Author Topic: Photometric Color Calibration Error Message  (Read 3756 times)
Offline cuivenion
« on: 2018 June 04 22:11:47 »
Hi I get this message when trying to use PCB:
Photometry process finished:
   3 of 3 images processed successfully.
   0 images with errors.
*** Error: Insufficient photometric data: Got 3 sample(s); at least 5 are required.
I've tried increasing the magnitude (to a maximum of 17), increasing sensitivity, adjusting saturation level, and having distortion correction and force plate solving enabling. I have seen threads with similer problems but none of the solutions seem to work in my case. The image has had Crop, DBE and Background Neutralization applied. Please find attached a log of a PCB attempt with default settings. Thanks for the help.
Offline John_Gill
Re: Photometric Color Calibration Error Message
« Reply #1 on: 2018 June 04 23:28:39 »
I am not sure what the solution is, but try this.  Copy your three images to the same location, but with different names.  Now try the PCC with the 6 images.
Look up
John
APM 107/700 apo on CGX mount
ZWO Optics - Autoguiding
ZWO1600mm and filters
Offline cuivenion
« Reply #2 on: 2018 June 05 00:08:53 »
Sorry, I'm not following that.
Offline John_Gill
« Reply #3 on: 2018 June 05 01:54:18 »
Sorry, I thought that maybe more images were required.  Ooops!
Offline cuivenion
« Reply #4 on: 2018 June 05 03:01:56 »
Possibly John, I just thought the PCB was automated and found the images itself. I'm not sure what you where proposing, I'm still new to Pixinsight.
Offline kkretzsch
« Reply #5 on: 2018 June 05 03:33:11 »
HI,
the error message comes from the fitting procedure to evaluate the white balance
http://pixinsight.com/tutorials/PCC/#PCC_Specific_Features -> Interactive Graphs
I think the image that causes the problem does not contain enough stars.
Klaus
« Reply #6 on: 2018 June 05 05:18:31 »
Can you upload the image to somewhere like dropbox and share the link. This would help.
Offline cuivenion
« Reply #7 on: 2018 June 06 10:15:54 »
Hi, no probs I'll sort that out.
Offline cuivenion
« Reply #8 on: 2018 June 06 10:28:46 »
This is the original integrated file before cropping, DBE or background neutralization.
https://www.dropbox.com/s/dvq8p0o5mh1ffm5/Autosave.tif?dl=0
« Reply #9 on: 2018 June 06 14:30:17 »
I had no problem using PCC with your M27 image. I didn't even change anything, just used the default settings.
« Reply #10 on: 2018 June 06 14:40:16 »
Thought I would add this. The plate solving that PI uses has good latitude if the image is good. HEre is just such a case. Notice that the settings were for 1000mm yet the solved image is 2400mm. This is why I tend to start with the default settings. If the image has issues then you might be looking at making changes.
Offline cuivenion
« Reply #11 on: 2018 June 06 17:50:24 »
Thats weird my focal length was 1000mm not 2400mm.
Offline cuivenion
« Reply #12 on: 2018 June 06 17:53:05 »
Just to add, I started with default parameters too. I only changed them when I ran into a problem.
« Reply #13 on: 2018 June 06 18:29:18 »
Did you drizzle the image? That will change the apparent focal length. What pixel size is your camera? If it's not 9 like the default then that will change the apparent focal length. Those parameters do not need to be precise for ImageSolver to plate solve as you can see. They do need to be precise if you want the reported log information to be correct. Without knowing what camera and scope the best one can do is guess based on knowledge of the objects in an image.
Here is the image solved with PCC but I changed the Pixel size to 5 instead of 9. Now the reported FL is 1334.
Offline cuivenion
« Reply #14 on: 2018 June 06 18:57:10 »
Ah I see, I thought I was supposed to enter the focal length (1000mm) of my scope and the pixel size of the camera which is what I did. I'll give it another go with default FL and pixel size. The pixel size of my camera is 3.75. I didn't drizzle the image but it is cropped.
Thanks for the help. It's much appreciated.
