Author Topic: New Preview  (Read 2389 times)
Offline shammo
New Preview
« on: 2018 March 05 10:57:31 »
I have updated to the very latest version of PI. For some reason now I cannot create a preview by using the mouse and drawing a box around the area I want to select. There isn't anything available except create a new preview which opens a pop up box to define the preview using x-y coordinates. My MacBook still has an older version of PI and the preview is still selectable with the cursor.
Thanks for any help with this issue.
Scott
Offline John_Gill
Re: New Preview
« Reply #1 on: 2018 March 05 11:35:16 »
Try the keyboard shortcut "Alt N", then the cursor should change and you should be able to draw the preview box.  There are two preview icons, one to create the preview and the other to edit the preview.
Look up
John
APM 107/700 apo on CGX mount
ZWO Optics - Autoguiding
ZWO1600mm and filters
Offline shammo
Re: New Preview
« Reply #2 on: 2018 March 05 11:38:30 »
Well...thanks! I had actually tried that because that was the shortcut still available on my MacBook, but i swear it didn't work before I posted this... operator error.
At any rate, that worked, thank you very much!!!
Scott
Offline RickS
Re: New Preview
« Reply #3 on: 2018 March 05 14:17:12 »
If you have turned off "Show Previews" in a window you won't be able to create previews in that window.  I did this a couple of times by accident early in my PI career and it took me a while to figure out!
Offline dwormuth
Re: New Preview
« Reply #4 on: 2018 March 06 08:01:56 »
I've had the same problem several times. I'd always have to Ctrl-Right click and change the mode.  Then I "noticed" the toolbar (red box) and found that it's the easiest way to be able to mouse a preview. Alt/Option-N (blue box) pops the dialog as you mention.
