stereographic
Resolution: 48.7"/px
Obviously a wide field image. Therefore I used the Bright Star Catalog.
Peter.
Logged
Andres.Pozo
PTeam Member
PixInsight Padawan
Reply #5 on:
2018 October 30 10:53:53 »
BrightStars Catalog has proper motion data but in wide field images the motion is usually too small to make a visible difference.
In any case, with the parameters that you are using I can see movement in a few stars between 1918 and 2018.
Logged
Gallery @ Astrobin
Print
Pages: [
1
« previous
next »
PixInsight
Bug Reports
