Hi all,
Welcome to my (first) little (big) PJSR script.
After weeks of procrastination, whilst I failed to find time to polish out the last little blemishes on this script, I feel that I should just publish it here and let others decide whether the script is of any real use.
Fundamentally, the script was written to allow me to determine how well 'other' CMYG deBayer routines work - most of which, in my experience, didn't work that well.
The second driving force behind the exercise was to allow me to get to grips with the process of writing PJSR scripts in the first place - hence the reason that this script is so big !! It has been 'fully' commented. (Well, at least it has been commented as much as I possibly could - to allow others to learn from my experience
It has also had, in places, input and feedback from Juan - in areas where I could not see the PJST solution, or in areas where I was making fundamental PJSR mistakes.
The script does work, and does seem to work quite well for my (amateur-level) data acquisition. Obviously, I have only used it with the Meade DSI-IIC camera, and primarily only with RAW subs obtained from Meade's proprietary 'Envisage' software. However, I have now started using Craig Stark's 'Nebulosity', and will make code adjustments as I discover them.
I certainly hope that someone can at least try out the routine - I would like Juan to be able to include the script with some future release of PI - simply because of the exhaustive commenting. I know that, had I found more comments when I was trying to learn, life would have been somewhat easier !!
