Author Topic: Overscan newb questions  (Read 1719 times)
Offline mmnb
« on: 2018 October 15 18:11:08 »
I just got a camera (QHY 16200A) with overscan capabilities, wanted to check my understanding to see if I have this right:
Previously I created a master bias according to the Light Vortex tutorials with a camera that did not have overscan.  I should be able to use the overscan capability to do better bias correction for an image.  Because the bias is dependent on the state of the (non-cooled) components in the camera, overscan provides better correction than a master bias frame from an average of a bunch of rapidly acquired bias images.
The bias for a given image is determined by taking the overscan region, averaging columns and fitting a smooth representation of bias *along* the columns.  This is done for *all* images (lights, darks, flats).  The master bias (now the zero frame) is also corrected this way.  The zero frame is still subtracted from darks, flights and flats the way the original master bias would have been.  All of this is done simply by specifying the overscan regions in BatchPreProcessing.
Is that right?  I am not sure what the 'target' region is in the overscan region specification.  Does using the overscan region provide materially better accuracy than simply making a master bias out of a quickly acquired set of bias frames?
Offline RickS
Re: Overscan newb questions
« Reply #1 on: 2018 October 15 20:24:53 »
I use overscan calibration with an Apogee U16M camera.  The reason I started doing it was because my camera shows significant variation in the bias offset between frames taken at different times.  If you have a camera that has a stable bias offset then it's not worth the extra bother.
Your explanation sounds about right.  You have to capture all the calibration and light frames with overscan included.  I can't remember exactly how the calbration calculations are done but the idea is that the overscan region is used to correct for variations in the bias offset between frames.
To figure out which areas in the expanded frame are actually overscan you may need to ask the camera manufacturer.  How they map non-image areas of the sensor to the image read out of the camera can vary.
If your camera suffers from significant bias variation then I think that overscan calibration is definitely worth doing, especially if you are chasing dim objects.
Rick.
Offline bulrichl
« Reply #2 on: 2018 October 16 01:54:42 »
The following links could be helpful for you:
https://pixinsight.com/forum/index.php?topic=10900   and the websites cited in post #8
www.iceinspace.com.au/forum/showthread.php?t=112592
Bernd
