Author Topic: M101  (Read 1997 times)
Offline rdryfoos
M101
« on: 2018 February 17 14:07:51 »
Not yet done--need a bunch of lum and Ha, but this RGB image is a good start.  TOA 130 with .7x reducer and STT-8300.  18 10 min subs in each of RGB, with a synthetic luminance made from 51 RGB subs.  I tried drizzle, but not enough data I guess.  It was OK at small sizes but full resolution was rough
Re: M101
« Reply #1 on: 2018 February 17 14:25:39 »
Rodd
I really like this image. I like the fact that for what data you have you haven't over processed it. That shows in the background and the details in the small secondary objects. Yes with more data you'll be able to bring out more but this is well done. Not every image has to be shown at a high resolution to be enjoyed.
Offline rdryfoos
Re: M101
« Reply #2 on: 2018 February 17 14:27:34 »
Rodd
  Thanks Mike.  I am looking forward to getting more data.  I love this target.  I appreciate your kind words.
Rodd
Offline RickS
Re: M101
« Reply #3 on: 2018 February 17 22:21:01 »
You've got a bit of a red cast in some of the background (especially at top left) but a nice result...
Rick.
Offline rdryfoos
Re: M101
« Reply #4 on: 2018 February 17 22:58:59 »
Rick.
  Thanks...The numbers don't indicate a red cast.  All RGB numbers are about the same pretty much everywhere in the background.  Monitor maybe?
Rodd
Offline RickS
Re: M101
« Reply #5 on: 2018 February 18 01:47:08 »
Hi Rodd,
I did check the numbers to verify my visual impression.  Draw a preview in the top left hand side of the image and check the median values.  Example attached.  Also see DBE extracted background.
Rick.
« Last Edit: 2018 February 18 02:00:37 by RickS »
Offline rdryfoos
Re: M101
« Reply #6 on: 2018 February 18 06:31:09 »
Hi Rodd,
Rick.
  Wow--you must have a sensitive eye! .067 vs .059 (or what ever the number was--something like that).  When I add the luminence (which means a total reprocess of the data) I will be more careful.  Supposed to be clear tonight.
Rodd
Offline rdryfoos
Re: M101
« Reply #7 on: 2018 February 18 06:39:10 »
Hi Rodd,
Rick.
  Maybe this is cheating, but I hit the image with ABE and now the background numbers are the same.  It didn't seem to ruin the image, though I did not inspect in great detail.
Offline RickS
Re: M101
« Reply #8 on: 2018 February 18 12:34:51 »
Looks better  :D
Offline rdryfoos
Re: M101
« Reply #9 on: 2018 February 18 12:43:55 »
Looks better  :D
Thanks Rick.  I am looking forward to reprocessing this with 5-6 hours of lum
Rodd
Offline rdryfoos
Re: M101
« Reply #10 on: 2018 February 19 18:17:06 »
Here is an LRGB with 27 10 min lum subs added.
Offline RickS
Re: M101
« Reply #11 on: 2018 February 19 20:32:17 »
Nice work, Rodd!
Offline rdryfoos
Re: M101
« Reply #12 on: 2018 February 19 21:25:38 »
Nice work, Rodd!
  Thanks Rick.  There are more detains in M101 than I thought.
Rodd
