Author Topic: Add Script as a Process Icon?  (Read 2139 times)
Offline joelshort
    • Buckeyestargazer.net
« on: 2018 April 27 16:47:29 »
Is it possible to add the NoiseEvaluation script as a process icon on my workspace?
Joel Short
www.buckeyestargazer.net
Offline RickS
Re: Add Script as a Process Icon?
« Reply #1 on: 2018 April 27 20:45:34 »
Hi Joel,
I faked up an XPSM file that works for me (attached.)  Load or merge it as an icon.  When you double click it, it will display a script dialog.  Click on the Apply Global symbol and voila!
Rick.
Offline joelshort
« Reply #2 on: 2018 April 28 04:58:09 »
PERFECT! Thanks!  You can also just drag the icon over the image which is what I wanted to do.
Can anyone do this in PI, or do you have some secret mojo knowledge to be able to make an XPSM?
Joel Short
« Reply #3 on: 2018 April 28 08:53:47 »
they are just XML files, which are text files... if you have a little bit of programming experience you will be able to figure out what they do and hack them a little bit.
Offline RickS
« Reply #4 on: 2018 April 28 14:29:01 »
Yup.  I just made an icon for another script (one that had a UI that supported saving process icons) and then modified it in a text editor.
