Yep! (CRTL+PGDN)
I have a tutorial that demonstrates 5 or 6 different ways to blink images/views. This is the one I use most often.
I do not know the reason for it (haven't studied the forum)- but blinking views sure seems like a powerful thing to do.
For example if I wanted to show the evolution of a mask via different parameters... I might want to blink three or more masks (and then do pixel math accordingly).
Or perhaps I need to blink a set of views that represent an image at different points along the processing timeline (history states). And of course, just to simplify
the comparison of two views- a blink tool would be great.
If a blink tool isn't in the cards for PI, what might be equally useful is for a single method to match two views in terms of their window dimensions, position in image, and zoom factor. Dragging and dropping is OK but only works well if you are dragging from right to left with the right view being on top. This is the short distance and does not require worrying about the overlap of images (using the shift key).
Furthermore, if the images are *already* matched in window dimension, position and zoom... and you change one of these elements in one image- a keyboard press to have the other image matched with the new settings without dragging and dropping would help. Even better... something to "connect" the views temporarily so that any change in one is reflected in the other. Since the images are on top of one another exactly..you need to unalign the window, re-drag/drop, and realign.
If I am missing this feature- *please* let me know! Of course, just having the blink tool blink views takes care of everything.
-adam
