Author Topic: Problem with File Format  (Read 1888 times)
Offline Hank
« on: 2018 June 30 10:04:54 »
I had clear skies last night and decided to image M5 and I saved the images to an external hard drive.
I started processing them in Pixinsight this morning starting with "Blink". Next I moved on to "Sub-frame Selector" and ran into difficulties. See attached file.
Imaging Information: C11" with 6.3 focal reducer, SBIG STF8300C, Moonlight Focuser, The SkyXPro, all on a MtY mount. BTW, I set up The SkyXPro for FITS format.
Any suggestions as to what I'm doing incorrectly?
Hank
Re: Problem with File Format
« Reply #1 on: 2018 June 30 12:21:46 »
couple of possibilities - one is that the external disk filled up and the fits file is corrupted. another is the presense of spaces in the filename. PI should be able to handle this but there are situations where it does not. could be related to the filesystem format on the external disk... is it NTFS or some other windows format?
Offline John_Gill
« Reply #2 on: 2018 June 30 13:43:14 »
I think the problem is that the file name has two full stops.  Rename the file, with the only full stop just before the tiff extension.
Look up
John
APM 107/700 apo on CGX mount
ZWO Optics - Autoguiding
ZWO1600mm and filters
Offline Hank
« Reply #3 on: 2018 July 02 07:09:03 »
Thanks, Rob and John.
Yes, it turns out that the spaces in the file name caused my problem. I removed them and now everything is working.
Hank
