Author Topic: Amp Glow removal  (Read 3253 times)
Offline wboeck
Amp Glow removal
« on: 2018 March 28 04:37:36 »
I have an amp glow from my qhy10. I reduced some of it by unchecking optimizing dark frames during calibration. I then reduced a little more by using DBE tool. However there is still some left. Is the any routine or tutorials showing how to remove it other than cropping my image. Seems like this would be a high priority with all of the new cameras having problems with amp glow.
Offline RickS
Re: Amp Glow removal
« Reply #1 on: 2018 March 28 17:23:35 »
I would make a mask that matches the amp glow and then use HistogramTransformation or CurvesTransformation (or a mix of both) to reduce the glow.  To make the mask, take a stretched monochrome image (extract Lightness if you're working with RGB.)  Blur with Convolution or removal of layers in one of the Multiscale processes.  Black clip with HistogramTransformation to isolate the amp glow.  If there are features in the amp glow, like stars, that you want to protect then use PixelMath to subtract a bit of the original mono image (e.g. "new_mask-orig-mono*0.5" - adjust the scaling factor for best results.)  Now draw a preview around the area with the amp glow and use the SubstituteWithPreview script to copy the preview into a black image.  Clean up with CloneStamp if needed and voila!
Rick.
Offline wboeck
« Reply #2 on: 2018 March 29 04:34:36 »
Thanks, I will give that a try. Wayne
Offline wimvb
    • Wims place
« Reply #3 on: 2018 March 30 12:35:37 »
Darks are the best way to remove amp glow. If you have a master dark that shows the amp glow, but can't completely remove it, why not use that as the mask?
Wim
AZ EQ6 GT + EQ3 PRO, SW 150P-DS, SW MN190, ZWO ASI174MM-Cool, Pentax K20D (retired),
SW ST80 + ZWO ASI120MM + Lin_guider
Offline wboeck
« Reply #4 on: 2018 April 02 04:32:57 »
Yes, I do have a dark with the amp glow. Thanks for the idea
Offline STEVE333
    • sk-images
« Reply #5 on: 2018 April 09 11:42:23 »
Rick.
Clever technique for creating an "isolation mask". Thanks for sharing.
Camera:  Canon T3 (modified)
Mount:  CEM40 EC
Offline gvanhau
« Reply #6 on: 2018 April 12 11:40:50 »
Hello
Normally if darks match the lights the amp glow sould be removed during calibration.
Be aware that your flats should also be calibrated with the apropiate dark flats, else it could be that the remaining amp glow is introduced by your flats.
You can do a test calibrating the ligths without flats to see if there is still ampglow (of course, vignetting and dust dognuts will be present)
Regards
Geert
Geert Vanhauwaert
