Author Topic: Export To PDF (Revisited)  (Read 2406 times)
Offline blackwatch42nd
« on: 2018 April 27 12:14:51 »
Just did a search for "Export to PDF" and found a single message back in Dec 2017.
The question was where does (if it does) the export to PDF go when selecting the documentation icon at the top of the page?
Thanx
John
Re: Export To PDF (Revisited)
« Reply #1 on: 2018 May 03 11:32:27 »
Anybody out there?  Anyone got a clue?  Anyone got this issue other than me?
John
Offline oldwexi
    • Astronomy Pages G.W.
« Reply #2 on: 2018 May 03 13:00:09 »
Hi John!
Despite printer is activated in my PI,  i cant use the PDF Icon either.
So, wenn i want to view or print documentation (usually i dont read and print documentations ;))
i open the directory where the documentation htmls are located
and view or print all the the HTML with the HTML Browser. The directory
where these are allocated is in the upper right of your documentation window.
Hope somebody has more details which fit more precise to your request,
Gerald
« Reply #3 on: 2018 May 03 13:14:31 »
John
To add to what Gerald is saying if you use a Chromium base browser and this might be true with others you can 'Print' to a PDF which is saved in your downloads directory for your browser. There is also a 'Save as PDF' but in Opera(what I use) that does not work, only Print works.
« Reply #4 on: 2018 May 04 05:56:00 »
Gerald & Mike,
Thanx to both of you for responding.  I am familiar with being able to get the documentation from the windows browser and then being able to print or send to PDF.  Takes time to drill down through the directories whenever you wanted to print/PDF a particular process doc.  Just thought it was very handy to have the PDF option in the doc window of PI.  Apparently from you responses, your's isn't working either.
Do y'all know if this is a bug or just implemented yet?
Thanx
John
« Reply #5 on: 2018 May 04 06:53:28 »
John
The file location is in given at the top where the PDF button is. Just copy and paste that into your browser and the browser will open the document. No looking around needed.
As far as this being a bug or not implemented I don't know. I've never tried to use it.
Offline RalphPaonessa
« Reply #6 on: 2018 August 17 17:51:06 »
I'm also not able to make this work in PI. My default browser is Chrome; but are you saying that the process explorer in PI somehow uses the Windows browser to display the documentation?
I am able to view the documentation in Chrome (and from the PI website). But I was hoping that an exported PDF might have been more readable.
I think this is part of a widespread problem where a lot of online documentation uses very poor layout practices that makes it almost unreadable (a pet peeve of mine). When the font size is too small for the line length, it gets very difficult to read. (For some reason, a great many of the best tutorial websites for PI are very bad at this, and don't use "responsive design." If they did, you could shrink the width of the browser window and the text would re-flow, rather than be clipped at the right.
A page is also more "responsive" when the font size can be resized by the browser zoom; but the page designer has to design for that, otherwise the text just disappears off the right.
One design challenge is when images are in the document flow, and they don't shrink when the window shrinks. Then the image width stops you from narrowing the window (to make the text re-flow). PixInsight images can be a challenge when they need to show the whole screen, which is impossible to read if too small.
Once in a while, a web page has a separately created PDF version with a more readable layout for printing (not simply a copy of the browser page rendered as PDF--that prints the same as the unreadable browser printout).
OK, glad I got that off my chest!  >:D
Ralph
(P.S. The information in the PI documentation is usually very clear, well-written, and informative. But trying to read the details of ImageIntegration right now is making me crazy  >:( )
« Reply #7 on: 2018 August 17 18:48:40 »
My understanding is Chromium is the underlying display for the documentation in PI and is built in to PI directly as Chromium is open source. I could easily be wrong as I am only a user but that's how I read these postings I've included. As far as the font sizes and so on I don't have any issues with my computer so I can't speak to that. I can only speak to how I go about saving the documentation.
https://pixinsight.com/forum/index.php?topic=12115.msg75782#msg75782
https://pixinsight.com/forum/index.php?topic=11281.msg70829#msg70829
