Author Topic: DSLR H-alpha general workflow question  (Read 1781 times)
Offline Goran
« on: 2018 September 25 09:58:27 »
Hi!
Very new to Pixinsight so sorry if this has come up before but I've really searched for a method but haven't got it to work.
So.
The intended workflow as I understand it is to:
1: Calibrate the Ha light frames with the bias, flats and darks, ticking the "only calibrate" box.
2: Use the Split CFA script on those calibrated frames.
3: Do a star align with the frames in the "0" folder (red channel).
4. Register the result.
Is this a valid workflow?
When I try to do the step 2 the script is doing it's thing but nothing gets saved.
Is there a better workflow to stack Ha frames from a DSLR?
Thank's!
/Göran
« Last Edit: 2018 September 25 10:34:43 by Goran »
Offline acmalko
Re: DSLR H-alpha general workflow question
« Reply #1 on: 2018 September 25 10:29:09 »
I use this workflow apart from bias caus I prefer using darks_flats
1- split_cfa on lights, darks, flats, bias
2- Integrate bias_cfa0 to obtain a masterbias_cfa0
3- Integrate darks_cfa0 to obtain a masterdark_cfa0
4- calibrate flats_cfa0 with masterbias_cfa0
5- Integrate flats_cfa0 to obtain a masterflat_cfa0
6- Calibrate lights_cfa0 with masterbias_cfa0, masterdark_cfa0+calibrate, masterflat_cfa0
7-Cosmetic correction using essentially the masterdark_cfa0
8- Subframe_selector for weighting
9- Alignment + drizzle data (with a synthetic star field)
10- Integration
11- Drizzle integration factor 2, 0.9
 :smiley:
Offline Goran
« Reply #2 on: 2018 September 25 10:33:11 »
Wow, thank's!
Need to read through this a couple of times now to try to understand.  :D
Offline Goran
« Reply #3 on: 2018 September 25 10:42:06 »
Thing is, nothing gets saved when I use the split CFA script...  :-\
Offline acmalko
« Reply #4 on: 2018 September 25 10:51:16 »
Honestly, I don't know.
Be sure to have configured the DSLR Raw on "pure raw" (format explorer and double-click on dslr raw)
Be sure to have filled a correct path in the Split_cfa process if the default one doesn't work and a pre- or postfix like "cfa_"
Offline Goran
« Reply #5 on: 2018 September 25 11:00:11 »
Thank you!
I have pure raw checked and set the split CFA to a specific output folder... So strange...
