Author Topic: Flat - DARK and BIAS calibrated - Is it worth it?  (Read 2064 times)
Offline Armando
« on: 2018 June 14 08:09:49 »
do you think it's worth calibrating flat frames by Master BIAS and Master Dark (BIAS subtracted and then optimized)?
I'm going to take flat frames with 1.3s exposure time by a temperature controlled KAF 8300 CCD. I still don't know if Pixinsight will find a correlation between the flats_masterBiasSubtracted and masterDark_masterBiasSubtracted...
What I know is that I noticed no correlation was often reported when using a DSLR when calibrating the flat frames so that, to calibrate flat frames taken by DSLR, I'm used to opt only for bias calibration.
Armando
Offline RickS
Re: Flat - DARK and BIAS calibrated - Is it worth it?
« Reply #1 on: 2018 June 14 13:51:09 »
For short flats I only use bias for calibration but I run the sensor pretty cold.  How well this works will depend on the characteristics of your camera.
Offline chris.bailey
« Reply #2 on: 2018 June 14 14:46:06 »
Flats on the KAF8300 need to be several seconds long to avoid the shutter causing shadowing.
For short duration RGB flats I tend to only Bias subtract my flats but for longer duration narrowband i take a series of say 30 second darks and then Bias/Dark/Optimise.
Chris
