Author Topic: BPP and cosmetic correction with mixed binning  (Read 1900 times)
Offline UlteriorModem
« on: 2018 May 14 07:38:26 »
I was trying to get a handle on the Batch Preprocessing script using cosmetic correction when I have sub frames with mixed binning.
As an example I have Lum frames binned at 1x1 and a set of RGB binned at 2x2.
Yet the BPP script utilizes a single process icon, that single process icon only uses one master dark. So one has to choose either a master dark binned at 1x1 or 2x2.
How does that work or am I mis-understanding something?
Offline RickS
Re: BPP and cosmetic correction with mixed binning
« Reply #1 on: 2018 May 14 16:00:30 »
You'll need to run BPP twice with different CosmeticCorrection icons.
« Reply #2 on: 2018 May 14 19:14:40 »
Really?
So I need to run BPP for the 1x1 frames, then again for the 2x2 frames?
Almost need to forgo BPP and do it all from scratch.
Offline RickS
« Reply #3 on: 2018 May 14 21:28:09 »
Really?
I can't think of a simple alternative if you're going to reference a master dark in CosmeticCorrection.  It's not that great a hardship, surely?  If you really find it that annoying then don't bin the RGB.  There's no benefit unless your subs are so short as to be read noise limited...
Rick.
« Reply #4 on: 2018 May 15 11:28:36 »
Nah its not really a hardship. It is just that everything else is nicely configured to handle multiple binning configurations ... except CC.
