www.pixinsight.com
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
https://pixinsight.com/forum/
News:
Home
Help
Search
Login
Register
PixInsight Forum (historical)
PixInsight
General
split and channel recombine to fix chromatic aberation
« previous
next »
Print
Pages: [
1
Author
Topic: split and channel recombine to fix chromatic aberation (Read 2206 times)
slackingCamel
Newcomer
on:
2018 January 08 01:09:50 »
i have a colour image that was taken low on the horizon and the planets have got visible chromatic abberation.
I speculate that to fix a colour image with chromatic aberration i would need to split, align, and recombine the RGB of the image.
The split and recombine i understand and can do, but how would i align them accurately?
Logged
msmythers
PTeam Member
PixInsight Jedi
Re: split and channel recombine to fix chromatic aberation
Reply #1 on:
2018 January 08 02:06:48 »
You can use the ChannelMatch tool to move the individual channels without extraction. Here is a screenshot of the tool. This is the reverse of what you want to do but it shows the movement. I had a good image and shifted the red and blue pixels leaving the green alone.
If you have CA in different direction in the corners of your image then you would need to separate the channels and use the StarAlignment tool. Use the green channel image as the reference and make sure to have Distortion correction turned on. Apply this to the red and blue channel images and then recombine. Most of the time the ChannelMatch tool will take care of the problem.
Logged
slackingCamel
Newcomer
Reply #2 on:
2018 January 08 02:53:04 »
thanks, i was experimenting with alignment, but it doesnt detect stars, its a pic of Jupiter and Mars in the same frame, hard to get stars, but i will keep at it.
Logged
slackingCamel
Newcomer
Reply #3 on:
2018 January 08 03:15:37 »
yep, the channel match will work to solve my problem, thanks very much.
Logged
Print
Pages: [
1
« previous
next »
PixInsight
General
