Author Topic: Star Colors after LRGBCombination  (Read 2331 times)
Offline Franky
« on: 2018 August 22 08:34:31 »
Hi Guys,
I have some issue with my star colors.
Background: When processing narrwoband SHO I remove all stars and process all images seperately from luminance. At the end of my work I combine the colored tonemap image with the luminance using LRRGCombination (after stretching, etc.).
Problem: Some of the stars are colored red, when the background nebula is also red (or blue if background ist blue). It seems to be get worse when using ChromianceNoiseReduction in LRGBCombination options... But for me this option is mandatory to get good looking colors without sprinkles in the nebula. I tried a lot, also for example removing the colors in tonemap image by using a star mask and then combine with luminace. Overall it's getting better - but not sufficient…
I added an example:
Left side (from top to bottom): Tonemap image; LRGB without ChromianceNoiseReduction; LRGB with ChromianceNoiseReduction
Right side (from top to bottom): Tonemap image with removed colors using a StarMask; LRGB without ChromianceNoiseReduction; LRGB with ChromianceNoiseReduction
Is there any idea, how to get rid of these colored stars?
Frank
Offline aworonow
    • Faint Light Photography
Re: Star Colors after LRGBCombination
« Reply #1 on: 2018 August 22 09:16:52 »
you might try astro-imaging-insights.com > Methods > Annoying little red stars
Alex
Offline Franky
« Reply #2 on: 2018 August 24 14:02:26 »
Thanks Alex for your reply!
Read the article and tried it, but it's not working for me. Problem is, that also bigger sized stars are badly colored...
Any other ideas?
Frank
Offline RickS
« Reply #3 on: 2018 August 24 18:24:21 »
Star mask and a reduce saturation curve?
Offline Franky
« Reply #4 on: 2018 August 25 03:21:21 »
Hi Rick,
that was of course my very first idea. Obviously I don't find the correct values for the Star Mask to get all these tiny stars.  :-\ Is there somewhere a known tutorial for that?
Frank
