Author Topic: How to use Overscan  (Read 2224 times)
Offline tshaug
How to use Overscan
« on: 2018 March 21 05:14:54 »
Hi everybody,
I'm an novice to PixInsight, so please forgive any "stupid" question.
I have a OSC camera (QHY CCD8 Pro) with overscan area.
When I tried to use the overscan area functionality in PI I first thought that it is sufficient to specify the area only in the light frames. but failed on this (I am getting problems with the geometry)
But I have "discovered" that I have to specify the overscan area for darks, flats and bias frames as well otherwise I am not able to do cosmetic correction and image integration.
For darks and bias I am (mis)using the imageCalibration process to specify the overscan area without any further stuff.
I would like to know if I am doing this correctly?
The second question is does it make sense to use the overscan area even when I take darks?
Thomas
« Last Edit: 2018 March 21 05:45:14 by tshaug »
Offline bulrichl
Re: How to use Overscan
« Reply #1 on: 2018 March 21 11:03:29 »
Hi Thomas,
here https://pixinsight.com/forum/index.php?topic=10900 I gave saome links that may help you to understand the concept of overscan calibration.
Bernd
Offline tshaug
« Reply #2 on: 2018 March 21 14:43:33 »
Hi Bernd,
thanks for your advice. So I will read the papers.
I was hoping if somebody can tell me if my "process" is generally ok to "calibrate" all types (light, bias, flat, and dark) of images before doing any image integration.  But I guess that is better to understand more of the background  ;)
Cheers
Thomas
Offline RickS
« Reply #3 on: 2018 March 21 14:47:52 »
Yes, you need to do overscan calibration on bias, dark, flat and light frames.
Offline tshaug
« Reply #4 on: 2018 March 22 14:48:40 »
Hi Rick,
thanks for the clarification.
CS
Thomas
