Author Topic: Has anybody tried processing an image taken with the new OPT Triad filter?  (Read 1384 times)
Offline STEVE333
    • sk-images
Hi - I'm thinking about getting the OPT Triad filter to help with my bad LP. I"m currently using an IDAS LPS-V4 filter and having some good success. The Triad filter has narrower spectral bandpasses, so, it should further reduce my LP noise.
Has anybody processed any images taken using the OPT Triad filter?
How did the filter work for you?
Thanks in advance for any feedback.
Camera:  Canon T3 (modified)
Mount:  CEM40 EC
Offline STEVE333
    • sk-images
FYI -
I purchased the Triad Tri-Band filter. It took about 5 weeks to arrive because it was backordered and I was on a waiting list.
I took 3 hours worth of 9 min exposures on the Heart Nebula with the filter and my Canon T3 and a WO Star71 (Gen 2) telescope. The BYEOS histogram is shown in the first attachment. As expected (based on many calculations) the B/G channel histograms were at about 25% which is fine. For comparison, with the IDAS LPS-V4 filter I was only able to use 3 min exposures to achieve similar histogram readings.
I used the same PI processing workflow that I've been using for all my images with LP filters. I used PCC for color correction, and, colors came out very reasonable. Processing was easier than usual because the filter greatly reduces the LP gradient. The stacked image also had lower noise than with the IDAS LPS-V4 filter or the IDAS LPS-D1 filter for similar total exposure times, so, the image has nice details.
The filter/camera combination basically captures Ha and Oiii data, so, HOO processing is certainly an option.
The final processed image is shown in the second attachment.
I really like this filter so far. It produced a superior image to what I was able to capture in the past with the other filters. I have about 25 other targets already picked out. It's exciting to be able to capture better data from my high LP location. It's kind of a "poor man's" approach to NB imaging (although the Triad Tri-Band filter costs $775 for a 2" filter, so, not for the very poor!).
Mount:  CEM40 EC
Offline RickS
Nice result, Steve!  I gave up on doing anything other than full NB from home.
Offline STEVE333
    • sk-images
Thanks Rick - I am hoping that I won't have to go full NB (filters, filter wheel, another wire hanging from scope, etc.). Time will tell.
Mount:  CEM40 EC
Offline Lammertus
I've been using the Triad filter for a couple of months now and the only thing
I can say is that it works great.
It is used either with a Maksutov at 1900mm fl or an APO at 550 mm and
processing is quit easy.
Nowadays I use APP for preprocessing and Pixinsight for the final work.
This is IC1396: 50x180 seconds
Lammertus
Lammertus,
Good to know, but please remember that this is PixInsight Forum, not a general forum where you can talk about any application freely. We are interested exclusively in PixInsight here, especially when talking about other products adds no value to the discussion.
Offline Lammertus
Ok, got your point, no offense, if you like please delete my entry!!
Lammertus
Thank you, don't worry, there's no need to delete (almost) anything on this forum ;)
Offline Lammertus
In my reply I forgot to mention that I used deconvolution and
finally resampled the image 50% down ( since I used Bayer drizzle ).
Also did some noise reduction ( ACDNR ).
Color balance seems to be quit neutral with the Triad filter.
I also imaged a lot using the IDAS-LPV4 filter I also have but
with this filter, from the balcony it seems it is much easier to
get reasonable good signal ( even with full moon and local football
club stadium lights on )
Offline STEVE333
    • sk-images
Thanks Lammertus. I haven't been back to this thread for some time and missed this response.
My Triad filter came in and I love it! Color balance seems pretty easy with PI (as you mentioned). It also reduces the LP gradient significantly which eases processing.
Your response is much appreciated.
Mount:  CEM40 EC
