Author Topic: dynamic crop does not work  (Read 2394 times)
Offline astroCha
« on: 2018 March 01 03:14:16 »
Hello everybody,
can someone give me a tip why dynamic crop does not work? ;)
After cutting out one area and saving this  process, after dragging the process to another image, it appears that a crop is being performed, but not happening on the image!
Where is my mistake? :o
thanks for any help
CS charly
Offline dld
Re: dynamic crop does not work
« Reply #1 on: 2018 March 01 03:30:57 »
Hello Charly,
Try saving a new instance at the desktop before clicking apply!
Clear Skies!
Offline astroCha
« Reply #2 on: 2018 March 02 07:51:52 »
thanks dld
 for the tip.
I've already tried that, strange that it has worked a few months. suddenly the application does not work anymore.
what can I do wrong? :embarassed:
CS charly
Offline astroCha
« Reply #3 on: 2018 March 02 15:53:05 »
hey,
what I have noticed:
in the new instance the new, changed width and height data are not saved!
So the crop can not be applied to other pictures.
I also reinstalled PI !
what happened there? or not ?
regards and  :embarassed:
CS charly
« Reply #4 on: 2018 March 02 17:44:32 »
Here is what I think you are trying to do. The first step using DynamicCrop on the first image mark your area to crop and before executing drag the new instance triangle to the workspace. Step2 execute DynamicCrop using the Check mark. Step3 with the second image to crop, drag your DynamicCrop process icon that you created in Step1 into the second image. That's it. The process icon can be saved and used with any other image.
Offline astroCha
« Reply #5 on: 2018 March 03 03:44:27 »
thanks  Mike for  this instruction,
thats the way i did it !  ???
Unfortunately, this way works no more. Although I have used it so often.
oh dear, what's up?
regards amd CS
charly
« Reply #6 on: 2018 March 03 05:42:44 »
charley
I did that on the latest PI 1.8.5.1353 and also with another computer running 1.8.4.1195.
If you can't find a solution you might try resetting PixInsight to the original settings. Any settings you have made will be deleted in favor of the original as installed. If a parameter became corrupted this should fix that. Worse case is you could uninstall and then reinstall PI.
« Reply #7 on: 2018 March 03 08:35:15 »
you should be able to drag the DynamicCrop step out of the image history of your cropped image and drop it onto your 2nd image, give that a try.
« Reply #8 on: 2018 March 03 09:07:51 »
Your so right. I forgot about that.
Offline astroCha
« Reply #9 on: 2018 March 03 12:43:41 »
hi rob, hi mike :-)))
_drag the DynamicCrop step out of the image history of your cropped image and drop it onto your 2nd image
great , this works  :D
thanks so much ! 8) 8) 8)
charly
PS .Can I repair PI so that the dynamic crop works normally?
