Author Topic: register new images with existing ones  (Read 2432 times)
Offline alcol
« on: 2018 June 19 11:18:22 »
Hi folks, looking for advice.
If I have a batch of images that I calibrate, register and integrate. Can I save one of the registered images from this batch so that if I take more images at a later date I can simply register them against the saved registered image from the earlier batch?
Thanks for clarification.
Offline chris.bailey
Re: register new images with existing ones
« Reply #1 on: 2018 June 19 14:26:11 »
I always 'mark' the image I use for registration with an _* i.e M42_L_600_* so if I add more images at a later date I can register them to the same one.
Offline alcol
« Reply #2 on: 2018 June 19 14:34:10 »
Thanks Chris much appreciated
Offline John_Gill
« Reply #3 on: 2018 June 19 23:25:23 »
For DSLR images I process each nights images up to and including the debayer process.  Then use the script "SubFrameSelector" to find the best SNR and Eccentricity image for all the images.  I guess you can use your predefine best image as the reference.  I then continue to StarAlignment and add all the debayered images for various night and continue the pre-processing with LocalNormalization, ImageIntegration and sometime DrizzleIntegration.
I assume the process is very similar for CCD images, except there is no Debayer required.
Look up
John
APM 107/700 apo on CGX mount
ZWO Optics - Autoguiding
ZWO1600mm and filters
Offline GJL
« Reply #4 on: 2018 June 20 02:27:36 »
For each image I have a Word file, in which I enter all data and parameters. The reference image for image integration is also listed.
Offline GJL
« Reply #5 on: 2018 June 20 02:30:25 »
The reference image for ImageRegistration was meant.
Offline alcol
« Reply #6 on: 2018 June 20 05:07:32 »
Thanks everyone, most helpful.
