Author Topic: Memory leak ?  (Read 873 times)
Offline slash29
Memory leak ?
« on: 2018 January 20 07:50:35 »
I am using Pixinsight 1.08.05.1353 (x86) on a 64 bit Windows 10
Intel Core I6700 CPU 3.4 GHz 8 Gb RAM NVidia GTX 970
After startup of PI, all normal.
After 15 min PI work and opening 3-4 images (they may have already been closed again too) PI starts to become laggy, mouse moves are slow etc.
Especially, opening file selector boxes takes 10-30 s ...
It feels as if there is a progressive memory leak.
It seems as if this has been caused by one of the recent updates.
No problems with previous versions on the same system.
Help please.
Best regards
rudolf
Re: Memory leak ?
« Reply #1 on: 2018 February 07 02:33:49 »
Hi Rudolf,
We can't reproduce this behavior on any of our working and testing machines. As far as I know (and I test this thoroughly), there are no memory leaks in the current version of PixInsight with the current set of official modules.
I have to say that our testing machines have at least 16 GB of RAM (most of them have 32 GB, and my main workstation has 64 GB). Depending on the sizes of your images, the amount of images you open, how you process them, and what applications and utilities (including background processes and services) you are using along with PixInsight, 8 GB may not be enough to achieve an optimal user experience. This is particularly true on Windows. System resources are managed much better on macOS, and even better on Linux and FreeBSD.
This does not happen under normal working conditions, unless you are running out of resources severely. Note that native file open dialog boxes are not created or managed by PixInsight on Windows; they are managed exclusively by your operating system.
